PeterCr Posted October 6, 2018 Report Share Posted October 6, 2018 I'm considering options for mooring over winter, for about 7 or 8 months. Some of those options are in locations without power. I don't have solar panels. Should I be considering leaving the boat without a power supply for that time? What are the implications for the batteries? And is leaving the boat on continual power for that length of time an issue for the batteries as well if I elected for a power supply? Thanks all. Link to comment Share on other sites More sharing options...
Robbo Posted October 6, 2018 Report Share Posted October 6, 2018 Can you take your batteries home and keep them on a charge? Link to comment Share on other sites More sharing options...
PeterCr Posted October 6, 2018 Author Report Share Posted October 6, 2018 Just now, Robbo said: Can you take your batteries home and keep them on a charge? No sadly I live in Australia. The weight limit on the flight might be an issue! 1 2 Link to comment Share on other sites More sharing options...
rusty69 Posted October 6, 2018 Report Share Posted October 6, 2018 (edited) The batteries would prefer to be charged to prolong their life.You could take them home as Robbo suggests,but would loose any benefit of an automatic bilge pump if you have one fitted. Leaving batteries on a dedicated charger is no problem as long as that charger is a decent marine type one with "float" function. The other option, of course, is to have some solar fitted.Although the performance isn't brilliant through the Winter, it may be enough to maintain your battery bank if sized correctly. If you do leave it,as always take precautions regarding frost damage. Edited October 6, 2018 by rusty69 Link to comment Share on other sites More sharing options...
NB Lola Posted October 6, 2018 Report Share Posted October 6, 2018 Batteries will suffer over that period. Power to boat is required unless you can find a friend to look after them. Even then, you need to consider your bulge pump and need for operation. You will know your boats water ingress. Link to comment Share on other sites More sharing options...
Mike Hurley Posted October 6, 2018 Report Share Posted October 6, 2018 Just buy a basic solar panel, nothing fancy, keeps the battery charged and bilge pump operational. 3 Link to comment Share on other sites More sharing options...
MtB Posted October 6, 2018 Report Share Posted October 6, 2018 3 minutes ago, PeterCr said: I'm considering options for mooring over winter, for about 7 or 8 months. Some of those options are in locations without power. I don't have solar panels. Should I be considering leaving the boat without a power supply for that time? What are the implications for the batteries? And is leaving the boat on continual power for that length of time an issue for the batteries as well if I elected for a power supply? Thanks all. Firstly, you seem to be planning not to use the boat over winter. Why not? This is the BEST cruising time! But back on topic, solar panels don't deliver any worthwhile output in winter anyway so not having them is no great handicap. They might perhaps counter 'self-discharge but equally they might not. What batteries do you have? If decent quality batts I'd say leaving them fully charged for a month or so will be fine. Visit the boat once every few weeks (say every four to six weeks but not critical) and run the engine a few hours to keep them topped up with charge. If you only have el cheapo leisures they are probably knackered anyway if they are more than half an hour old, so don't fret about them and just buy new ones in the spring. 1 Link to comment Share on other sites More sharing options...
Mike Hurley Posted October 6, 2018 Report Share Posted October 6, 2018 1 minute ago, Mike the Boilerman said: Visit the boat once every few weeks (say every four to six weeks From Australia? New batteries every year would be cheaper. 1 minute ago, Mike the Boilerman said: 1 1 Link to comment Share on other sites More sharing options...
PeterCr Posted October 6, 2018 Author Report Share Posted October 6, 2018 1 minute ago, Mike the Boilerman said: Firstly, you seem to be planning not to use the boat over winter. Why not? This is the BEST cruising time! But back on topic, solar panels don't deliver any worthwhile output in winter anyway so not having them is no great handicap. They might perhaps counter 'self-discharge but equally they might not. What batteries do you have? If decent quality batts I'd say leaving them fully charged for a month or so will be fine. Visit the boat once every few weeks (say every four to six weeks but not critical) and run the engine a few hours to keep them topped up with charge. If you only have el cheapo leisures they are probably knackered anyway if they are more than half an hour old, so don't fret about them and just buy new ones in the spring. We'll be in Australia for the summer/winter, it's expensive to fly back, so won't be coming back till May or thereabouts for 4 or 5 months over the summer here cruising. I've got Vetus 105 ah lead acid batteries. Sadly I'm no expert on batteries hence wondering what I should be doing for the 7 or 8 months the boat is laid up. I've got 7 batteries (bow thruster, starter and 5 domestic) so buying a new lot isn't cheap. They seem fine so far, relatively new. Link to comment Share on other sites More sharing options...
mrsmelly Posted October 6, 2018 Report Share Posted October 6, 2018 5 minutes ago, PeterCr said: We'll be in Australia for the summer/winter, it's expensive to fly back, so won't be coming back till May or thereabouts for 4 or 5 months over the summer here cruising. I've got Vetus 105 ah lead acid batteries. Sadly I'm no expert on batteries hence wondering what I should be doing for the 7 or 8 months the boat is laid up. I've got 7 batteries (bow thruster, starter and 5 domestic) so buying a new lot isn't cheap. They seem fine so far, relatively new. if you are leaving it with an option of power? A small battery charger pukka one will just keep them on float at very very little cost and the batteries will be very happy next year. There must be a grands worth of batteries there so you need to weigh up the cost against mooring costs. Link to comment Share on other sites More sharing options...
OldGoat Posted October 6, 2018 Report Share Posted October 6, 2018 4 minutes ago, Mike Hurley said: From Australia? New batteries every year would be cheaper. Folks just don't read the full thread do they??? Short answer - yes Long answer - what would the 'leccy supply cost? Does your mooring location have a 'leccy supply or would a supply restrict where you could moor? Just read your latest post - with lots of batteries, I think a decent charger setup in a comfortable marina where someone can keep an eye on the boat seems best. Seven months is a long time. Last season I left our boat for three months and the starter battery was dead when I got to the marina. The mains were fine 'cos they're NiFe. Link to comment Share on other sites More sharing options...
rusty69 Posted October 6, 2018 Report Share Posted October 6, 2018 1 minute ago, OldGoat said: Folks just don't read the full thread do they??? To be fair, the answers were coming thick and fast, and perhaps MTB was typing his response whilst the other had been posted. Link to comment Share on other sites More sharing options...
MtB Posted October 6, 2018 Report Share Posted October 6, 2018 8 minutes ago, PeterCr said: We'll be in Australia for the summer/winter, A feeble excuse!!!! But seriously, if your bothered about the cost of replacing them I'd say get a mooring with 240Vac power. Then you can wire them all up to a three stage charger which will keep them in tip-top condition for when you get back. HST, the price of a mooring with 240Vac over the price of one without may well be bout the same as a new set of batteries.... 1 Link to comment Share on other sites More sharing options...
OldGoat Posted October 6, 2018 Report Share Posted October 6, 2018 2 minutes ago, Mike the Boilerman said: A feeble excuse!!!! But seriously, if your bothered about the cost of replacing them I'd say get a mooring with 240Vac power. Then you can wire them all up to a three stage charger which will keep them in tip-top condition for when you get back. HST, the price of a mooring with 240Vac over the price of one without may well be bout the same as a new set of batteries.... Really, where we are the provision of 'leccy is in the price - which is obscene anyway.... Link to comment Share on other sites More sharing options...
roland elsdon Posted October 6, 2018 Report Share Posted October 6, 2018 For the last 7 years we have kept the boats batterys charged over uk winter with a 160 panel and regulator. We put all the batteries in parallel during our time in oz, and leave only the bilge pump fuse in circuit. we do the same in aus with our camper ( apart from the bilge pump bit) neither boat nor van has failled to start in spring. we have lost 2 car batteries though, once when the solar panel in the screen got into darkness ( a friend pushed the car into the carport when inclement weather threatened)and once when the fuse on a panel failed. Both batteries were ruined. Dont leave them with nothing- it will cost you big time, and disconnect from any load but bilge pump when we got here in april our batts were at 13.6 volts. might see you in victoria off in nov. Link to comment Share on other sites More sharing options...
MtB Posted October 6, 2018 Report Share Posted October 6, 2018 9 minutes ago, OldGoat said: Folks just don't read the full thread do they??? Well actually, yes they do. I was typing my first reply when the thread filled up and this information initially not mentioned, was posted. Link to comment Share on other sites More sharing options...
PeterCr Posted October 6, 2018 Author Report Share Posted October 6, 2018 1 minute ago, Mike the Boilerman said: A feeble excuse!!!! I'm a little stuck with being here more than for the 5 months or so cruising. Whilst I'm Australian my wife is English, so technically we could stay here all year. But if you've ever looked at the extraordinary cost and hassle of getting the visa that I need to stay here all year! So I only get visitor visas, so can't stay any longer. 4 minutes ago, roland elsdon said: might see you in victoria off in nov. Call when you're there, would be nice to catch up. Link to comment Share on other sites More sharing options...
OldGoat Posted October 6, 2018 Report Share Posted October 6, 2018 2 minutes ago, PeterCr said: I'm a little stuck with being here more than for the 5 months or so cruising. Whilst I'm Australian my wife is English, so technically we could stay here all year. But if you've ever looked at the extraordinary cost and hassle of getting the visa that I need to stay here all year! So I only get visitor visas, so can't stay any longer. Strewth mate - leave the Sheila here to look after the boat and you go home to drink all those tinnies.... 2 Link to comment Share on other sites More sharing options...
peterboat Posted October 6, 2018 Report Share Posted October 6, 2018 I am in the solar panel camp the bonus is that next year you will have the use of it as well when you decide not to cruise on a day Link to comment Share on other sites More sharing options...
PeterCr Posted October 6, 2018 Author Report Share Posted October 6, 2018 Just now, OldGoat said: Strewth mate - leave the Sheila here to look after the boat and you go home to drink all those tinnies.... Too late she's on the plane as we speak/type. The only upside is that she's going home to work! Link to comment Share on other sites More sharing options...
alan_fincher Posted October 6, 2018 Report Share Posted October 6, 2018 Don't forget that if you are going to leave it permanently plugged into the mains yo really do nedd a galvanic isolator or isolation transformer fitted, if you are not going to risk erosion of your bat's hull. Even if you do connect to the mains and leave a battery charger connected you will need somebody periodically checking thed arrangements surely? If something causes a breaker on that supply to trip after you have got on that plane back to Australia, and you have nobody to keep an eye, and reset things if required, you could be no better iff than leaving the boat with no mains. Link to comment Share on other sites More sharing options...
Alan de Enfield Posted October 6, 2018 Report Share Posted October 6, 2018 2 minutes ago, PeterCr said: I'm a little stuck with being here more than for the 5 months or so cruising. Whilst I'm Australian my wife is English, so technically we could stay here all year. But if you've ever looked at the extraordinary cost and hassle of getting the visa that I need to stay here all year! So I only get visitor visas, so can't stay any longer. You have explained this a number of times over the last couple of years, surely it shouldn't need explain again ? I'd go for power if you can. You can also add in engine room heaters save any freezing up problems and the forecast is for the coldest winter since 1814-15 when the Thames froze over. My engine room heaters use about £30 per month of electric. Link to comment Share on other sites More sharing options...
roland elsdon Posted October 6, 2018 Report Share Posted October 6, 2018 A basic panel and regulator is about 150-200 get an mppt regulator even on a small panel, we use a victron. In summer even with only 160 w panel by mid afternoon on days when we dont boat it will charge up to 14.3 volts and then drop to float, even with our electric fridge. Link to comment Share on other sites More sharing options...
rusty69 Posted October 6, 2018 Report Share Posted October 6, 2018 (edited) 3 minutes ago, alan_fincher said: Don't forget that if you are going to leave it permanently plugged into the mains yo really do nedd a galvanic isolator or isolation transformer fitted, if you are not going to risk erosion of your bat's hull. Even if you do connect to the mains and leave a battery charger connected you will need somebody periodically checking thed arrangements surely? If something causes a breaker on that supply to trip after you have got on that plane back to Australia, and you have nobody to keep an eye, and reset things if required, you could be no better iff than leaving the boat with no mains. He could always get one of those plug in sim card power loss devices(another expense).Granted, he would still need someone to turn the power back on and assess the situation. Edited October 6, 2018 by rusty69 Link to comment Share on other sites More sharing options...
OldGoat Posted October 6, 2018 Report Share Posted October 6, 2018 2 minutes ago, Alan de Enfield said: You have explained this a number of times over the last couple of years, surely it shouldn't need explain again ? ....... Hey, hey 'twas in response to my trying to write Strine. I didn't know, but then I don't read everything... Link to comment Share on other sites More sharing options...
