Marine VHF Frequencies Change 1/1/19
Alan de Enfield
Following the 2015 World radio conference some of the Duplex channels are being 'split', some channel spacings reducing from 25Khz to 12.5Khz, some being reserved for 'new technologies' & others are changing 'use' all as of 1/1/19
As per Annex 4, Tables 1 and 3
Some changes all ready came into effect :
From late 2017 UK Coastguard channels 23, 84 & 86 are no longer used and they now use 62, 63, & 64
Notes relating to the chart :
General Notes
a. Administrations may designate frequencies in the intership, port operations and ship movement services for use by light aircraft and helicopters to communicate with ships or participating coast station in predominantly maritime support operations under the conditions specified in Nos. 51.69, 51.73, 51.74, 51.75, 51.76, 51.77 and 51.78. However, the use of the channels which are shared with public correspondence shall be subject to prior agreement between interested and affected administrations.
b. The channels of the present Appendix, with the exception of channels 06, 13, 15, 16, 17, 70, 75 and 76, may also be used for highspeed data and facsimile transmissions, subject to special arrangement between interested and affected administrations.
c. The channels of the present Appendix, with exception of channels 06, 13, 15, 16, 17, 70, 75 and 76, may be used for direct-printing telegraphy and data transmission, subject to special arrangement between interested and affected administrations
d. The frequencies in this table may also be used for radiocommunications on inland waterways in accordance with the conditions specified in No. 5.226.
e. Administrations may apply 12.5 kHz channel interleaving on a non-interference basis to 25 kHz channels, in accordance with the most recent version of Recommendation ITU-R M.1084, provided:
  • It shall not affect the 25 kHz channels of the present Appendix maritime mobile distress and safety frequencies, especially the channels 06, 13, 15, 16, 17, 70, AIS 1 and AIS 2, nor the technical characteristics mentioned in Recommendation ITU-R M.489-2 for these channels;
  • Implementation of 12.5 kHz channel interleaving and consequential national requirements shall be subject to coordination with affected administrations.
Specific notes
f. The frequencies 156.300 MHz (channel 06), 156.525 MHz (channel 70), 156.800 MHz (channel 16), 161.975 MHz (AIS 1) and 162.025 MHz (AIS 2) may also be used by aircraft stations for the purpose of search and rescue operations and other safety-related operations.
g. Channels 15 and 17 may also be used for on-board communications provided the effective radiated power does not exceed 1 W, and subject to the national regulations of the administration concerned when these channels are used in its territorial waters.
h. Within the European Maritime Area and in Canada these frequencies (channels 10, 67, 73) may also be used, if so required, by the individual administrations concerned, for communication between ship stations, aircraft stations and participating land stations engaged in coordinated search and rescue and anti-pollution operations in local areas, under the conditions specified in Nos. 51.69, 51.73, 51.74, 51.75, 51.76, 51.77 and 51.78.
i. The preferred first three frequencies for the purpose indicated in note a) are 156.450 MHz (channel 09), 156.625 MHz (channel 72) and 156.675 MHz (channel 73).
j. Channel (70) is to be used exclusively for digital selective calling for distress, safety and calling.
k. Channel 13 is designated for use on a world-wide basis as a navigation safety communication channel, primarily for intership navigation safety communications. It may also be used for the ship movement and port operations service subject to the national regulations of the administrations concerned.
l. The channels (AIS 1 and AIS 2) are used for an automatic identification system (AIS) capable of providing worldwide operation, unless other frequencies are designated on a regional basis for this purpose.  Such use should be in accordance with the most recent version of Recommendation ITU-R M.1371.
m. These channels  may be operated as a single frequency channels, subject to coordination with affected administrations. The following conditions apply for single frequency usage:
        - The lower frequency portion of these channels may be operated as single frequency channels by ship and coast stations.
        - Transmission using the upper frequency portion of these channels is limited to coast stations.
        - If permitted by administrations and specified by national regulations, the upper frequency portion of these channels may be used by ship stations for transmission. All precautions should be taken to avoid harmful interference to channels AIS 1, AIS 2, 2027 and 2028. From 1 January 2019, channel 2027 will be designated ASM 1 and channel 2028 will be designated ASM 2.
mm. Transmission on these channels is limited to coast stations. If permitted by administrations and specified by national regulations, these channels may be used by ship stations for transmission. All precautions should be taken to avoid harmful interference to channels AIS 1, AIS 2, 2027 and 2028. From 1 January 2019, channel 2027 will be designated ASM 1 and channel 2028 will be designated ASM 2.
n. With the exception of AIS, the use of these channels (75 and 76) should be restricted to navigation-related communications only and all precautions should be taken to avoid harmful interference to channel 16 by limiting the output power to 1 W.
o. (n/a)
p. Additionally, AIS 1 and AIS 2 may be used by the mobile-satellite service (Earth-to-space) for the reception of AIS transmissions from ships.
q. When using these channels (10 and 11), all precautions should be taken to avoid harmful interference to channel 70.
r. In the maritime mobile service, this frequency is reserved for experimental use for future applications or systems (e.g. new AIS applications, man over board systems, etc.). If authorized by administrations for experimental use, the operation shall not cause harmful interference to, or claim protection from, stations operating in the fixed and mobile services.
s. Channels 75 and 76 are also allocated to the mobile-satellite service (Earth-to-space) for the reception of long-range AIS broadcast messages from ships (Message 27; see the most recent version of Recommendation ITU-R M.1371).
t. (n/a)
u. (n/a)
v. (n/a)
w. In Regions 1 and 3:
Until 1 January 2017, the frequency bands 157.025-157.325 MHz and 161.625-161.925 MHz (corresponding to channels: 80, 21, 81, 22, 82, 23, 83, 24, 84, 25, 85, 26, 86) may be used for new technologies, subject to coordination with affected administrations. Stations using these channels or frequency bands for new technologies shall not cause harmful interference to, or claim protection from, other stations operating in accordance with Article 5.
From 1 January 2017, the frequency bands 157.025-157.325 MHz and 161.625-161.925 MHz (corresponding to channels: 80, 21, 81, 22, 82, 23, 83, 24, 84, 25, 85, 26, 86) are identified for the utilization of the digital systems described in the most recent version of Recommendation ITU-R M.1842. These frequency bands could also be used for analogue modulation described in the most recent version of Recommendation ITU-R M.1084 by an administration that wishes to do so, subject to not claiming protection from other stations in the maritime mobile service using digitally modulated emissions and subject to coordination with affected administrations.
ww. In Region 2 (i.e. N. and S. America), the frequency bands 157.200-157.325 and 161.800-161.925 MHz (corresponding to channels: 24, 84, 25, 85, 26 and 86) are designated for digitally modulated emissions in accordance with the most recent version of Recommendation ITU-R M.1842.
wa. In Regions 1 and 3:
        Until 1 January 2017, the frequency bands 157.025-157.175 MHz and 161.625-161.775 MHz (corresponding to channels: 80, 21, 81, 22, 82, 23 and 83) may be used for digitally modulated emissions, subject to coordination with affected administrations. Stations using these channels or frequency bands for digitally modulated emissions shall not cause harmful interference to, or claim protection from, other stations operating in accordance with
Article 5.
        From 1 January 2017, the frequency bands 157.025-157.100 MHz and 161.625-161.700 MHz (corresponding to channels: 80, 21, 81 and 22) are identified for utilization of the digital systems described in the most recent version of Recommendation ITU-R M.1842 using multiple 25 kHz contiguous channels.
        From 1 January 2017, the frequency bands 157.150-157.175 MHz and 161.750-161.775 MHz (corresponding to channels: 23 and 83) are identified for utilization of the digital systems described in the most recent version of Recommendation ITU-R M.1842 using two 25 kHz contiguous channels. From 1 January 2017, the frequencies 157.125 MHz and 161.725 MHz (corresponding to channel: 82) are identified for the utilization of the digital systems described in the most recent version of Recommendation ITU-R M.1842.
        The frequency bands 157.025-157.175 MHz and 161.625-161.775 MHz (corresponding to channels: 80, 21, 81, 22, 82, 23 and 83) can also be used for analogue modulation described in the most recent version of Recommendation ITU-R M.1084 by an administration that wishes to do so, subject to not claiming protection from other stations in the maritime mobile service using digitally modulated emissions and subject to coordination with affected administrations.
ww. In Region 2, the frequency bands 157.200-157.325 and 161.800-161.925 MHz (corresponding to channels: 24, 84, 25, 85, 26 and 86) are designated for digitally modulated emissions in accordance with the most recent version of Recommendation ITU-R M.1842.
In Canada and Barbados, from 1 January 2019 the frequency bands 157.200-157.275 and 161.800-161.875 MHz (corresponding to channels: 24, 84, 25 and 85) may be used for digitally modulated emissions, such as those described in the most recent version of Recommendation ITU-R M.2092, subject to coordination with affected administrations.
x. From 1 January 2017, in Angola, Botswana, Lesotho, Madagascar, Malawi, Mauritius, Mozambique, Namibia, Democratic Republic of the Congo, Seychelles, South Africa, Swaziland, Tanzania, Zambia and Zimbabwe, the frequency bands 157.125-157.325 and 161.725-161.925 MHz (corresponding to channels: 82, 23, 83, 24, 84, 25, 85, 26 and 86) are designated for digitally modulated emissions.
From 1 January 2017, in China, the frequency bands 157.150-157.325 and 161.750-161.925 MHz (corresponding to channels: 23, 83, 24, 84, 25, 85, 26 and 86) are designated for digitally modulated emissions.
xx. From 1 January 2019, the channels 24, 84, 25 and 85 may be merged in order to form a unique duplex channel with a bandwidth of 100 kHz in order to operate the VDES terrestrial component described in the most recent version of Recommendation ITU-R M.2092.
y. These channels may be operated as single or duplex frequency channels, subject to coordination with affected administrations.
z. Until 1 January 2019, these channels may be used for possible testing of future AIS applications without causing harmful interference to, or claiming protection from, existing applications and stations operating in the fixed and mobile services.
From 1 January 2019, these channels are each split into two simplex channels. The channels 2027 and 2028 designated as ASM 1 and ASM 2 are used for application specific messages (ASM) as described in the most recent version of Recommendation ITU-R M.2092.
zx. In the United States, these channels are used for communication between ship stations and coast stations for the purpose of public correspondence.
zz. From 1 January 2019, channels 1027, 1028, 87 and 88 are used as single-frequency analogue channels for port operation and ship movement.
Frequency, new channel numbers and changes
Table of Transmitting Frequencies in the VHF Maritime Mobile
Channel Designator
Notes
Transmitting Frequencies (MHz)
Intership
Port Operations and Ship Movement
Public correspondence
Ship Stations
Coast Stations
Single frequency
Two frequency
60
m
156.025
160.625
  x
x
x
01
m
156.050
160.650
  x
x
x
1001   156.050 156.050   x
61
m
156.075
 160.675
  x
x
x
02
m
156.100
 160.700
  x
x
x
62
m
156.125
 160.725
  x
x
x
03
m
156.150
 160.750
  x
x
x
63
m
156.175
 160.775
  x
x
x
1063   156.175 156.175   x
04
m
156.200
  160.800
  x
x
x
64
m
156.225
  160.825
  x
x
x
05
m
156.250
  160.850
  x
x
x
1005   156.250 156.25   x
65
m
156.275
  160.875
  x
x
x
1065   156.275 156.275   x
06
f
156.300
x
2006 r   160.900   160.900
66
m
156.325
  160.925
  x
x
x
1066   156.325 156.325   x
07
m
156.350
 160.950
  x
x
x
1007   156.350 156.350   x
67
h
156.375
 156.375
x
x
08
156.400
x
68
156.425
156.425
x
09
i
156.450
156.450
x
x
69
156.475
156.475
x
x
10
h,q
156.500
156.500
x
x
70
f,j
156.525
156.525
Digital selective calling for distress, safety and calling
11
q
156.550
156.550
x
71
156.575
156.575
x
12
156.600
156.600
x
72
i
156.625
x
13
k
156.650
156.650
x
x
73
h,i
156.675
156.675
x
x
14
156.700
156.700
x
74
156.725
156.725
x
15
g
156.750
156.750
x
x
75
n,s
156.775
156.775
x
16
f
156.800
156.800
DISTRESS, SAFETY AND CALLING
76
n,s
156.825
156.825
x
17
g
156.850
156.850
x
x
77
156.875
x
18
m
156.900
161.500
x
x
x
1018   156.900 156.900   x
78
m
156.925
161.525
  x
x
x
1078   156.925 156.925   x
2078 mm 161.525 161.525   x
19
m
156.950
161.550
  x
x
x
1019   156.950 156.950   x
2019 mm 161.550 161.550   x
79
m
156.975
161.575
  x
x
x
1079   156.975 156.975   x
2079 mm 161.575 161.575   x
20
m
157.000
161.600
  x
x
x
1020   157.000 157.000   x
2020 mm 161.600 161.600   x
80
157.025
161.625
  x
x
x
1080   157.025 157.025   x
21
y,wa
157.050
161.650
  x
x
x
1021   157.050 157.050     x
81
y,wa
157.075
161.675
  x
x
x
1081   157.075 157.075   x
22
y,wa
157.100
161.700
  x
x
x
1022   157.100 157.100   x
82
x,y,wa
157.125
161.725
x
x
x
1082   157.125 157.125   x
23
x,y,wa
157.150
161.750
  x
x
x
1023   157.150 157.150   x
83
x,y,wa
157.175
161.775
x
x
x
1083   157.175 157.175   x
24
w,wx,x,xx
157.200
161.800
  x
x
x
1024
w,wx,x,xx
157.200
2024
w,wx,x,xx
161.800
161.800
x
(digital only)
84
w,wx,x,xx
157.225
161.825
x
x
x
1084
w,wx,x,xx
157.225
x
(digital only)
2084
w,wx,x,xx
161.825
161.825
25
w,wx,x,xx
157.250
161.850
  x
x
x
1025
w,wx,x,xx
157.250
x
(digital only)
2025
w,wx,x,xx
161.850
161.850
85
w,wx,x,xx
157.275
161.875
x
x
x
1085
w,wx,x,xx
157.275
2085
w,wx,x,xx
161.875
161.875
26
w,ww,x
157.300
161.900
  x
x
x
1026
w,ww,x
157.300
2026
w,ww,x
161.900
86
w,ww,x
157.325
161.925
x
x
x
1086
w,ww,x 157.325
2086 w,ww,x   161.925
27
z,zx
157.350
161.950
x
x
1027 z,zz 157.350 157.350
ASM 2 (2027) z 161.950 161.950
87
z,zz
157.375
157.375
x
28
z,zx
157.400
162.000
x
x
1028
z,zz
157.350
157.350
  x
ASM 2 (2028) z 162.000 162.000
88
z,zz
157.425
157.425
x
AIS 1
f, l, p
161.975
161.975
AIS 2
f, l, p
162.025
162.025
Edited by Alan de Enfield
28 minutes ago, GRLMK38 said:
Thanks Alan.  Do you know if this means that radio firmware will need to be updated?
The majority of the channels that are used 'inland' will remain unaffected,
The additional channels and the revised spacings will require adding into your programming (if you can do it, or the radio allows it)
I have updated my hand-helds (I rarely use the 'base station').
8 minutes ago, Jen-in-Wellies said:
Tried and failed to make sense of this. Does it affect any of the channels used on the Trent? 6 commercial shipping, 74 CaRT lockies and 16? The only place I use VHF.
Jen
No. You will be fine.
Channel 74 unaffected.
But if relying on the Coastguard they no longer keep a listening watch on Channel 16
Channel 6 is now allocated to Aircraft SAR, but this appears to be currently in addition to Marine usage.
Keep monitoring the news from ABP etc for any channel change information.
I thought that the coastguard had sometime ago stopped keeping a listening watch on 16, as DSC renders this unnecessary.  Not relevant to inland users though, and in general it seems inland use would not be changed.
Scanning through the changes it seems that it is about making better use of the spectrum, and allowing digital use of some channels.  This would presumably require new radios to take full advantage.
Depending on your radio, some can be 'owner' reprogrammed, some may have to go back to the manufacturer and I guess some will be unable to be modified.
I have a programming lead for my hand-held's and when connected to the PC you can go into the programme list and add / change / remove / rename channels and amend channel spacings.
