roggie
GoWindlass
12 hours ago, haggis said:
yes, I saw that suggestion earlier and have seen it done. Must acquire a belt :-)
haggis
Or cradle it over your shoulder. Plus use of belt.
Edited by Ray T
Share this post
If you're going to get one, do it before this company, like several predecessors, disappears since the sheer cost means they don't get sufficient sales to be able to continue.
They seem like a good idea, but the eye watering cost is enough to make me shy away. I'll wait for the rechargeable electric version (with light for night use).
Share this post
'Ordinary' windlasses are £20-£30 (https://www.midlandchandlers.co.uk/search.aspx?q=Windlass) so the £80 isn't that 'eye watering' given the advantages it offers those who struggle with some locking mechanisms. Like lots of boats things it's worth paying good money if it makes your journey appreciably better, and it's not a often purchased item. Of course how long it
lasts is still to be determined but it does seem to be manufactured in quality material.
Share this post
To be fair, if it is any good the "Go Windlass" is perhaps half the price of some ratchet windlasses offered in the past.
If it works, and doesn't break, I don't think it is particularly expensive for what it is.
Not having seen one in the flesh, I should perhaps not express doubts, but it looks rather short on metal around the non ratcheting eye to me, and perhaps a bit under-engineered overall.  That said people who exert huge forces on windlasses are unlikely to be using one, and they are likely to only usually used by those who struggle to use an ordinary one.
Edited by alan_fincher
Share this post
And of course more metal would increase the weight. The fixed eye is intended for winding down, so shouldn't normally experience major stresses. Being a very short throw, it makes dropping the paddle very quick, too. My main concern is the ratchet itself, but time will tell. IME, cheap socket set ratchets are prone to jam after a while, presumably as a result of wear of the pawl.
Share this post
Yes, but when you are using the ratchet eye, all the forces associated with doing so are still being passed through the two sides of the fixed eye.
Actually looking at it again, given it relies heavily on castings, quite a bit of it doesn't look that robust to me.
Share this post
True, o King. Time will tell!
Share this post
It lasts until you leave it behind at a lock.
I am GREAT at this and they vanish even if you return 15 minutes later. I buy them in bulk on ebay, usually for about a tenner or 15 squids each.
Share this post
I just get mine from boaters who leave them behind at locks :)
Share this post
That's a fair point, however in the 2 months we've been using it (virtually every day) the wife has had so many people admiring it, asking about it, and saying they must get one. Whether many of them will do so of course is another matter but if a fair few do then that would auger well well for the future of the company that makes/sells them.
And if they make and sell a lot of them the cost of production might come down and probably the price as a result.
A few of the husbands have said something along the lines of 'well that's sorted her birthday present then'. I reckon husbands/partners are going to agree to purchasing one rather than seeing their partners struggle.
Share this post
I just tell her that if she loses it she won't be getting another one. That seems to work (so far).
Incidentally, I keep meaning to test if my sea magnet is strong enough to lift it. I think it is.
Share this post
139 posts... what did I start? Time will tell as to how robust it is, hopefully it should last a few years, if not more and if it does have a weakness someone will come up with something better, how about a titanium windlass.... I guess there must be a price ceiling and perhaps its £80 which covers postage. I wonder how many locks the 'average' boater goes through and so the benefit for those who operate the locks - I've not done any locks on the Huddersfield/Rochdale and have been told that these are stiffer so a cost benefit might be higher on these locks rather than the relatively well maintained ones on the southern GU. Let's revisit the thread in a year(s) time as to the effectiveness of the racket mechanism.
Share this post
I've notr done the Huddersfield, but would suggest some selected paddles on the Southern GU are at least as bad as most on the Rochdale.
I don't struggle with many paddles (although I find them harder than in my youth), but for example those on Buckby Bottom lock, bottom gates are particularly appalling now.
Stoke Bruerne, which used to be an easy flight now has some pretty bad paddles as well.
The solution would be for CRT to make them work as they should, so anybody of reasonable strength can wind them up by continuous rotation.  It shouldn't be necessary for people to have to buy some device that was never envisaged as necessary when the mechanisms were designed.
One of the issues may well be that wooden paddles have largely been replaced by plastic ones, some of which distort under the head of water, and hence need more force to drag over the openings in the gates.
Share this post
Having bought ours at the Crick show in May before heading south, my wife has used it on the Southern GU, the Paddington Arm, the Regents Canal, and now on the South Oxford. Like with all canals the stiffness of the paddle gear has varied but there have been plenty where she'd have really struggled with a normal windlass.
She had major heart surgery just over a year ago and her ribs are still a bit delicate so although she loves working the locks she wasn't able to do any until she got this. She hasn't worked them all on this trip but it has meant we can now share the task once again like we used to.
Share this post
But given current management style, the more likely solution will be erection of a large blue and white sign saying:
"WARNING, STIFF PADDLES - DO NOT OPERATE UNLESS EQUIPPED WITH RATCHET WINDLASS"
Share this post
You forgot to add "AVAILABLE FROM CRT AT A BARGAIN PRICE OF £120.00 + VAT"
Share this post
Me too
And you forgot to add.
"Licence to operate ratchet windlass required."
Share this post
