Traveller 39 Report post #1 Posted April 22, 2017 There was a thread on here a while ago where someone rebuilt their shower cubical using the wet-room treatment. I just cannot find the thread and would like some pointers - membrane used etc. Many thanks Share this post Link to post Share on other sites
nbfiresprite 199 Report post #2 Posted April 22, 2017 http://canalworld.net/forums/index.php?/topic/90162-wet-room-floor/#comment-1969204 http://canalworld.net/forums/index.php?/topic/4652-wet-room-style-shower-floorsenvirolet-composting-toilets/#comment-61651 These two threads should help. Share this post Link to post Share on other sites
Traveller 39 Report post #3 Posted April 22, 2017 Thank you :-) Share this post Link to post Share on other sites
wonderdust 3 Report post #4 Posted April 23, 2017 Found this using the search function http://canalworld.net/forums/index.php?/search/&q="wet room"&type=forums_topic&sortby=relevancy Share this post Link to post Share on other sites
jddevel 338 Report post #5 Posted April 23, 2017 Having my wetroom vinyl floor installed this week. Have used a Impey Aqua level forma (800mm x 800mm) raised to allow Impey pumped drain. Forma screwed to 25mm ply sat on timber furrings to ensure its as level as possible. Bathroom is 1800mmx 1100mm with toilet vanity unit and double bi-fold doors obviously both of which fold back against the walls. Walls are being panelled with Aquabord PVC t&G panels. Share this post Link to post Share on other sites
FadeToScarlet 65 Report post #6 Posted April 24, 2017 The best thing I did in the fitout was seal off the bilge under the shower into a separate compartment. Saved lots of hastle from a leaky plumbing joint, kept all the water in one small bit and the rest of the ballast dry. Share this post Link to post Share on other sites
