eid Posted August 18, 2018 Report Share Posted August 18, 2018 On my tiller there is a grease nipple. Is there a particular type/size of grease gun I need for this, or are they a standard size? Thanks. Link to comment Share on other sites More sharing options...
Chewbacka Posted August 18, 2018 Report Share Posted August 18, 2018 I use the one I bought in the late 70’s for my Ford mk1 Escort, I use the same grease as I put in the stern tube greaser. Link to comment Share on other sites More sharing options...
dmr Posted August 18, 2018 Report Share Posted August 18, 2018 This is a nice family forum, I suggest you join Thunderboat. ..................Dave 1 Link to comment Share on other sites More sharing options...
Boater Sam Posted August 18, 2018 Report Share Posted August 18, 2018 Straight answer is its a usual push on nipple which a common or garden grease gun will fit. As to grease, any automotive grease, using waterproof grease is usually a waste of time, regular greasing is required to drive any water out. A rubber flap over the bearing to keep the rain out is a good idea Link to comment Share on other sites More sharing options...
Alan de Enfield Posted August 18, 2018 Report Share Posted August 18, 2018 1 Link to comment Share on other sites More sharing options...
WotEver Posted August 18, 2018 Report Share Posted August 18, 2018 The late, lamented Farah Fawcett. Link to comment Share on other sites More sharing options...
OldGoat Posted August 18, 2018 Report Share Posted August 18, 2018 It used to be the perceived wisdom to use waterproof water resistant grease ( makes good sense if your stern gland is of the grease lubricated type - one grease for both jobs). I once used a 'moly' grease on mine and I was not overly impressed. Morriss' K99 comes in small tins at a reasonable price. Link to comment Share on other sites More sharing options...
eid Posted August 18, 2018 Author Report Share Posted August 18, 2018 Thank you all. I'm close to a Screwfix so I'll pop in and buy one tomorrow. I have a pot of grease for the stern so I'll use that. Link to comment Share on other sites More sharing options...
Dr Bob Posted August 18, 2018 Report Share Posted August 18, 2018 4 hours ago, Chewbacka said: I use the one I bought in the late 70’s for my Ford mk1 Escort, I use the same grease as I put in the stern tube greaser. I dont advise that. I would use fresh grease each time. 1 2 Link to comment Share on other sites More sharing options...
Rickent Posted August 18, 2018 Report Share Posted August 18, 2018 You can't beat a well greased nipple. Link to comment Share on other sites More sharing options...
MtB Posted August 19, 2018 Report Share Posted August 19, 2018 15 hours ago, eid said: On my tiller there is a grease nipple. Is there a particular type/size of grease gun I need for this, or are they a standard size? Thanks. As nobody has actually answered your question, grease nipples are all the same standard size so any gun will do. I dun well to avoid any inuendo there dint I..! . Link to comment Share on other sites More sharing options...
eid Posted August 19, 2018 Author Report Share Posted August 19, 2018 1 minute ago, Mike the Boilerman said: As nobody has actually answered your question, grease nipples are all the same standard size so any gun will do. I dun well to avoid any inuendo there dint I..! . Thank you ? Link to comment Share on other sites More sharing options...
Alan de Enfield Posted August 19, 2018 Report Share Posted August 19, 2018 46 minutes ago, Mike the Boilerman said: As nobody has actually answered your question, grease nipples are all the same standard size so any gun will do. I dun well to avoid any inuendo there dint I..! . Generally all the same size, BUT, there are 'big ones' and 'small ones' and metric sized and imperial sized. Generally for the run-of-the-mill applications you are correct for 99.9% (estimated) of the time Then there are : Concave head Nipples Slide-On Nipples Button Head Nipples Mushroom Head Nipples Slide on Nipples K-Type Nipples Bayonet Nipples "The Nipple Shop" has an interesting 76 page catalogue of nipples and accessories. 1 Link to comment Share on other sites More sharing options...
rusty69 Posted August 19, 2018 Report Share Posted August 19, 2018 1 minute ago, Alan de Enfield said: "The Nipple Shop" has an interesting 76 page catalogue of nipples and accessories. I'll nip over for a read! 1 Link to comment Share on other sites More sharing options...
Dr Bob Posted August 19, 2018 Report Share Posted August 19, 2018 1 minute ago, rusty69 said: I'll nip over for a read! No ogling page 3 please! 2 1 Link to comment Share on other sites More sharing options...
eid Posted August 19, 2018 Author Report Share Posted August 19, 2018 (edited) 1 hour ago, Mike the Boilerman said: As nobody has actually answered your question, grease nipples are all the same standard size so any gun will do. I dun well to avoid any inuendo there dint I..! . 53 minutes ago, Alan de Enfield said: Generally all the same size, BUT, there are 'big ones' and 'small ones' and metric sized and imperial sized. Generally for the run-of-the-mill applications you are correct for 99.9% (estimated) of the time Then there are : Concave head Nipples Slide-On Nipples Button Head Nipples Mushroom Head Nipples Slide on Nipples K-Type Nipples Bayonet Nipples "The Nipple Shop" has an interesting 76 page catalogue of nipples and accessories. I was about to buy a grease gun from Screwfix but in the Q&A it says they are for 14mm nipples. I assume this is the standard size. However, my nipple (below) is clearly not 14mm. Is this even a grease nipple? Maybe it's an oil nipple. Or something. Maybe my OP should have just read "what do I do with this thing?" The reason for all this is that when I use high revs to turn, water comes up through the tiller-tube and I noticed yesterday a metallic whine as I turned the tiller (sometimes). Edited August 19, 2018 by eid 1 Link to comment Share on other sites More sharing options...
rusty69 Posted August 19, 2018 Report Share Posted August 19, 2018 You can usually find really cheap grease guns at car boot sales etc Link to comment Share on other sites More sharing options...
MtB Posted August 19, 2018 Report Share Posted August 19, 2018 51 minutes ago, rusty69 said: I'll nip over for a read! When I was at skool, the name of one of my fellow pupils was Paul Nipp. Guess his nickname... what WERE his parents thinking of!!! 1 Link to comment Share on other sites More sharing options...
rusty69 Posted August 19, 2018 Report Share Posted August 19, 2018 4 minutes ago, Mike the Boilerman said: When I was at skool, the name of one of my fellow pupils was Paul Nipp. Guess his nickname... what WERE his parents thinking of!!! He had a sister you know. Catherine Nipp! 1 Link to comment Share on other sites More sharing options...
eid Posted August 19, 2018 Author Report Share Posted August 19, 2018 22 minutes ago, rusty69 said: You can usually find really cheap grease guns at car boot sales etc Yes I like the old brass ones. I was looking at them on ebay. 2 minutes ago, rusty69 said: He had a sister you know. Catherine Nipp! ? ? Link to comment Share on other sites More sharing options...
cereal tiller Posted August 19, 2018 Report Share Posted August 19, 2018 (edited) 36 minutes ago, rusty69 said: He had a sister you know. Catherine Nipp! What did they call his Father?in fact he had 2 Fathers , they were referred to as the "Pa's Nipp" Edited August 19, 2018 by cereal tiller 1 Link to comment Share on other sites More sharing options...
rusty69 Posted August 19, 2018 Report Share Posted August 19, 2018 (edited) 13 minutes ago, cereal tiller said: What did they call his Father? Biggus Nippus! Edited August 19, 2018 by rusty69 Link to comment Share on other sites More sharing options...
Boater Sam Posted August 19, 2018 Report Share Posted August 19, 2018 That is a standard push on nipple, just go to Halfords and buy a grease gun before the loonies on here whip themselves into a juvenile frenzy, it will be too messy. Link to comment Share on other sites More sharing options...
rusty69 Posted August 19, 2018 Report Share Posted August 19, 2018 Ok, I admit it.I'm a loony! You would have to be to want to own a floating skip and call it a boat Link to comment Share on other sites More sharing options...
eid Posted August 19, 2018 Author Report Share Posted August 19, 2018 (edited) 3 hours ago, Boater Sam said: That is a standard push on nipple, just go to Halfords and buy a grease gun... Too late, I went and bought the "14mm" one at ScrewUfix. It works great. 3 hours ago, Boater Sam said: ...before the loonies on here whip themselves into a juvenile frenzy, it will be too messy. too late... Thanks for the help. Edited August 19, 2018 by eid Link to comment Share on other sites More sharing options...
