And now the Birmingham New Line
pearley
1 hour ago, john6767 said:
Finally made it into Birmingham, slow all the way and the level is still well down in the centre.
Where is everybody though, no boats at all on the Arena side of the Main Line, only 3 boats on the other side, and 2 spaces on the Oozells St Loop.  Funny though that from Salvage Turn to Worcester Bar was completely full, don’t know why people pick to moor there, but I should not complain as it gave me the pick of the better places ?
Hang on John, I'll be there next week (levels permitting)!  I hope it's still equally easy to find a favoured billet.
17 minutes ago, mrsmelly said:
Think I will stick with my 2 foot draught boat :D
26 inch at the skeg o our boat, was still hitting the bottom on the N Stratford.
Will put some cones out for you ?
18 minutes ago, Hudds Lad said:
im intrigued as to how they always know its “vandals”
could it not just as easily be an inexperienced new boater or hirer whos had zero instruction?
What who smashed off the ani-vandal locks, the pawls, and the collar on one gate, as well as removing bolts from lock gates.  This was a targeted attack, a bit like the case where the lock beams were being sawn off on the Walsall flight last year.
fair enough, I've not seen that info anywhere, so vandals it is then.
52 minutes ago, john6767 said:
?What who smashed off the ani-vandal locks, the pawls, and the collar on one gate, as well as removing bolts from lock gates.  This was a targeted attack, a bit like the case where the lock beams were being sawn off on the Walsall flight last year.
Thats not nice.
Where does this information come from John?
That's cos we left this morning to give you some space.
Now at Tipton, water low all the way scraping over stuff in places. A group of badly secured Rothen work boars by Caggys floating out as you pass.
From Facebook the say the anti vandal locks were smashed off. Could be a hire boater who couldn't find his key.
1 hour ago, Victor Vectis said:
Thats not nice.
Express & Star article states
Over the past two and a half weeks a number of incidents have occurred, including 10 water conversion locks and five frog catches being broken.
2 hours ago, Graham Davis said:
I presume there are no longer ground water pumps from the area around The Old Custard Factory in Digbeth, into the canals?
 :offtopic:
Two humorous true stories follow...
Back in the late ‘70’s the Birmingham Hippodrome wished to enlarge the orchestra pit. The wizened old stage manager sat on his stool watching the workers, a skinny roll up between his nicotine stained fingers. “You’ll hit water” he mumbled.
“What?” They asked.
“You’ll hit water!”
Just at that point a huge geyser of mud and water flew into the air, hitting the ornate ceiling 40 ft above and splashing all over the safety curtain. The mud was still on the safety curtain until it was refurbished in the 80’s.
Nearly 30 years later the entire front of house of the theatre was demolished preparatory to building a brand new facade, public areas, performance areas and more. They had big machines driving in piles for the foundations. Suddenly... yup, a big geyser of mud and water shot into
the air. The construction was delayed for several months while the architects worked out why the adjacent road is called ‘Bridge Street’ and why ‘Watery Lane’ Is nearby...
Here is actually what was said by @CRT_Lee, the operations team leader for the BCN
Quote
Yes the same location, 10 con locks smashed off. 5 frog catches broke. 1 gate collar removed. Lock 6 weir wall give way due to the amount of water running down the flight. 100 metre stretch of towpath washed out. Numerous bolts taken out the gates.
2 hours ago, WotEver said:
 :offtopic:
“What?” They asked.
“You’ll hit water!”
When I was working in that area I remember the number of companies who couldn't use their cellars because the water table had risen so much after the Custard Factory had closed, and I can remember the sound of the pumps in one of the back streets underneath the railway.
I presume they are no longer running, then?
I have no idea I’m afraid.  I had a business in The Custard Factory about 16 years ago and never heard anything about wet cellars although there may well have been.
Birmngham used to have hundreds of businesses taking water via artesian wells.
I had several customers in the motor trade in that area, and a couple of them had wet cellars.
What is a water conversion lock?
I imagine a frog catch is the anti vandal lock.
4 hours ago, john6767 said:
Quote
Can everyone, especially CRT,  please stop attracting anyone other than boaters to the canals???!!!
The water conservation lock, is the anti-vandal lock.  My assumption was that frog catch was the pawl, but I guess I could be wrong.
Ah now that makes more sense.
But why would someone bent on causing maximum damage to the canal system break the pawls? Hardly a major inconvenience or cause of stoppages.
But maybe they are not that familiar with how canals work....
Don't try to work out why Mike - it's a bunch of morons, not Ocean's 11.  :banghead:
It appears that someone has gone to a lot of trouble to target all these components, the anti vandal locks make sense but breaking pawls, removing bolts and a collar sounds a bit more targeted - disgruntled boater, ex employee maybe?
