Sign in to follow this
Gra73
Johnstone’s Garage Floor Paint
6 hours ago, Gra73 said:
Can anyone attest to the use of Johnstone’s Garage Floor Paint on their Stern Decking?
Looks like a 'NO' then....!
Garage floor paint has two problems. Firstly it is formulated for use in dry conditions, it may not cope with prolonged rain well. Secondly is is not resistant to UV sunlight radiation.
If you decide to use it, do let us know how durable it turns out to be.
Share this post
Thirdly, as it is largely impervious to Water it is very slippery when wet.
Share this post
Fourthly, is your rear deck concrete? It may not adhere too well to other substrates or be flexible enough.
Share this post
Ora, there's another thread running where the subject is floor paint on the roof - you may find that helpful.  I'm in the camp that says use the right paint for the right job so I'd just use a deck paint and remove the doubt, but floor paint does seem to have its followers. It is, however, not formulated for exterior steelwork on boats as I'm sure Johnstones themselves would be the first to advise if asked. Good luck.
Share this post
One would hope all exterior boat paint (including Raddle) is impervious to water so I’m not sure that reasoning follows.
More likely slippery when wet if gloss finish.
Share this post
Agreed. Protective coatings are designed to be impervious to water.
Flooring coatings are usually high build i.e. thicker than 'normal' paint and will be designed to be tough and hard. Obviously using a decking paint for steel would be better but if you have the garage paint spare you may get away with it but as above:
- if water pools on your rear deck when it rains, like it does on a section of ours, then that would be a weak point
- concrete coatings are often designed to go straight onto the surface whereas a steel coating usually has a primer coat to get best adhesion. If you get rid of any rust, the garage paint should adhere reasonably well.
- UV stabilization is a big issue. I would give Johnsons a ring and see if it is ok for outdoors(I doubt it).....and don't use red as that will not be as color fast as outdoor red coatings.
Share this post
I used a garage floor paint on some vertical surfaces in our trad engine room last year, cos i was too tight do do the whole thing in jotamastic 87. So far, tis ok.
Share this post
1 minute ago, Gra73 said:
Thanks Sea Dog, could you suggest one please?
I've used Andy Russell's Gunwale paint, but I can't attest to its grip or resistance to abrasion on a steerer's step (although it's fine on the gunwales!) as I have Dri-Dek grid tiles on top so there's no direct contact.  In warships we used a deck paint clled Camrex which was waterproof, hard wearing - and very grippy! There must be a less military equivalent available at a chandler's. I'd be inclined to ask our resident paint experts what they'd recommend for the application (rather than asking about garage floor paint to which they might not reply). Hope that helps.
Share this post
Was that to assist the spiders climbing the walls?
Share this post
2 hours ago, Mike the Boilerman said:
One would hope all exterior boat paint (including Raddle) is impervious to water...
You’d think so, wouldn’t you?
However a Leyland tech wrote “Unfortunately non of our floor paints are suitable to be used externally. They do not allow moisture to pass through and would potentially become very slippery if saturated by rainfall. Thanks
from the q&a here: https://www.screwfix.com/p/leyland-trade-heavy-duty-floor-paint-slate-5ltr/49596
Share this post
Wow. What a lot of numpties!
You cannot protect the steel (or concrete) if it lets water through!!
The best floor coatings I have seen have been modified 2 pack epoxies for use on off-shore platforms. Top of the list for performace criteria were adhesion, resistance to water transmission and toughness. You then build in the antislip without affecting the other properties.
Share this post
I'm not Sea Dog, but i always recommend international interdeck. It's very easy to apply.
Share this post
Nah,  folk use that on their garage floors.
Share this post
Surprised nobody has mentioned that steel expands quite a lot more than concrete, and whatever paint is stuck to it, that coating has to expand as well. If it doesn't, it peels off. This, it seems to me, might be another reason why the formulations of floor paint and deck paint are different? I know nothing about paint chemistry but I'm with Seadog (post 6):
Edited by Machpoint005
punctuation
Share this post
Many thanks for all the valid contributions, I have bought the correct paint for the purpose as per the sensible comments received, suffice to say the topic has fulfilled it’s use.
Regards
Gra
Share this post
Yes, Leyland confirmed that their floor paint isn't suitable. I used an International non slip paint on the back deck a few years ago. Hopeless. It flaked off the Masons paint that was under it, and anything applied on top flaked off too. Had to remove it completely to redo the deck.
Share this post
Sounds like a 6 Ps issue to me.  ;)
Share this post
I used floor paint on a boat roof some years ago.
It didn't last long - basically it's just not the right stuff for the job as alluded to above.
Share this post
I painted my entire boat in Johnstone metal paints with excellent results couldnt be happier with their paints, just did another boats engine bay with their zinc phosphate primer and a few top coats of grey metal paint and it looks great
Rick
Share this post
