Mac Mackenzie Posted June 4, 2018 Report Share Posted June 4, 2018 I would be interested in what experiences and recommendations people have with shower drain pumps I'm trying to decided whether to go for either a Rule or Attwood waste water sump box with integral bilge pump and float switch or a Whale Gulper pump with remote switch My preference would be the sump box rather than having to switch a pump on and off Just how reliable are the sump box systems? Link to comment Share on other sites More sharing options...
nicknorman Posted June 4, 2018 Report Share Posted June 4, 2018 Very unreliable, don’t do it! Whale gulper every time! We had a sump box on our new build. Despite me cleaning it out a few times (and what a yucky job that is) the inevitable happened and the pump failed to run, the box filled up and overflowed into the bilges. One showerful of dirty soapy water in the bilges, not nice. We then went for a whale gulper which has been perfect and requires no cleaning out etc. I did install flow switches on the shower water feed pipes so the pump runs automatically as soon as the shower is turned on, but it also needed a timer circuit to keep the pump running for 20 secs or so after the shower was turned off, to get rid of the drips etc Link to comment Share on other sites More sharing options...
Alan de Enfield Posted June 4, 2018 Report Share Posted June 4, 2018 Go Gulper (fit and forget) Go Sump-Box and learn to live with your head in the bilges cleaning the filter after every shower - not pleasant. If switching on and off it too complicated, you can get a vacuum switch (commonly) used for 'outside lights' where you just give it a 'push' and it works on a timer (that you set) and switches off after a minute up to 20 minutes. 1 Link to comment Share on other sites More sharing options...
Mac Mackenzie Posted June 4, 2018 Author Report Share Posted June 4, 2018 Thanks for your response. I was also considering the Whale grey water 8 lt tank with water sensor fitted in lid to activate a Gulper pump. Where did you get your flow switches and also the timer circuit you mentioned? Here's the Whale grey water tank https://www.ebay.co.uk/itm/8lt-Whale-Multi-port-Grey-Waste-Water-Storage-Tank-Boats-Caravans-Motorhomes/362100868840?epid=26009272235&hash=item544ee4c6e8:g:sZoAAOSwRH5XKdxS Link to comment Share on other sites More sharing options...
Alan de Enfield Posted June 4, 2018 Report Share Posted June 4, 2018 1 minute ago, Mac Mackenzie said: Thanks for your response. I was also considering the Whale grey water 8 lt tank with water sensor fitted in lid to activate a Gulper pump. Where did you get your flow switches and also the timer circuit you mentioned? Why mess about making up timer circuits when its already done for you with one of these Link to comment Share on other sites More sharing options...
Mac Mackenzie Posted June 4, 2018 Author Report Share Posted June 4, 2018 Yes that's a possible solution to get the pump to run on - thanks Link to comment Share on other sites More sharing options...
nicknorman Posted June 4, 2018 Report Share Posted June 4, 2018 25 minutes ago, Mac Mackenzie said: Thanks for your response. I was also considering the Whale grey water 8 lt tank with water sensor fitted in lid to activate a Gulper pump. Where did you get your flow switches and also the timer circuit you mentioned? Here's the Whale grey water tank https://www.ebay.co.uk/itm/8lt-Whale-Multi-port-Grey-Waste-Water-Storage-Tank-Boats-Caravans-Motorhomes/362100868840?epid=26009272235&hash=item544ee4c6e8:g:sZoAAOSwRH5XKdxS Flow sensors from here: https://www.rapidonline.com/measurement-specialities-fs-10-meas-copper-bodied-flow-switch-61-1358 But the switches aren’t rated sufficiently to operate the pump directly, you would need some electronics or a relay to operate the pump from it. I just used our Empirbus DC distribution system to control it, if you wanted to do it with a run on timer you would need some electronics expertise. Link to comment Share on other sites More sharing options...
BruceinSanity Posted June 5, 2018 Report Share Posted June 5, 2018 KISS! We have a Gulper with a waterproof rocker switch in the shower compartment. This means that the pump can be switched on and off as you shower – you can delay switching on to get a bit of water build up to soak your feet, for example. If turning a switch on is too much effort, words fail me. 2 Link to comment Share on other sites More sharing options...
LEO Posted June 5, 2018 Report Share Posted June 5, 2018 8 minutes ago, BruceinSanity said: KISS! We have a Gulper with a waterproof rocker switch in the shower compartment. This means that the pump can be switched on and off as you shower – you can delay switching on to get a bit of water build up to soak your feet, for example. If turning a switch on is too much effort, words fail me. Wise words, Whale Gulper every time. Link to comment Share on other sites More sharing options...
CV32 Posted June 5, 2018 Report Share Posted June 5, 2018 Whale gulper for us too - it washes the boat next to us nicely Link to comment Share on other sites More sharing options...
nicknorman Posted June 5, 2018 Report Share Posted June 5, 2018 1 hour ago, BruceinSanity said: KISS! We have a Gulper with a waterproof rocker switch in the shower compartment. This means that the pump can be switched on and off as you shower – you can delay switching on to get a bit of water build up to soak your feet, for example. If turning a switch on is too much effort, words fail me. Turning a switch isn’t too much effort, but if you dont have to do it, why do it? Especially when we have Jeff’s elderly parents staying from time to time, simple things like turning switch on and off to drain the shower is something they’re not used to and would struggle. Link to comment Share on other sites More sharing options...
Rob-M Posted June 5, 2018 Report Share Posted June 5, 2018 We replaced a sump box and pump with a whale gulper, we have a switch near the shower door so you turn on the shower, wait for the temperature of the water to settle, turn the pump on and get in the shower. Job done and no more worrying about daughters with long hair using the shower and blocking the pump. Link to comment Share on other sites More sharing options...
nicknorman Posted June 5, 2018 Report Share Posted June 5, 2018 7 minutes ago, Rob-M said: We replaced a sump box and pump with a whale gulper, we have a switch near the shower door so you turn on the shower, wait for the temperature of the water to settle, turn the pump on and get in the shower. Job done and no more worrying about daughters with long hair using the shower and blocking the pump. If my daughter had long hair I’d be very worried. Not about the hair, about the daughter! Link to comment Share on other sites More sharing options...
Momac Posted June 5, 2018 Report Share Posted June 5, 2018 By coincidence I fitted a new float switch to my Attwood shower sump last weekend. I had the same arrangement in my previous boat. That is the first shower sump expense I have had in 10 years of boating = £31 for the switch. I would say an annual clean out of the sump box is a prudent action for light user. No doubt the whale gulper is the better solution. Link to comment Share on other sites More sharing options...
Alan de Enfield Posted June 5, 2018 Report Share Posted June 5, 2018 5 minutes ago, nicknorman said: If my daughter had long hair I’d be very worried. Not about the hair, about the daughter! You should be OK if you put a 'mesh' over the plug hole - even a Whale gulper would have problems sucking a daughter thru 1/2" mesh. 1 Link to comment Share on other sites More sharing options...
system 4-50 Posted June 5, 2018 Report Share Posted June 5, 2018 Gulper works for me. Make sure the gulper switch is easily accessible from within the shower. Link to comment Share on other sites More sharing options...
MoominPapa Posted June 5, 2018 Report Share Posted June 5, 2018 Another vote for a Gulper. Ours is controlled by a waterproof switch within the shower cubicle which also controls the lights therein. MP. Link to comment Share on other sites More sharing options...
rgreg Posted June 5, 2018 Report Share Posted June 5, 2018 5 minutes ago, MoominPapa said: Another vote for a Gulper. Ours is controlled by a waterproof switch within the shower cubicle which also controls the lights therein. MP. I'll join the Gulper Admiration Society. I recently swapped out a standard in-line water pump (lots of cleaning required) for the Gulper and it is excellent. It is operated by a switch just outside the shower. Link to comment Share on other sites More sharing options...
Drayke Posted June 5, 2018 Report Share Posted June 5, 2018 Gulper for us as well operated via pull cord switch. Link to comment Share on other sites More sharing options...
dor Posted June 5, 2018 Report Share Posted June 5, 2018 Gulper for me. My last boat had a rubber vane type jabsco which was a real pain; either the filter blocked or the vanes broke. No contest fitting a gulper on my present boat, with a switch on the side of the bath. It's a sit-bath so leave the switch off while having a navy shower. Very economical on water (my water tank is not very big) and just switch it on when I get out. Link to comment Share on other sites More sharing options...
Ex Brummie Posted June 6, 2018 Report Share Posted June 6, 2018 I made a version of the sump box, with a length of 4" soil pipe, capped off at the bottom, with a hose adapter screwed into the pipe at low level. This sits vertically so that the open top is higher than the shower/bath, and a small submersible pump is dropped into it. The outlet is pumped to the basin waste. All controlled with a switch mounted in the bath panel. A periodic withdrawal of the pump enables cleaning, and the basin waste gives a visual ( and audible ) monitor of working. 1 Link to comment Share on other sites More sharing options...
Mac Mackenzie Posted June 9, 2018 Author Report Share Posted June 9, 2018 (edited) Thank you everybody for your contributions. I can see that the waste box with float switch is going to need ongoing maintenance so I will probably go with the diaphragm pump for greater reliability . The only thing which puts me off the Whale Gulper is the noise it makes. I'm looking at the Johnson Viking pump which is supposed to be much quieter. Has anyone had any experience of this model pump? http://www.spxflow.com/en/johnson-pump-marine/pd-marine-lavatory-systems-viking-power-16/ Edited June 9, 2018 by Mac Mackenzie Link to comment Share on other sites More sharing options...
WotEver Posted June 9, 2018 Report Share Posted June 9, 2018 The whale is only on while you’re showering, which isn’t a silent operation itself... Link to comment Share on other sites More sharing options...
Chewbacka Posted June 9, 2018 Report Share Posted June 9, 2018 (edited) If it was very quiet you would probably forget to turn it off Edited June 9, 2018 by Chewbacka 1 Link to comment Share on other sites More sharing options...
Boater Sam Posted June 9, 2018 Report Share Posted June 9, 2018 Whale gulper is the dogs tackle. Having said that we have had an old Jabsco impeller pump in ever since we bought the boat and it has never blocked. Got 2 unused spare impellers. Operated by an air switch in the shower, totally waterproof. Link to comment Share on other sites More sharing options...
