Can we have a new rule
rasputin
3 minutes ago, WotEver said:
Wot about if it’s raining?
Or cloudy?
Or winter?
Yes fine for all those scenarios. Simple rule, if you have solar run your engine when you want
Edited by rasputin
33 minutes ago, Mike the Boilerman said:
YES.
I’m still staggered by the number of liveaboard around here with no solar who run  their engines for three hours on a warm and otherwise peaceful summer’s evening. Grrrr....
Why assume everyone is a liveaboard?
Although I must admit that the network is fast becoming a vast housing estate.
14 minutes ago, Mike the Boilerman said:
If the pulley ratio is big enough, yes definitely.
Sometimes you talk in tongues.
I worry about my ambition to spend a year or two exploring the system onc we retire. I don’t think ill understand enough.
Dont worry, I  will come and rescue you if necessary.
Probably ?
7 hours ago, rasputin said:
No running engines to charge batteries unless you have at least 200w of solar
Shouldn’t this rule read:
No running engines to charge batteries if you have over 200w of solar.
Visitor moorings should be divided into sunny areas for solar power boats, and shaded areas for engine runners. The latter could sit in the gloom running their generators in their own little ghetto.?
9 hours ago, Wanderer Vagabond said:
I run my engine to charge my batteries every day, just as an aside I move the boat as well, does that mean I'll have to stop doing that???
Ahhh now this is what you have totaly wrong. The ccing licence means you MUST spend 14 days in one place after moving 300 yards before moving on again 14 days later.
I agree.
In a a similar vein, few people understand speed limits on roads. A 30mph limit for example actually means you are supposed to try to drive everywhere at 30mph :P
Edited by Mike the Boilerman
Incorrect worm
