Rubbish
rawsondsr
Certainly do not burn plastic and beware also of burning packaging or anything with printing on it. Toxins may  be produced which are potentially carcinogenic. Commercial incinerators are designed to burn at much higher temperatures and have filters on the exhaust which no domestic stove can replicate.
I dare easy the next person along will say they  have been breathing toxic fumes their whole life and not experienced an ill affects.
We used to throw Christmas wrapping paper on the open fire as the various inks, metalised finishes etc. would give lots of different colours in the flames.
I have heard 'white' smoke is OK, but 'black smoke is not.
They all have an unpleasant smell  - except for me, tree wood on bonfires - that takes me back many years to happy boy scout camping days when the troop sat round the bonfire at night - signing camp fire songs - where supper was a mug of cocoa (no milk) made with hot water from a dixie hung over the fire  - a chunk of dry bread - and a chunk of cheese.
I have been breathing toxic fumes my whole life and not experienced any I'll effects. They were my own toxic fumes tbough, I'm rather less keen on other people's toxic fumes.
4 hours ago, LadyG said:
Dr Bob has specialist information, maybe he will helicopter in here.
Personally I think I'd stick to mainstream fuels.
There is nowt wrong burning polyethylene or polyprop. Both burn very clean with no nasties.....well maybe the odd little bit but nothing as bad as Supertherm. However.....burning PVC or PET ( don't burn your pets unless they are ducks) is not recommended. PVC burns to coke and HCL which is not nice. In fact it is quite bad. I would say incredibly bad but someone would comment. Not a clue what PET goes to but likely bad. Polystyrene or HIPS have benzene rings in them so again it will give off toxic stuff. 70% of waste plastic is PE/PE which is ok. If you are burning PE or PP, keep the temp up and it won't flow down and clog the grate up.
5 minutes ago, Alan de Enfield said:
When we 'overcooked' the PoM we had to evacuate the factory.
Nasty, nasty stuff.
I think it is Formaldehyde ?????? (certainly catches your eyes and throat)
What on earth is PoM? Did you mean poly methyl methacrylate? If so yes. Lots of formaldehyde. Horrible stuff. Is anything made out of PMM these days?
Acetal, Delrin various names but "chemically" Polyoxymethylene  (or PoM)
Very tough material -non-hydroscopic. We used to make plastic hose clips for various companies, - Ford used then to hold the fuel hose inside (submerged in petrol) inside the Fiesta fuel tank.
Despite being 'warned' they initially wanted PA66 we supplied and when it failed suggested they listen to what we recommended.
Image result for snapper hose clip
Edited by Alan de Enfield
Nasty, nasty stuff.
No wonder the Aussies are so down on British migrants getting sunburnt :giggles:.
This is startling. Most people use old newspaper (with print on it) to light their fires. Should we no longer do this? If not, is a firelighter any less toxic?
Or, in my case, 2 dried out teabags soaked (but not dripping) in a jar with a little white spirit. Gets the fire going a treat but now wondering how toxic that might be.
Tried newspaper, thought it was useless.
Why is Dr Bob so down on Supertherm? I've been using it happily for 3 years, tried  Homefire Ovals once but didn't get on with them. I'm now near the end of my first bag of Excel, which I think I prefer to Supertherm but not by a huge margin.
How inventive, I've never heard of that method before!
I am surprised that you have found newspaper useless, as generations of kindlers have used it successfully. Perhaps you were using the glossy magazine-style paper? This does not catch light well. You need the matt daily paper-type paper.
I realise many people do but you should not really burn printed paper.
Coloured inks probably  worse than black ink in terms of toxins produced.
Bear in mind also your boat chimney is at low level so the fumes are likely to be  be breathed in by passers by and neighbouring boat owners  as  well as yourself.
I used it for the first half of last winter and hated it cause of the noxious smoke and lots of ash. Switched to excel and it was great. This winter, the excel is leaving far more ash......and had to get a few bags of supertherm and guess what? Far less ash. Still the noxious smoke. I guess the specs on these products mean diddly squat and they vary year on year.
Interesting observations, thank you.
Luckily newsprint is generally black (unless you read the "red tops", which we don't), though of course modern papers often have some colour photos.
I'm not sure that fumes from newspaper pose much of a threat, though, because the paper burns for only about two to three minutes, long enough to set the wood alight.
