Timx
Anyone know what this is ?
Hi, I found this on boat , alongside mooring pins etc, I don't know if it's anything boaty ! Can anyone tell me what it is , if anything ?
Share this post
It is a piling hook for mooring to piling, and alternative to the more common “nappy pin” type.
Share this post
And a complete waste of space. Bin it.
Share this post
Ha, OK , makes sense now you say that, I will have to try it.
Share this post
But don't depend on it. As Tim says, they're useless.
Share this post
Use it for dredging shopping trolleys, and if it comes off your rope and its lost, you are lucky.
Share this post
Ha thanks for answers, I will remember your advice as well.
Share this post
We have used them in the past with no problems, I prefer them to the 'nappy pin'
We use goat chains instead these days
Richard
Share this post
Richard
Me too, had  nappy pins pulled out, never one f those.
Share this post
Four of them would make a handsome matched set of earings and cufflinks.
Share this post
4 minutes ago, JamesFrance said:
My boat came with these which look even more useless, anyone know what they are for?
Mooring spikes. Perhaps the loop is to help pull them out
Richard
Share this post
Richard
But surely hammering them in would cause the top to bend round on itself?
Share this post
Richard
The loop is to prevent the rope sliding off the top when the spike leans over, but you are correct, it does give you something to pull on when you want them out.
Share this post
They are not completely useless. We have three we keep as backup to Safety pins and goat chains. And Stakes/Pins.
Just in case you understand.
Share this post
Richard
Chains for me every time.
Share this post
I didn't say they were good mooring spikes...
Share this post
I have had boats come loose with both nappy pins and those piling hooks in the OP, so neither design can be trusted. Also, they make a loud clanking noise each time a boat passes and the tension on the bow and stern mooring lines reverses.
I think it should not be beyond the wit of man to design a mooring device to securely engage on the horizontal rail on piled banks. I can do it though, despite many hours of idle musing on how.
Share this post
Also if your single handed they come in useful for quickly mooring until you get your chains on.
Share this post
Big U clamps and chains. :D Or a chain and a Carabiner.
See the source image
Edited by Ray T
Share this post
51 minutes ago, JamesFrance said:
They are well under a foot long and proper spikes were also supplied new with the boat.
You could use them to through the hole of your main pins at a 90° angle.  This will help your main pins from coming loose with the boat movement.
Edited by Robbo
Share this post
Well goat chins do the job perfectly well and very securely.
I meant something as quick and easy to drop into the armco like a nappy pin, but actually and genuinely secure.
Share this post
Something Like...
https://www.uktoolcentre.co.uk/products/faithfull-deep-throat-g-clamp-200mm-8in-cap-85mm-3in.html
Basically drop over the Armco and then tighten up to secure
Edited by Robbo
Share this post
