March of the Widebeams
cuthound
Just now, furnessvale said:
No wonder it brought Halsey to tears of laughter.  We all know the "policy" but is it being carried out?
George
C&RT have claimed it is - they published examples of a marina opening (one I think was Pillings Lock) and listed all of the on-line moorings 'closed'.
The 'closed moorings' are not necessarily particularly close to the marina, again, from memory, some of them were around Beeston.
Like you, I believe all of CRT's claims.
George
George
Along with the tooth fairy, the Easter Bunny and Father Christmas.
I am not a supporter of C&RT as I think my posting record would show - however when they post lists of moorings they have 'removed' and some forumites make comments about them being no longer available I do try to believe it.
It was some years ago so I maybe have a 'fuzzy' recall.
It's a good job I have banned my great grandchildren from access to this forum or I would have some serious explaining to do!?
George
  • 4 months later...
We are at Crick.
Widebeams dominate the show, which appears quieter than of latter years.
Fair warning for those on the North Oxford, twixt Braunston and Dunchurch pools after show week. Apparently, a humongous Dutch barge is being craned in at Braunston, then travelling to Dunchurch. This really is a big beast. I will try to get a photo later...
15 hours ago, johnmck said:
We are at Crick.
I'm heading that way before too long.  If I meet him coming the other way, he'd better be prepared to go through the trees because I won't be doing!
George
I'd pay good money to watch that.
Just the bit from Midland Chandlers (calling them swindlers is getting old hat now) to after the A 45 bridge would do me.
There are enough boats moored either side and overhanging vegetation to endanger tempers and necessitate a repaint.
If we don't know exactly when this joyful occurrence will be enacted I guess we'll probably be able to catch up with it on Google Earth.  That part of The Grand Oxford is probably caught in one Passover.
I've never actually met a widebeam on the move on any narrow canal but I know they must do because of where they moor.
If I ever do, my plan is simply to tie up on the towpath for tiffin until he has passed.
George
George
Why so aggressive?
Edited by blackrose
31 minutes ago, blackrose said:
Why so aggressive?
Because widebeams are appearing on totally unsuitable waterways like the northern oxford. It’s high time CRT stopped pussyfooting around and banned the marinas in such locations from accepting widebeams.
I don't see how C&RT can do that.
Those are 'private' waters / businesses and C&RT have no control over who they rent moorings to.
I suppose a comparison would be the DVLA telling my local garage not to sell fuel to 4WD owners.
C&RT COULD refuse to licence boats who declare their home mooring to be on 'unsuitable' canals, but then they would have to amend the T&C's of the access agreement that demands the marina only accepts licensed boats.
The answer is much simpler than that.  Simply stank off the marina entrances to 8ft wide and stank of the first road bridge from Braunston down the Oxford similarly.
George
Not quite that simple - That would make it impossible for many long narrowminded boats to exit the marina - few canals are wide enough to let them 'out' and then turn, it generally needs a funnel shaped (or wide) entrance / exit to allow them to be able to start turning before they hit the opposite bank.
6 hours ago, blackrose said:
Why so aggressive?
People with wide boats are taking them up the North Oxford to Dunchurch Pools Marina.
The North Oxford is a "narrow" canal, never designed for wide boats, or two breasted up narrow boats for that matter.
(If one is being pedantic the Oxford canal was designed for horse drawn boats.)
Because these boats are out of gauge some of the infrastructure has been damaged in the past.
I am not a wide beam hater, correct boats for the size of canal.
Edited by Ray T
Every (new) marina I have seen has a "V" shaped entrance with stop planks at the narrows.  I am suggesting those narrows should be 8ft, not the 12-14ft they seem to have.  Plenty of room for a narrowboat to turn using the "V".
George
How many of these widebeams actually go anywhere, once that are in their chosen 'Bungalow Park' ?
Agree with the bridges being narrowed, but why 8 Foot?  Narrowboats are 7 foot.  As I said to someone - "You've got seven foot, what more do you want?"
Its being cranned in on 5th June
3 minutes ago, frangar said:
Narrowboats on wider waters tend not to remove lumps from bridges or make life tricky for others navigating because they are blocking the channel.
They can wear the mitre of broad lock gates going in with only one open, leading to more water loss, if they are not accurate with their steering. They can do this to narrow locks too of course, forcing the boat in to open mitre gates.
Jen with a NB on a WB canal.
Agreed re broad locks.  However, on a narrow lock the bows of a narrowboat will catch the steel protector plates on the gates and push them open before any contact is made with the mitre faces.
George
