Getting rid of chimney drip
I have been spending part of the afternoon cleaning off the tar which has dripped from the chimney cowl over the last winter and on to the roof.
The wife recommends wrapping a rag around it this winter to catch all the drips, but I was wondering if any of you had any ideas to reduce or get rid of chimney drip?
Thanks
Richard
Thanks
Richard
Buy a chimney from Alex moored at Enslow they are great and you will never have grunge again on yer boat. I have his tel number if u want to ring him. You will not get better. Stop changing yer forum name ?
Edited by mrsmelly
The wife just said 'I told you so' when I read your post to her. Looks like we're getting an Alex chimney! Does it not need a cowl then as that seems to be the issue!
With regards to changing me name. I lost details for old account ;)
Doesn't need one mate the design drops the grunge back into the stove. I will show you mine so you can see how it works. I will be around your way again in a week or so and ring you to arrange ?
Great. We're in Coventry at the moment in the basin. Will be back a week today.
Our only issue will be that our flue doesn't go straight into the stove top but via a tee joint on the back.
It will work ?
3 minutes ago, Gareth E said:
Hat or no hat, double skinned chimney, I still get this mess, and it's a bugger to get off.
We have a double skinned chimney. I have wrapped the inner chimney with exhaust wrap then sealed it with fire retardant foam. Never had any problem with tar stains. The inner sleeve should fit down inside the collar.
Edited by Ray T
Is your inner skin fitted inside the roof fitting with the outer skin on the outside? I have seen some chimneys fitted with both ouside thevfitting so the tar runs out onto the roof. I also agree with others that you should remove the Chinamans hat when the stove is lit because the lower edge of the hat is outsde the chimney, letting the tar drip onto the roof.
Howard
20 minutes ago, doratheexplorer said:
So I'm supposed to keep taking the hat on and off every time I light my stove?  Really?  Do people actually do this?
It's more for folks who aren't on their boats all the time.......or are finiskybabout their paintwork.?
For those that live on board all winter then the stoves never out anyway.
You can, of course, do whatever you wish but it does help to stop tar drips. When the stove is lit the updraft up the chimney stops rain going down it which is why most people fit the hats. I just take it off when lighting the stove, otherwise I leave it on.
Howard
I live on board.  There are times of year when I light my stove sometimes but not all the time.  Like when its a bit cold but not very cold.  In September I might have my stove lit 30% of the time.  In October 70%.  In November 90%.  Then all the time from the end of November to March it's on nearly all the time, except if I'm going away for a few days or I let my fire go out to clean the flue out.  So there's lots of times when my stove is going on and off.  Should I be taking my hat on and off too?
I think you are going to have to work it out for yourself.?
Howard
You can leave your hat on.
Edited by David Mack
Better to take the whole chimney off when the stove’s not lit and put a cap on.
