Jen-in-Wellies
Digital Instrument Panel
27 minutes ago, Chewbacka said:
I’m sure Jen will sort that with a few cable ties and some silicone.
Hot glue gun!  Then it’ll look like it’s made in China ;)
Share this post
I am already working on the instruction manual. Google Translate came up with this:
Jen-in-Wellies Dinghy Instructing Board
  • Maximum Quality Controlling with MPPT*.
  • Connect the panel with strongest grabbing.
  • Be assured not to press the button twice times as this may cause occurrence.
  • Clean with dampness. Roughness products never used.
Jen
Share this post
Jen
I think you should also include the instructions that used to come with Technics headphones: Excessive turning of the volume can be damage the earholes
Share this post
On 05/07/2018 at 13:54, cuthound said:
Nice job. Have a greenie. ?
Thank you!
The panel is now in and so far, working OK. Don't have a photo yet of it installed. For anyone interested in doing something similar, here are some of the design decisions and circuits used. As has been mentioned before in this thread, boats are electrically very noisy environments. Pumps, motors, relays, alternators, radios are all putting noise and voltage spikes in to the supposedly DC wiring. Delicate low voltage, low current electronics needs protecting against this if weird results, or device destruction is to be avoided. I stole some ideas from the early Bedazzled LED's I have on my boat and also from the Megasquirt project, which is an open source vehicle engine management system. These products have been designed for boat and the similar automotive environment.
There is a 22V metal oxide varistor on the 12V input into the 12V to 5V DC-DC convertor. This safely dumps any high voltage spikes, either negative or positive to earth. Protecting the 5V Arduino there is a 5V transient voltage suppressor on the output from the DC-DC convertor. There is another on the resistor voltage divider in to one of the analogue inputs used to measure boat voltage. There are capacitors on the digital and analogue input lines to filter out any high frequency signals induced in to the lines. Most resistors are standard 5% tolerance carbon film. The ones used for voltage divider resistor networks are 1% tolerance metal film type.
I've attached pictures of various input circuits below. Also below is the sketch for the Arduino Leonardo for anyone who is interested. Feel free to copy and modify to suit. All this stuff will almost certainly need altering to suit the senders on your boats engine.
Jen
/*A digital instrument set for boat Delta Lady.
  Written by Jen-in-Wellies, June-July 2018.
  Displays on a 20x4 character LCD using an I2C interface adaptor.
  Uses an Arduino Leonardo PLC as this doesn't use analog-in pins for the IC2 interface,
  like the Uno and gives six available for analogue inputs, instead of four.
  Displays RPM, water temperature, oil pressure, voltage and fuel level.
  Displays warnings when oil pressure is too low or high, water temp is too high,
  voltage is too low or high and fuel level is too low.
  Lights LED's and sounds buzzer for these warnings as appropriate.
  Automagic day/night LCD backlight illumination using Light Dependent Resistor (LDR).
#include <LiquidCrystal_I2C.h> //Library for liquid crystal displays driven by I2C two wire bus
#include <Wire.h> //Library for I2C 2 wire bus to drive the liquid crystal display.
#include <EEPROM.h> //Library so EEPROM can be used to store engine hours.
/* SDA to the I2C adaptor goes to SDA pin on the Leonardo and SCL to SCL pin
  These are also on pins D2 and D3, so don't use these for anything else.
  Similarly, pins D0 and D1 can't be used as they are also for serial data when debugging.*/
LiquidCrystal_I2C lcd(0x27, 20, 4); //Address 0x27, 20 characters by 4 rows.
//Define variables for analog inputs.
int tempIn = 0; //Temperature input from analog in. 0 to 1024.
int oilIn = 0; //Oil pressure input from analog in. 0 to 1024.
int voltIn = 0; //Voltage input from analog in. 0 to 1024.
int rpmIn = 0; //Engine rrpm input from analog in. 0 to 1024.
int dieselIn = 0; //Fuel level from analog in. 0 to 1024.
int ldrIn = 0; //Cabin ambient light level from analog in. 0 to 1024.
//Define variables for digital inputs.
int oilDin = 0; //Oil pressure switch input.
/*Calculated values to go to LCD.
  Floating point for required precision for calculation and display
  Except LDR, where it isn't important. */
float tempOut = 0; //Calculated water temperature.
float oilOut = 0; //Calculated oil pressure.
float voltOut = 0; //Calculated engine voltage.
float rpmOut = 0; //Calculated engine RPM.
float dieselOut = 0; //Calculated fuel level.
//int ldrOut = 0; //Output to LCD backlight.
byte hoursAddress = 0; //EEPROM address to store engine hours.
float engineHours; //engine hours stored in EEPROM hoursAddress
//Define time measurement variables for updating engine hours.
uint32_t ts1 = 0;
uint32_t ts2 = 0;
//Define analog input pins
int tempPin = A0; //input from coolant temperature sender.
int oilPin = A1; //input from oil pressure sender.
int voltPin = A2; //input from 12V system voltage divider.
int rpmPin = A3; //input from AC rpm sender bridge rectifer.
int dieselPin = A4; //input from fuel tank sender.
int ldrPin = A5; //input from light dependent resistor. Ambient light.
//Defining output digital pins.
int oilWarn = 4; //Oil pressure warning LED pin.
int tempWarn = 5; //Water temperature warning LED pin.
int voltWarn = 6; //voltage warning LED pin.
int dieselWarn = 7; //Low fuel warning LED pin.
int buzzwarnA = 8; //Warning buzzer output pin A.
int buzzwarnB = 9; //Warning buzzer outpin pin B.
//Define input digital pins.
int oilDpin = 10; //Input from oil pressure switch.
//Characters to display floating points to the required precision on the LCD
char engineHoursdisplay[15];
char rpmOutdisplay[15];
char tempOutdisplay[15];
char oilOutdisplay[15];
char voltOutdisplay[15];
char dieselOutdisplay[15];
//various constants
const int oilMin = 15; //Minimum oil pressure warning value PSI.
const int oilMax = 85; //Maximum oil pressure warning value PSI.
const int tempMax = 105; //Maximum coolant temperature warning value C.
const int voltMin = 12; //Minimum voltage warning value.
const int voltMax = 15.5; //Maximum voltage warning value.
const int dieselMin = 10; //Minimum fuel tank warning level value.
const int ldrThreshold = 400; //ldrIn value to switch backlight on/off. Higher is darker.
int buzzWarn = 0; //Sound buzzer when set to >0 (1).
//Equation values.
const float rpmM = 4.554; //m part of the y=mx+c linear equation for converting Analogue in to rpm displayed.
const float rpmC = 215.706; //c part of the y=mx+c linear equation for rpm.
//Voltage divider resistors units are 10^3ohms to minimise interger values and overflow risk.
//Dimensionless as divider ratio is (voltR1+voltR2)/voltR2.
//const int rpmR1 = 27; //kohms //Rpm voltage divider resistors.
//const int rpmR2 = 10; //kohms
const int voltR1 = 27; //kohms //Voltage sensing divider resistors.
const int voltR2 = 10; //kohms
const float tempB = 0.000786; //B multiplier parameter for temperature resistance curve.
const float tempR = 0.000942; //r offset parameter for temperature resistance curve.
float tempR2 = 0.0; //calculated resistance of temperature sender.
const float tempR1 = 220.0; //voltage divider resistor for temp sender.
const float oilM = -0.243; //M multiplier for oil pressure linear equation
const float oilC = 178.543; //C offset for oil pressure linear equation
float oilR2 = 0.0; //Calculated resistance of oil sender.
const float oilR1 = 100.0; //voltage divider resistor for oil sender.
const float dieselM = 1; //M multiplier for diesel level linear equation.
const float dieselC = 0; //C offset for diesel level linear equation.
float dieselR2 = 0.0; //Calculated resistance of diesel sender.
const float dieselR1 = 100.0; //Voltage divider resistance for diesel level oil sender.
void setup() {
  // put your setup code here, to run once:
  // Define digital outputs for warning LED's and buzzer.
  pinMode(oilWarn, OUTPUT);
  pinMode(tempWarn, OUTPUT);
  pinMode(voltWarn, OUTPUT);
  pinMode(dieselWarn, OUTPUT);
  pinMode(buzzwarnA, OUTPUT);
  pinMode(buzzwarnB, OUTPUT);
  //Define digital input pin for
  pinMode(oilDpin, INPUT); //External pullup resistor used.
  //Initialise warning LED's and Buzzer.
  digitalWrite(oilWarn, LOW); //lOW turns it off.
  digitalWrite(tempWarn, LOW);
  digitalWrite(voltWarn, LOW);
  digitalWrite(dieselWarn, LOW);
  digitalWrite(buzzwarnA, LOW);
  digitalWrite(buzzwarnB, LOW);
  // initialise the lcd
  lcd.init();
  //3 blinks of LCD backlight and LED's, except alternator warning which is 12V and seperate.
  for (int i = 0; i < 3; i++)
    lcd.backlight();
    digitalWrite(oilWarn, HIGH);
    digitalWrite(tempWarn, HIGH);
    digitalWrite(voltWarn, HIGH);
    digitalWrite(dieselWarn, HIGH);
    delay(250);
    lcd.noBacklight();
    delay(250);
  //Get current engine hours.
  EEPROM.get(hoursAddress, engineHours);
  //Initialise time counter for engine hour updating.
  uint32_t ts1 = millis();
  /*//Debug serial port monitoring. Comment out for production.
  //Must have laptop connected and serial monitor running if uncommented,
  //or the Arduino hangs at this point waiting for the serial port to connect.
  Serial.begin (115200);
  // Leonardo: wait for serial port to connect
  while (!Serial)
void loop() {
  // put your main code here, to run repeatedly:
  //Read analog sensors.
  tempIn = analogRead(tempPin);
  oilIn = analogRead(oilPin);
  voltIn = analogRead(voltPin);
  dieselIn = analogRead(dieselPin);
  rpmIn = analogRead(rpmPin);
  ldrIn = analogRead(ldrPin);
  //Read digital sensors
  oilDin = digitalRead(oilDpin);
  //Check engine hours count and update every 0.1 hour.
  uint32_t ts2 = millis();
  if (ts2 - ts1 >= 360000) {
    ts1 = ts2;
    EEPROM.put(hoursAddress, engineHours + 0.1);
    engineHours = engineHours + 0.1;
  //Calculations for engine voltage, oil pressure, water temperature, LDR and RPM.
  //Use *.0 for constants to force calculation in to floating point mode, except LDR where it doesn't matter.
  voltOut = voltIn * 5.0 * (voltR1 + voltR2) / (voltR2 * 1023.0); //Engine voltage calculation. Resistor based voltage divider.
  //Calculate oil sender resistance.
  //oilR2 = oilR1 * 1023 / (1023 - oilIn);
  oilOut = oilM * oilIn + oilC; //Oil pressure calculation.
  //Calculate temp sender resistance.
  tempR2 = tempR1 * 1023 / (1023 - tempIn);
  tempOut =  (1 / ((tempB * log10(tempR2)) + tempR)) - 273.0; //Temperature calculation.
  //Calculate fuel sender resistance.
  dieselR2 = dieselR1 * 1023 / (1023 - dieselIn);
  dieselOut = dieselIn * dieselM + dieselC; //Fuel level calculation. Awaiting calibration data.
  //RPM calculation. Linear equation.
  rpmOut = rpmM * rpmIn + rpmC;
  //Set LCD backlight according to the ambient light level detected by the LDR.
  if (ldrIn <= ldrThreshold) {
    lcd.backlight();
  else {
    lcd.noBacklight();
  //Convert floating point values to the required precision and put them in to strings to display on the LCD.
  dtostrf(engineHours, 5, 1, engineHoursdisplay);
  dtostrf(rpmOut, 4, 0, rpmOutdisplay);
  dtostrf(tempOut, 3, 0, tempOutdisplay);
  dtostrf(oilOut, 3, 0, oilOutdisplay);
  dtostrf(voltOut, 2, 1, voltOutdisplay);
  dtostrf(dieselOut, 3, 0, dieselOutdisplay);
  //Debug readout to serial monitor.
  /*Serial.print("oilDpin ");
  Serial.println(oilDpin);
  Serial.print("Engine Hours ");
  Serial.println(engineHoursdisplay);
  Serial.print("RPM In ");
  Serial.print(rpmIn);
  Serial.print(" Out ");
  Serial.print(rpmOut);
  Serial.print(" Display ");
  Serial.println(rpmOutdisplay);
  Serial.print("Temperature In ");
  Serial.print(tempIn);
  Serial.print(tempOut);
  Serial.println(tempOutdisplay);
  Serial.print("Oil Press In ");
  Serial.print(oilIn);
  Serial.print(oilOut);
  Serial.println(oilOutdisplay);
  Serial.print("Voltage In");
  Serial.print(voltIn);
  Serial.print(voltOut);
  Serial.println(voltOutdisplay);
  Serial.print("LDR In ");
  Serial.println(ldrIn);
  //Serial.print("OilIn ");
  //Serial.println(oilIn);
  //Serial.print("Oil R1 ");
  //Serial.println(oilR1);
  //Serial.print("Oil Sender Resistance OilR2 ");
  //Serial.println(oilR2);
  Serial.print("tempIn ");
  Serial.println(tempIn);
  Serial.print("tempR1 ");
  Serial.println(tempR1);
  Serial.print("Temp Sender Resistance tempR2 ");
  Serial.println(tempR2);
  delay(4000); //Delay so above can be read.*/
  //Display results on the LCD.
  lcd.clear();
  //Display RPM.
  lcd.setCursor(0, 0);
  lcd.print("Engine");
  lcd.setCursor(7, 0);
  if (rpmOut < 300) {
    lcd.print("0");
  } //Set display RPM to 0 if it is low to get round tolerance errors with a stopped engine.
  else {
    lcd.print(rpmOutdisplay);
  lcd.setCursor(11, 0);
  lcd.print("rpm");
  /*//Display fuel level.
    lcd.setCursor(16,0);
    lcd.print(dieselOutdisplay);
    lcd.setCursor(19,0);
    lcd.print("l");*/
  //Display water temperature.
  lcd.setCursor(0, 1);
  lcd.print("Water");
  lcd.setCursor(7, 1);
  lcd.print(tempOutdisplay);
  lcd.setCursor(11, 1);
  lcd.print("degC");
  //Display oil pressure.
  lcd.setCursor(0, 2);
  lcd.print("Oil");
  lcd.setCursor(7, 2);
  lcd.print(oilOutdisplay);
  lcd.setCursor(11, 2);
  lcd.print("PSI");
  //Display Voltage
  lcd.setCursor(0, 3);
  lcd.print(voltOutdisplay);
  lcd.setCursor(4, 3);
  lcd.print("V");
  //Display engine hours.
  lcd.setCursor(7, 3);
  lcd.print(engineHoursdisplay);
  lcd.setCursor(14, 3);
  lcd.print("Hrs");
  //Warning LED's, LCD display and buzzer for engine problems with voltage, oil, water, or diesel tank.
  //Voltage
  if (voltOut > voltMax) {
    lcd.print("*HIGH*");
    buzzWarn = 1; //sound buzzer
  else {
  if (voltOut < voltMin) {
    lcd.print("*LOW*");
    buzzWarn = 1;
  else {
  //Oil Pressure
  if ((oilOut > oilMax) && (rpmOut < 200)) {
    lcd.setCursor(14, 2);
  else {
  if (((oilOut < oilMin) || (oilDin = LOW)) && (rpmOut < 200)) {
    lcd.print("*LOW*");
  else {
  if ((oilOut > oilMax) && (rpmOut >= 200)) {
    buzzWarn = 1;
  else {
  if (((oilOut < oilMin) || (oilDin = LOW)) && (rpmOut >= 200)) {
    lcd.print("*LOW*");
    buzzWarn = 1;
  else {
  //Water temperature.
  if (tempOut > tempMax) {
    lcd.setCursor(14, 1);
    buzzWarn = 1;
  else {
  /*//Diesel fuel low level in the tank.
    if(dieselOut < dieselMin){
  //Either sound warning buzzer delay 1sec.
  if (buzzWarn > 0) {
    buzz();
  else {
    delay(1000); // update each second
  buzzWarn = 0;
//Warning Buzzer. Set up buzz function with 4kHz frequency for half sec, delay half sec.
void buzz() {
  long elapsed_time = 0;
  while (elapsed_time < 500000) {
    digitalWrite(buzzwarnA, HIGH);
    delayMicroseconds(125);
    digitalWrite(buzzwarnB, HIGH);
    elapsed_time += 250;
  delay(500);
  • Love 2
Share this post
14 minutes ago, system 4-50 said:
Would TI's LM2917 be of any use in this context?
Potentially yes. Particularly for the B output from many diesel engine alternators. Also if a crank hall effect, or inductive sensor were fitted. Good suggestion.
Share this post
If I may make a suggestion...
being on a boat it is likely that the veroboard will be exposed to moisture.
once you are 100% certain the board is working properly apply a coat of varnish (at least to the copper side)
while you will curse it if you ever have to make changes it will help prevent corrosion eating away the tracks.
Share this post
Conformal coating as it is known. Often an acrylic. I've used clear nail varnish in the past!😀
Jen
Share this post
Jen
I bought a can from Maplins as I don’t have any nail varnish myself
Some conformal coatings are designed to ‘solder through’ so a better choice than ‘standard’ varnish.
Share this post
You can get some when the can runs out. Maplins not being around any more. ,😁
Share this post
