Heating Cost Comparisons
Alan de Enfield
In a recent thread, a comment was made regarding the high cost of heating when using LPG, however when looking at the heat output (Kwh) for each type of 'material', then taking into account the conversion efficiency the results may not be as clear cut as you may imagine.
1Kg LPG = 14.1Kwh and conversion is 90% efficient
1kg Coal = 6.9Kwh and conversion is 75% efficient
1kg of Smokeless fuel = 6.7Kwh and conversion is 75% efficient
1kg of Seasoned wood = 4.2Kwh and conversion is 85% efficient
1kg of diesel = 12Kwh and conversion is 90% efficient.
Compare 'smokeless fuel' with LPG with Diesel
LPG
Cost of a 13kg cylinder = approx. £25, or, £1.92/kg.
14.1Kwh @ 90% efficiency = 12.69Kwh
12.69Kw costs £1.92, or, approximately £0.15 per Kwh
Smokeless Fuel
Cost of 20kg bag = approx. £11, or, £0.55/kg
6.7Kwh @ 75% efficiency = 5Kwh
5Kwh costs £0.55, or, approximately £0.11 per Kwh
Diesel
Cost per Kg (1.17 litres at £0.80/litre) = £0.94/kg
12Kwh @ 90% efficiency = 10.8Kwh
10.8Kwh = £0.94, or, approximately £0.09 per Kwh
I think the problem with such as gas is that for instance if used in an alde c/h system is that it needs to run all night or the heat from rads disappears very very quickly whereas solid fuel stoves can tick over for hours for very little fuel and maintain a background heat when living aboard. To maintain my boat at 24 plus all day would methinks be expensive with gas and impossible or expensive with diesel wheras for max of a fiver a day I can be very warm and still ok overnight.
I think some of your figures are on the edge of reasonableness and if you move them more into the middle, the picture is a little different. So which LPG heaters are 90% efficient? Where on the cut do you get a 13kg cylinder for £25?
Similarly, diesel is around 65p a litre round here at 0% propulsion. But what diesel heaters are 90% efficient?
And yes buying coal in 20kg bags is expensive, coal is much cheaper when bought in bulk but agreed that is only any good if you have somewhere to store it!
In our marina, the unit price for electricity is 13p making electric heating (100% efficient) a good bet.
Edited by nicknorman
All efficiency figures from a 'energy comparison' web site by 'Nottingham Energy'.
Our BWML Marina
Don't forget we are comparing KGs and not litres. Our BWML marina is 80p/litre which equates to 94p/kg
Agreed - ours is 15p 'all in' (no service charges) but for liveaboards on the cut with no hook-up marina electricity prices are pretty irrelevant
Edited by Alan de Enfield
1 hour ago, reg said:
Junked my ALDE due to the cost of running it and also the fact that you have to constantly find and change the cylinder, not practical  when CCing.
I find that a solid fuel stove with Alde as occasional secondary heating, plus hot water, works fine. The cost of using the Alde as the primary heating source would be prohibitive.
Fradley junction Kingfisher Cafe/Caravan Park   £22 recently. Also for similar price at Capital Gas  Etruria between the top lock and the Black Prince hire base.
In my experience , (i have both an eberspacher and a solid fuel stove) If i use the eberspacher as i did last winter on a 24/7 basis i used around 160 quid a month in diesel ... using my coal stove 24/7 costs me half of that and the boat is like a sauna even the far end is warm enough and without an eco fan in sight! :)
Rick
4 minutes ago, Goliath said:
And I'm getting 25kg coal under a tenner, which wobbles the original figures too.
And dont forget the 'free' wood that feeds the stove.
What are summers for if not to season wood ready for the winter ... and who doesnt carry a chainsaw "just in case"? :)
Rick
Don't forget that many diesel and gas heaters require circulating pumps and boiler fans use 12 volt power (my webasto  uses 2.5 amps) which has to be replaced somehow. This is very unlikely from solar at this time of year, so engine or generator at loads per kilowatt.
Yep...post seven says it all.
1 minute ago, Goliath said:
And a chippy gave me several door frames/casings the orher day! Free wood comes in all ways. Lovely.
The last wood i got i was paid 20 quid to take to the tip! ... someone wanted a garage clearing ... 3 bags of rubbish the rest was wood :)
Rick
Some of those numbers look a bit iffy, anthracity and decent smokeless is close to 9kWh/kg and butane should be a bit lower for 'LHV - lower heating value' say 1.25kWh/kg
Gernerally IIRC grid leccy comes out to 2 or 3x the cost of coal, and calor price their bottled gas as high as poss without costing much more than grid leccy, so as not to lose too much sales. Dunno about red diesel/kero though, much depends on the oil market.
Smokeless should be very efficient in a stove on tickover, the flue near the chimney collar may only be lukewarm.
Edited by smileypete
Is butane generally used ? I thought Propane was the norm.
I am assuming that your quoted LHV is a 'typo' and should read 12.58Kwh/kg, (Propane LHV is 12.9Kwh/Kg)
My drip feed diesel stove uses less than 0.25 litres per hour on its lowest setting, whilst maintaining the boat at around 23-29°C in at or below freezing temperatures. With diesel currently at around 70 ppl it costs just £4.20 per day,  is easily controllable an only needs cleaning out once every 3 weeks of 24/7 use. :D
My neighbour has one and swears by it ... he has used half the fuel running his I would have used in the same period running my ebby.
Rick
Have you got a whole boat? or is it one of those tiny sixty footers or somett? they should be able to be heated for about ten bob :P If it is proper as in 68 feet or more :rolleyes: then I submit. :P
60 foot, but then my cabin is as long as yours coz it's a proper trad, not a semi-trad with a long rear deck and shorter cabin.  :D
Rick
Yes, I have a Webasto as well as the drip feed stove.
Whilst good for warming the boat quickly on chilly Autumn and Spring mornings and evenings, it costs more to run than the drip feed stove, whilst not getting the boat as warm.
I was sceptical of it at first and planned to swap it for a multi-fuel stove, but once I had  fettled it and understood how to get the best from it, I wouldn't go back to a multi-fuel stove unless the price of diesel rises dramatically over coal.
