Rory_d
Central heating webasto
Hi,
i bought a narrow arrow boat a couple of weeks ago which has got a webasto diesel unit which is linked to the calorifier and 4 radiators,
my my question is how on earth do I start it up? It looks like it’s all wired in but there’s no switches anywhere so was wondering if anybody here could help
Share this post
I have looked and looked online but can’t find a manual for love nor money :(
the seller Said it was all working fine .
i can’t find a control panel so assuming there is a switch or something to make it run
i looked on webasto website but couldn’t find anything helpful there either
Share this post
Which model of Webasto is it, exactly?  Or post a photo of it.
My warm air Webasto is turned on and off by a switch at the room thermostat.
Share this post
There is no thermostat , I’ve looked everywhere !
Il have to take a picture tomorrow evening and upload it here and maybe somebody can help!
Im at the point where I’m going to rip it all out and bin it
Share this post
If it helps the wiring from the unit goes into the 12 v fuse box,
there is is a yellow and black wire that both go Into a normal domestic house light switch , if you flick the switch nothing happens. There are only 2 wires in that switch
Share this post
The fuse is fine,
There is also 2 earth wires right above the unit, these 2 earth wires go into a 12v toggle switch, if you flick the switch nothing happens.
i had the boat surveyed the other day and I asked the guy and he looked and couldn’t figure it out
Share this post
Frankly, without the manual you might as well rip it out and bin it.  It's worth putting considerable effort into identifying the appliance and getting a manual.
The level of expertise here is astonishing, but you may not realise that yet. Post a photo of it and someone will come up with the manual, almost bound to.
(Point being, the manual will tell you how to operate it, and if it doesn't work, will have a fault tracing flow chart.)
Share this post
Ok great, il get a picture on here tomorrow , Iwe will be livingon the boat in a few weeks so getting pretty desperate now as we have 2 small boys so central heating is a must!
Share this post
May be worth investigating a secondary (back-up) form of heating, particularly with a young family. (Multi-fuel?)
Boats can get mighty cold mighty quickly without heating.
Share this post
9 hours ago, RAP said:
Is it possible to ask the previous owner...
BUMP!
It could hardly have been "working fine" if there's no way to switch it on, so why not ask the previous owner this question?  This would just seem so much easier than ripping it out!
Share this post
11 hours ago, Rory_d said:
Hi,
The most common Webasto type  is the Top C and would normally have a timer.  To operate the heater manually you just press the button marked with the flame. I suggest you look for a timer like the ones in the link, it may be hiding in a cupboard.  https://www.google.co.uk/search?q=webasto+thermo+top+c&rlz=1C1AOHY_en-GBGB775GB808&tbm=isch&tbo=u&source=univ&sa=X&ved=2ahUKEwiXmK-70ZneAhUlIsAKHaaZAjcQ7Al6BAgFEA8&biw=1280&bih=845#imgrc=sdjsZNQRTdXFeM:
Contacting the previous owner would be the best option imo.
Edited by Flyboy
Share this post
I have removed most of the interior as I am
refitting it out and there is definitely no timer or control panel in there.
I cant find any loose wires either that would suggest it would of had one fitted in the first place.
il upload some pictures shortly when I get back to the boat
I have also tried to contact the old owner several times now without joy :(
Share this post
That’s the unit, it says webasto thermo top c . 12v 40w.
5kw diesel
2.5 bar
9004622a
the yellow wire out of the bottom of the chock block and the black out of the top go to the light switch I mentioned previously
Share this post
5kw diesel
2.5 bar
9004622a
What does the small blue toggle switch do ?
Share this post
I take you have tried the little blue toggle switch?
I’d be slightly alarmed at the poor quality of the electrical installation so def worth getting the manual and wiring it up properly and presumably adding a timer and thermostat would improve your comfort too!
Share this post
The wiring is a shambles, rip it out and take a + and - feed via a fuse (30A) direct to the heater, it should fire up if the battery is well charged.
Share this post
The little toggle switch doesn’t do anything, seems weird that there’s 2 earth wires switched?
The yellow low and black wires go into this switch
Share this post
If that 240v AC domestic  switched fused spur  is in the feed to the heater, the 13a fuse will be blown, the ignitor plug in the heater draws about 25A.
Share this post
