fudd Posted September 2, 2018 Report Share Posted September 2, 2018 Good afternoon. What oil pressure should my gauge read? I recently had to strip the oil feed pipes and filter housing to take my gearbox out. It’s reading 20-25 psi. Also the rockers don’t seem to be very oily. Thanks in advance. Steve P Link to comment Share on other sites More sharing options...
steamraiser2 Posted September 2, 2018 Report Share Posted September 2, 2018 Your oil pressure should be in the 30/45 psi range. I would investigate why yours is so low as a matter of urgency if I were you. Check your filter,if you have one, and the oil pressure relief valve. Link to comment Share on other sites More sharing options...
fudd Posted September 2, 2018 Author Report Share Posted September 2, 2018 13 minutes ago, steamraiser2 said: Your oil pressure should be in the 30/45 psi range. I would investigate why yours is so low as a matter of urgency if I were you. Check your filter,if you have one, and the oil pressure relief valve. I changed the filter last week. I’ve got no idea where the prv is. I’ll try and find a manual. Thank you. Link to comment Share on other sites More sharing options...
RLWP Posted September 3, 2018 Report Share Posted September 3, 2018 We have HW manuals Link to comment Share on other sites More sharing options...
