Correct oil filter
BWM
  • 1 month later...
I'm now too looking at doing my filter and after 2 years of not being able to find the correct filter I have found a lorry filter screw head that will fit my purolator setup
my question is do any of you guys know if your filters have a bypass valve in them and if so what rating? think the one I looked at had a 1 bar or a 2.3 bar bypass. my filter is going in before they oil pump pressure relief valve as its still got the stock side filter with control valve.
or am I correct in thinking that I need a hydrolic filter or high pressure rather than a normal type given the pump is putting about 90+ psi I pressure threw the current filter as its before the stock remote oil relief valve?
Edited by billybobbooth
