johnbullsbum Posted September 4, 2018 Report Share Posted September 4, 2018 hi all. i have recently changed leisure batteries to the 6v trojan t105s. now in the process of installing 1kw of solar, the controllers and breakers are in place and wired into the batteries but the panels arent due untill friday. would there be an issue of turning on the controllers before the panels are in place and wired up.. thanks all Link to comment Share on other sites More sharing options...
TheBiscuits Posted September 4, 2018 Report Share Posted September 4, 2018 3 minutes ago, johnbullsbum said: hi all. i have recently changed leisure batteries to the 6v trojan t105s. now in the process of installing 1kw of solar, the controllers and breakers are in place and wired into the batteries but the panels arent due untill friday. would there be an issue of turning on the controllers before the panels are in place and wired up.. thanks all Probably not. Most controller instructions state you should connect the batteries before you connect the panels - what do yours say? Your controller will just think it is dark outside until you add the panels and you will be able to set up the voltages for bulk/float/equalise in advance. Link to comment Share on other sites More sharing options...
Jess-- Posted September 4, 2018 Report Share Posted September 4, 2018 no issue that I can think of if it was the other way around (panels but no batteries) you could do damage. Link to comment Share on other sites More sharing options...
Robbo Posted September 4, 2018 Report Share Posted September 4, 2018 (edited) 1 minute ago, Jess-- said: no issue that I can think of if it was the other way around (panels but no batteries) you could do damage. Recommended to put an isolator switch on the panel side so you easily switch off the panels if you need to . Edited September 4, 2018 by Robbo Link to comment Share on other sites More sharing options...
johnbullsbum Posted September 4, 2018 Author Report Share Posted September 4, 2018 Just now, TheBiscuits said: Probably not. Most controller instructions state you should connect the batteries before you connect the panels - what do yours say? Your controller will just think it is dark outside until you add the panels and you will be able to set up the voltages for bulk/float/equalise in advance. instructions say to connect batteries first so i may just switch it on and see what happens Link to comment Share on other sites More sharing options...
Robbo Posted September 4, 2018 Report Share Posted September 4, 2018 35 minutes ago, johnbullsbum said: instructions say to connect batteries first so i may just switch it on and see what happens Link to comment Share on other sites More sharing options...
Richard10002 Posted September 4, 2018 Report Share Posted September 4, 2018 9 hours ago, johnbullsbum said: hi all. i have recently changed leisure batteries to the 6v trojan t105s. now in the process of installing 1kw of solar, the controllers and breakers are in place and wired into the batteries but the panels arent due untill friday. would there be an issue of turning on the controllers before the panels are in place and wired up.. thanks all Why the rush? Turning on the controllers is done by connecting the battery wires, then connecting the panel wires. Why not get it all set up for connecting, fit the panels, including some kind of panel isolation switch, then connect it all up. Link to comment Share on other sites More sharing options...
Anna-Claire Posted October 9, 2018 Report Share Posted October 9, 2018 Needing help with my electrics and solar pannels. Recently brought a project boat, 43ft dutch barge, the elctrics are completley buggered, it does have 3 solar pannels, but I'm looking for some help in installing the rest. I'm looking to live aboard so anyone withing the Hillingdon borough would be great. Many Thanks Link to comment Share on other sites More sharing options...
Robbo Posted October 9, 2018 Report Share Posted October 9, 2018 1 hour ago, Anna-Claire said: Needing help with my electrics and solar pannels. Recently brought a project boat, 43ft dutch barge, the elctrics are completley buggered, it does have 3 solar pannels, but I'm looking for some help in installing the rest. I'm looking to live aboard so anyone withing the Hillingdon borough would be great. Many Thanks You might want to create another thread. Link to comment Share on other sites More sharing options...
Sea Dog Posted October 9, 2018 Report Share Posted October 9, 2018 1 hour ago, Robbo said: You might want to create another thread. Oh I don't know, the OP appears to have left this one lying around unfinished! Maybe it's the same "project"? Rather a lot of those get abandoned. Link to comment Share on other sites More sharing options...
