jenevers
Mastervolt Charger query
I plugged into the mains last night, for the first time in over a year (been on 800W solar feeding 6x 6v Trojans).
The 12/80 Mass 12 volt Charger went into Float eventually, but this morning has gone back to back into absorption. At the moment it’s reading 15.16v!! and 12.5A. Should I be worried?
Share this post
Sounds like it’s decided that your batteries are due an equalisation charge. It should drop back into absorption or float after about an hour. Just keep an eye on it to ensure that it does, and don’t forget to check electrolyte levels afterwards.
Share this post
Thanks. Levels are OK. I thought 15.16v was a bit high. Batteries are only slightly warm. Btw even though I have temperature sensors on the batteries, the Tracer remote control seems to indicate the temperature of the Tracer itself rather than the batteries, is this normal?
Share this post
OK.
I’m sure I didn’t set the charger to go as high as 15.16v via the Masterlink MICC, (Trojan recommend 14.8 From memory).
I’ll give things few hours and see what happens. Don’t suppose the Trojans will come to any harm.
Share this post
Quite the opposite, they’ll love it :)
Share this post
Don’t forget that whatever voltage you set is the one you’ll get at 25C. If the battery temperature is colder than that, the voltage will be higher.
Share this post
All that and plus... if your DC load is high enough, it'll drop the voltage low enough for the Mastervolt to kick in an absorption cycle. Lights on, shower using water pump and gulper, fridge door opening and closing at breakfast time causing that to work overtime, etc.  Has it settled down now and gone back to float?
Share this post
Good point. It was only 17C.
Yes, back on float. Been 14.08v for last 4 hours.
Share this post
Float should be 13.5v. Prolonged “floating” at 14.08 or thereabouts will shorten the batteries’ life.
Share this post
I’d better check the MICC settings if the voltage doesn’t come down soon.
Share this post
I unplugged from the mains at 7pm last night.
Had TV on for 3 hours, fridge/freezer is on permanently. This morning voltage is 12.67v.
Looks good🙂
Share this post
