cuthound
March of the Widebeams
1 hour ago, Captain Pegg said:
For the maximum published beam it is at the maximum published draught, at the maximum published headroom, and at all points in between.
JP
I actually meant 'where on the boat'.
As the example given is 12' at the waterline and 14' at the Gunwale - in many cases the gunwale could be at the height of the coping stones of a bridge hole etc.
Share this post
Over it’s entire height (and depth)
Edited by Captain Pegg
Share this post
That would appear sensible - so - why did the owner of this 14 foot beam boat expect C&RT to widen the bridges for him ?
I wonder what beam he claims on the licence application form ?
Share this post
Did he expect that? I don’t know and I don’t think it’s the relevant point. The navigation authority identified a failure to maintain the canal to the required dimensions and put it right. That’s what should happen. This wasn’t the only, or the first, boat to be restricted by this particular bridge.
If this boat is 14’ wide at the gunwale then it navigates at the owners risk and should it get stuck on a piece of infrastructure that complies with the minimum craft dimensions then there will be no obligation on the part of CRT to take action and I very much doubt that they would.
JP
Share this post
JP
So why the big difference in CRT's response to the chap whose boat used to fit through the recently repaired lock on the K&A, but now doesn't?
Share this post
Perhaps he was a bit of a dick about it but this guy hasn't been.
How you approach a situation can have a big effect on the response you get to that situation.
Share this post
He seems pretty sensible and level headed in his posts about it on here, so I disagree with your hypothesis that he is a bit of a dick.
In fact the owner of the Stockton monster is reported to have been 'upset' about posts on here about his, but declined to post and put the record straight. Who looks the more of a dick to you?
Edited by Mike the Boilerman
Add a bit
Share this post
I think scale and geography and how that results in differing behaviours from CRT.
Rather than thinking of CRT as a single entity who present a joined up position think of it as a number of individuals arranged into specific functional teams within a number of regional structures. Depending on which team you are dealing with in which region you will get a different perspective, a different set of motivations and a different set of priorities. I’m not saying that’s how it should be but it’s a reality of an organisation like CRT and it isn’t an entirely negative thing.
The immediate problem at Itchington was one solvable by maintenance work, so within CRTs structure it will have available budget, available resource and local management empowered to deploy those. The asset management function was probably in the lead and calling the shots and well informed about the state of the infrastructure. The local lead asset manager concerned will also be well aware of the legal framework in which CRT operates. Hence they chose to sort it, good on them.
On the K&A the work was part of the winter stoppage programme so probably delivered through a process that was far removed from the above and involved a remit from the asset team to a project management team, a specific budget authority for the remitted outputs and no more, a planned stoppage and then the letting of the contract to deliver the work. So something of a chain through which knowledge, detail and ownership can get lost. One of the disadvantages of contracting out work. So immediately following the work there’s probably not a great deal of knowledge in the day to day CRT operation on the K&A about the current state of the asset. Then a boat gets stuck and it’s likely the local Operations & Customer Services team get involved. Without the local knowledge that applied at Itchington or the need to know the legal requirements in general they make a false assumption - aided by the published craft dimensions - that the boat is too wide for the infrastructure. A statement which frankly should have been subsequently corrected. It will now need another remit, another authority, another stoppage and another contract to sort it long term.
JP
Share this post
OK a very hypothetical one, I know it wont happen
So just suppose they rebuild the A45 bridge on the North Oxford to 9 foot width, considering the dimensions of the canal are quoted as 7ft 6in by 71 feet. Do you think it should be knocked down to let the wide beames out because they use to be able to pass through it.
Share this post
One doesn't belong to the right lodge??
Share this post
22 hours ago, Loddon said:
Indeed but wasn't she responsible for making that happen. It certainly came about when she was on the local council/mayor, wasn't there before that, and no one had heard it before then.
Oh, I guess you missed my irony re media, social and trad . . .
Share this post
I'd argue that I wasn't a bit of a dick. Not that they comment on here but I know a few of the local CRT staff personally and I'm sure they would say I was calm and polite throughout. I think it may be down to a difference in scenario's. In my case, if I wasn't at fault then it would mean that the recent repair work was - the chief engineer that visited site was primarily concerned with making sure that was not the outcome (Despite my boat, and others of the same beam always having previously fitted through the same lock). In the more recent scenario on the GU, this wasn't a consideration - no one from CRT needed to defend themselves. I can see why the owner of this boat was a bit pissed off about all the derogitory comments about the situation, lots of keyboard warriors about talking crap based on hearsay and very few of the facts.
  • Greenie 4
Share this post
Sitting here on the Trent and Mersey canal there is a wide lock at Middlewich but wide boats can't reach it because there is a narrow aqueduct about half a mile below it. I think this is probably the third aqueduct on that site and the first one was a wide one, Should CRT be looking to replace it so once again wide boats can get to Middlewich.
Edited by ditchcrawler
Not telling
Share this post
I have never managed to find an irony emoticon ;)
Edited by Loddon
Share this post
Yes!, for the sake of historic correctness the aqueduct should be replaced with a wide one, and at the same time all those wide locks on Hatton flight need to be demolished and the old narrow locks re-instated. :)
...............Dave
Share this post
...............Dave
That get’s my vote. 😀
Share this post
...............Dave
Can we un-sraighten the Northern Oxford please and don't forget the locks up to Calcutt from Warwick. Oh, re-tunnel Fenny Compton too.
Cheers Graham
Share this post
...............Dave
That's the BCN new mainline stuffed then!
Edited by TheBiscuits
Punctuation
Share this post
NOOOOOOO!!!!!! What about the amazing glow worm population along there??? They would all have to be re-housed!!
Share this post
Good points. We can solve the ‘problem’ of widebeams on ‘unsuitable’ canals by rewinding to before our canal network was even built. 😂
Obviously I’m not serious about the GU Birmingham line but I do hold the narrow canal would have been a nicer waterway than the widened version.
It all goes to show that history isn’t a good way of defining the future and that a formal line has to be drawn in the sand somewhere. That line is the current legal position and must be the starting point for any discussion on usage. Preservation of the dimensions of wide beam waterways is an important precedent in ensuring that the narrow beam network is never confined to 6’ 10”. I wonder if those who operate - or support the operation of - narrow craft in excess of 6’ 10” but argue against widebeams where they are within limits fail to recognise the issue or whether they just don’t believe it will happen?
The precedent at Itchington is the same one as ensures the Llangollen will become passable again to 7’ 0.5” craft. Of course if we applied history as per the posts above that facility wouldn’t be afforded on the Llangollen.
I contend that we should be supporting all boaters who operate within legal requirements, be encouraging CRT to regulate passage of atypical craft such that it is reasonable to other users, to restrict passage that flagrantly breaches the limits, while at the same time pushing them to demonstrate a transparent strategy of opening out pinch points to utilise the general dimensions of the as-built channel, locks and major structures. Individual bridges should not be a barrier to wider capability in the long term.
JP
Share this post
Cheers Graham
While we are at Napton area can we have this bridge back please?
Plus these gates and paddle gear.
Edited by Ray T
Share this post
Where was the bridge?
Cheers Graham
Share this post
Cheers Graham
Between the Wigram's 3, to give them their "proper" name and Napton Junction.
Edited by Ray T
Share this post
Thanks, I wondered if it was that one. I have crashed into the remains of the bridge on the towpath side in a minor moment of less that ideal attention.
Cheers Graham
Share this post
Anyhow, Stowe Hill was disrupted on Saturday by the arrival of recently discussed behemoth.
If the owner doesn't like being talked about then it's about time he got the boat lifted and dropped in the Thames off a lorry.
Coming under the A5 bridge the boat got wedged across the cut, much noise,  bowthruster action and sprayed silt later, it broke down due to overheating.
Eventually resuming , it appears navigation is achieved by forward motion corrected with constant use of said bowthruster. The canal looked like mulligatawney soup......obviously the fault of CRT due to lack of dredging.
The boat hit the narrowboat in front of me on his end of garden mooring, and then the owner used his shaft to push the boat away from Old Friends.
He did get some advice...." Get it lifted out, you give us wide beam owners a bad name"....from a wide beam owner.
Expect it at Blisworth tunnel for passage Monday morning.
Edited by matty40s
  • Love 1
  • Horror 6
Share this post
