rawsondsr Posted March 16, 2018 Report Share Posted March 16, 2018 Anyone know anything about these? Good quality or not, good hull design? many thanks Link to comment Share on other sites More sharing options...
Alan de Enfield Posted March 17, 2018 Report Share Posted March 17, 2018 It may be considered blasphemy by some, but I believe that the way a boat has been maintained over its life is more important than who the builder was. Any builders boat, if kept in a marina with 'stray electrical worms' floating about will / can be deeply pitted, if the top-sides are not painted and protected there will be corrosion. It doesn't have to be an 'old boat' to be a problem boat. What age is it, where has it been kept, has it been 'plugged in' with a land-line, what maintenance has it had ? Price Fallows are traditionally an Agricultural fabricator (manufacturing trailers, buckets, ballast weights etc) and decided to partially diversify into boats - about 9 years ago, so they should have had time to 'get it right'. 1 Link to comment Share on other sites More sharing options...
Bee Posted March 17, 2018 Report Share Posted March 17, 2018 1 hour ago, Alan de Enfield said: It may be considered blasphemy by some, but I believe that the way a boat has been maintained over its life is more important than who the builder was. Not blasphemy at all. I think you are absolutely correct. Dry and painted inside, painted everywhere that water can touch it outside = years of service. Price Fallows boats are not terrifically exciting looking but perfectly well built so far as I know. Just out of interest are there any really bad hull builders? Don't need to name names or create some sort of undeserved reputation but poor welding/ genuinely awful steel? Link to comment Share on other sites More sharing options...
Boater Sam Posted March 17, 2018 Report Share Posted March 17, 2018 Yes, there are/were several bad boys around. Thankfully they go bust regularly, trouble is they pop up again like daisies. Hulls with no weld inside in places, longer on one side than the other, bulkheads front and back not parallel or welded all round, and the inevitable banana boats. Link to comment Share on other sites More sharing options...
