NEW: Following member feedback, we now have a Mooring & Marina Review forum. Post your review here.
Sign in to follow this
shelly-123
Daily maintenance on RN engines
On Fulbourne's National you fill the oil reservoirs daily, give a turn on the oil filter screen and grease the water pump eccentrics if they need it.
We have a dry sump engine with an enormous external oil tank, so the oil level only needs to be checked occasionally, but on a wet sump engine I'd do it daily.
Share this post
Oil the linkages between governor and fuel pump.  Check water and oil.  Polish brightwork.
Edited by mross
Share this post
Make sure it still has oil and hasn't been disassembled by the Motor Fairies overnight.
That should cover it.
Share this post
17 minutes ago, shelly-123 said:
Ok many thanks so just really checking oil levels
Tush, tush -
 polishing the family engine is as important as all that oil stuff...
Edited by OldGoat
Share this post
Did you not read any posts?  Why not take heed of advice offered?:angry:
Share this post
On 08/11/2017 at 19:27, OldGoat said:
Tush, tush -
Or cheat polish it all and then spray it now my polishing is done for me.
Share this post
The first is the one which people often forget and its very important to ensure smooth running - VERY thin oil needed even WD40 worked for me
Share this post
