efish__ Posted September 16, 2018 Report Share Posted September 16, 2018 So we've been having issues with our raw water system - turned out the impeller shaft on the Jabsco 7860 was really scored and having a new one machined - this was letting water into the sump so have been giving her a deep clean - thought I would descale the exhaust manifold as it's full of limescale - on removal I noticed one cylinder has water in the exhaust part and little limescale while the other side has a dry exhaust but loads of limescale? Why could this be?? Also any descaling solutions that won't harm engine or environment? Thanks, Ed Link to comment Share on other sites More sharing options...
RLWP Posted September 16, 2018 Report Share Posted September 16, 2018 Top one is full of soot, the bottom one is full of oil Link to comment Share on other sites More sharing options...
efish__ Posted September 16, 2018 Author Report Share Posted September 16, 2018 what's the cause? cylinder head gasket? worn piston rings? Link to comment Share on other sites More sharing options...
RLWP Posted September 16, 2018 Report Share Posted September 16, 2018 3 minutes ago, efish__ said: what's the cause? cylinder head gasket? worn piston rings? Soot? Poor combustion/ long time since injector or pump overhaul/ leaking valves Oil? Piston rings/ worn valve guides Richard Link to comment Share on other sites More sharing options...
efish__ Posted September 17, 2018 Author Report Share Posted September 17, 2018 15 hours ago, RLWP said: Soot? Poor combustion/ long time since injector or pump overhaul/ leaking valves Oil? Piston rings/ worn valve guides Richard I think Valve guides is possible on that cylinder as I get a ticking sound from that side - anything I need to consider when replacing / should I do a full decarb while I'm at it? Or is it not worth it - she's an old engine so a bit of smoke and noise aint bad. Cheers Link to comment Share on other sites More sharing options...
RLWP Posted September 17, 2018 Report Share Posted September 17, 2018 Last time I was on Albion, the engine seemed OK. Chances are she's getting a bit tired and in need of a decoke. If you check your manual you'll find the recommended frequency which is in the hundreds of hours - not the same as a modern car Richard Link to comment Share on other sites More sharing options...
