Sign in to follow this
laura hinks
Water in the bulge
Im not a mechanical person but i just wondered what the reasons would be for water being in the bottom of the engine bay.
If the boats sat idle over winter for a few months without someone on it regularly to usw th bulge pump would the water build up massivley?
Is it something to worry about?
Someones told me that its historical water. I dont even know what that means. Can any one shead any light please?
Share this post
Leaking stern gland.
Condensation
Domestic water leak
window/hatch leak
Engine coolant/tank leak
Engine board leak (cruiser stern)
Deck leak
Hull leak
The extent of the worry is dependent on the extent of the leak and your continued ability to pump it out
Edited by rusty69
Share this post
Condensation
Domestic water leak
window/hatch leak
I think it may be a leaking stern gald.
Share this post
If you can't stop the leak by turning the stern gland greaser it may be time to have the stern gland re-packed, or the pusher adjusted if you have one.
Edited by rusty69
Share this post
It maybe a battle to remove it..
How much water? What type of boat?
Ian.
Edited by ianali
Share this post
I think you could describe ALL water as 'historical water' - it has all been here for millions of years and none has been made 'recently', in fact there is the same amount now as there was millions of years ago, it is just not always where our expanding populations want it to be.
The water cycle :
Image result for the water cycle
Share this post
I once knew a girl who also suffered with water in the bulge.
But when she gave birth, it disappeared like magic!
Hope that helps  :giggles:
Share this post
The water cycle :
Unless Laura has the biblical Red sea in her bilge complete with Os-Moses
Share this post
Unless Laura has the biblical Red sea in her bilge bulge complete with Os-Moses
Does it smell like vinegar ?
Edited by Alan de Enfield
Share this post
1 minute ago, Sea Dog said:
You need your head mended, you do. ;)
Up Jack got,
And home did trot
As fast as he could caper;
To old Dame Dob,
Who patched his nob
With vinegar and brown paper.
Share this post
2 hours ago, Mike the Boilerman said:
I think they just mean its been there a long time!
I thought that too but its a funny name
Ian.
About 4 inches i guess. A narrow boat . Ledgard
Share this post
Some cruiser sterns (and I guess some semi-trad and trad but cruiser more prone to it) can not help but gather rainwater - on Lutine the deck is below the gunnel and rain water has nowhere else to go. I doubt anyone can keep the bilge under a cruiser stern completely free of rain water.
A leaking stern gland that only adds four inches over a few months isn't leaking at all fast, and would be hard to detect. it would be a drip every couple of hours
Empty the bilge using the bilge pump, and see what happens
Share this post
A bit of kitchen towel balanced beneath the gland could help detect it. Or an ice cream tub (remove ice cream first)
Edited by rusty69
Share this post
Condensation
Domestic water leak
window/hatch leak
Deck leak
Hull leak
....................  you forgot rat's piss.
Share this post
Damn, I knew I forgot something. I also forgot mushroom leaks and flue/collar leak.
Do mushrooms leak? (makes good soup)
Edited by rusty69
Share this post
Laura doesn't say what type of stern the boat has. We have a cruiser stern and like Maggie says it's virtually impossible to keep the engine bilge dry. With ours it's the rain that's the main culprit and the worn deck boards and raised gunnels don't help.
If all the other possibilities mentioned on here regarding leaks have been investigated and Laura is still getting a depth of water in there, provided the bilge pump is set to automatic I don't think she has anything to worry about. I've been told many times to just accept that some boats have wet engine bilges and to not to be too concerned. I have and inch or so permanently in mine.
Share this post
Stern glands drip.  That's what they do.  However, the solution is simple:  next time you finish a carton of Elsan/Oil/Deionised water etc.  cut a large square hole in the side of it and tuck it on its side under the stern gland and put your bilge pump in there.
Share this post
