Stoves Vannette GG2200
Hi thank you for reading.
Does anybody here have the owners manual for this Oven
Vannette GG2200, As mine is due for renew. I am looking to see what alternative I can put in the hole. Preferably as easly as possible ??
all I really need is the cut out size.... etc
Many thanks.
Hello
 According to my handbook the cavity required for the CG2200 is 465mm wide 460mm high and 5mm above floor and 500mm deep (these are the MINIMUM distances)
Again according to my handbook the oven itself is 472 mm high 495mm wide and 425mm deep and it is mounted "over"  the cavity hence the difference in hieight and widt
 Hope that helps obbut
N
  • 2 years later...
