koukouvagia
BMC 1.8 Diesel leak into sump
After a recent oil change (15/40) I've covered about 60 hours.  The oil level in the sump has risen by about 1/2".  It's now showing just above max.   The engine is in otherwise good nick - it's has a top end rebuild, skimmed head etc.)
There is definitely a diesely smell on the dipstick where the top inch of the oil is less viscous.
Before calling in an engineer, I thought I ask for a few pointers as to what might be causing this.
Share this post
Check fuel lift pump diaphram first.
Share this post
Wow.  Consensus.  That'll  be the first thing to check then.  Thank you.
Share this post
Even more consensus - fuel lift pump highly likely!
Share this post
Its the only place it can come from unless the engine is so knacked that it won't run.
If you are lucky the lift pump will be the old type that you can get a repair kit for, the later ones are a chuck away job.
To get you running, open the pump and put a thickish piece of polythene on top of the diaphragm and reassemble, will work for months.
Share this post
No its not and many, if not all BMC lift pumps have a drain in the base of the pump so is any fuel leaking out of the base. Not a 100% test but a guide and the first thing to check. Since low sulphur diesel has been mandatory the older "rubber" seals that swelled with the sulphur as they wore so kept fuel tight have been slowly shrinking. This has lead to an increase number of injector pumps leaking fuel into their engine from the main injector pump shaft seal.
Share this post
Its possible Tony but I have never seen a master splined horizontal 1.8 leak into the chain case, they usually drip from the body on the very rare occasions that they leak at all.
Now 1.5 vertical pumps, that's another story.
Share this post
If you look at the picture on the ASAP supplies web-site, if accurate, they are now selling again the type that can be dismantled.
The good news is they aren't very expensive.
Linky
Share this post
I suspect its because the 1.8 is a newer engine so less time for wear to take place. A 1.5 could be 50 or more years old.
Share this post
I Had the same  problem a couple of years ago.  Various diagnoses were lift pump (replaced but didn’ cure the problem), worn injectors dripping (replaced - didn’t cure the problem) and then TB suggested the seal on the injector pump.  Pump was replaced and problem solved.  One word of warning though, if the problem isn’t sorted the diesel level can get to a point in the sump where it self ignites, the engine runs away and is virtually impossible to stop until it self disintegrates!  Drastic, I know, but apparently it can happen.
Share this post
If you ever suspect a lift pump diaphragm problem they can be tested fairly easily (that is apart from trying to put the pipe unions back in!).
1. Remove both pipes.
2. Turn engine into the position the priming lever gives maximum pumping throw.
3. Thumb over outlet port and   pump priming lever several times.
4. Stop & wait about 30 seconds.
5. Remove thumb and air trapped inside the pump should escape.
6. Carry out 3 to 5 above but this time you should hear air being sucked in.
7. Refit pipes.
If it fails the above tests it may be fouled valves rather than the diaphragm but you then know its time to take the pump off & try to strip it.
Share this post
7. Refit pipes.
Thanks, Tony.  I'll report back.  I've got a new lift pump on order, so I may as well fit that.
I note the comments about a failed seal on the injector pump.  I would think this unlikely since I had a new pump fairly recently.
Share this post
