Matt0404
Hi does anyone know what this is please on my boat
2 minutes ago, mrsmelly said:
made in the good old US of A.
Well I used to drive a cab, you know.
Share this post
12 minutes ago, Matt0404 said:
Hi again sorry to be a complete newbie is this for the gearbox and is it normal hydrolic oil?
Seen in isolation its hard to say. Is the boat hydraulic drive or bowthruster for instance? where does the thing connect up to?
Share this post
I would say its for a hydraulic drive - no gearbox, just a hydraulic pump, valve & motor driving the prop. Plus an oil cooler, PRV and hoses.
Yes hydraulic oil probably but you need to check the manual or any labels. Hydraulic oil is NOT brake fluid or hydraulic jack fluid. Its what farmers use in hydraulic machinery.
I think that you will find a filter under the castellated thing on top.
Good point about a hydraulic bow thruster or hydraulic pumps or winches. It does look a bit small for a main drive reservoir to me but they seem to get smaller almost by the year.
I can see the feed, return and leak back hose from the motor hoses though.
Edited by Tony Brooks
Share this post
Follow the pipes and post photos of whatever it is they connect into for more info.
Did you get a survey before buying the boat? The survey report ought to tell you what sort of hydraulic stuff you have in the boat. Or ask the surveyor!
Share this post
Does it go down to something like the red unit at the back of the engine like this? It's the hydraulic drive pump.
Share this post
Yes and as its on the engine the boat is likely to have a hydraulic transmission.  There will be a hydraulic motor on the prop shaft and between the two a three position spool vale. (reverse - neutral - ahead).
Share this post
Today through the small round window you can see a flow indicator; it doesn't work any more because its pipes have been cut/disconnected.
Edited by Eeyore
Share this post
Probably designed by http://www.arsangliandiesels.co.uk/
I think you will find its a low oil level switch
Share this post
10 minutes ago, ditchcrawler said:
Maybe I should get my ARS book out
Is that the one you carry in your back pocket?
Share this post
Only when I expect a canning
Share this post
Hi , Can you tell me if you are all sorted with the concerns of your hydraulic system in your boat ?
Its a small compact unit but straight forward enough.
Share this post
