machinerepairs Posted July 19, 2017 Report Share Posted July 19, 2017 Attention Tony Sorry Tony I forgot my original account details under machinerepairs@hotmail.com. Further to my post BMC 1.5 Diesel over reving. I removed governor housing operated lift pump until all bits where cleared i cleaned govenor replaced it with idling screw out. Operated lift pump until diesel appeared in top of governed housing replaced idling screw and it works fine now. Hope this may help anybody else Best regards Les Link to comment Share on other sites More sharing options...
Tony Brooks Posted July 19, 2017 Report Share Posted July 19, 2017 So you probably flushed any swarf out. Its interesting to note that a glob of water can stop these hydraulic governors working. Link to comment Share on other sites More sharing options...
les trickett Posted August 30, 2017 Report Share Posted August 30, 2017 Used a plunger screw for stripped idling screw. Tapped the govenor housing in my case 10mm because someone else had put an helicoil in that failed. The plunger spring tension can be changed with the little grubscrew in the top. I used a doughty washer and a locking nut Link to comment Share on other sites More sharing options...
RLWP Posted August 30, 2017 Report Share Posted August 30, 2017 If you should need to search for one, they are Dowty washers, named after the company: https://en.wikipedia.org/wiki/George_Dowty Richard Link to comment Share on other sites More sharing options...
bizzard Posted August 30, 2017 Report Share Posted August 30, 2017 No doubty about that. Link to comment Share on other sites More sharing options...
Sir Nibble Posted August 30, 2017 Report Share Posted August 30, 2017 2 hours ago, RLWP said: If you should need to search for one, they are Dowty washers, named after the company: https://en.wikipedia.org/wiki/George_Dowty Richard Oh bums, I thought it was the propellor people. Link to comment Share on other sites More sharing options...
RLWP Posted August 30, 2017 Report Share Posted August 30, 2017 1 minute ago, Sir Nibble said: Oh bums, I thought it was the propellor people. It is the same: https://en.wikipedia.org/wiki/Dowty_Group Richard Link to comment Share on other sites More sharing options...
