Sign in to follow this
Roxylass
Warning light
The warning light wasn't going of when I started my lister sr2.
Replaced with a new one still wasn't going of.
Had a mechanic look at it couldn't figure it out
So he fitted an exciter switch.
So when I turn the key now i press the button and the warning light comes on.
Start the engine press the button and the warning light goes off.
Is this an acceptable practice.
Share this post
The alternator on that engine would be driven by the camshaft which rotates at half crankshaft speed. So it sounds like you have the small diameter pulley on the camshaft. To get the proper output from the alternator a larger diameter camshaft pulley is needed, a 9, 10 or 12'' one. You would not need the exciter switch then, just a normal 2w or so warning light which would excite it.
Mechanics that don't know these engines often think the camshaft IS the crankshaft, because its thick and beefy.
Nothing wrong with an exciter switch but a bigger wattage warning light bulb would probably do the same thing. 5 or 6 watt.
Edited by bizzard
Share this post
M'lud B'zzard is absolutely correct, but for folks unfamiliar with engines manufactured before the dawn-of-time, perhaps the key point is that you need to spin the engine up-a-bit to get the alternator to start charging, and the light should go out, without the need for a shorting switch.
IME the shorting switch often gets left on - and that will flatten the engine battery if left on for long enough (done it...)
Share this post
All I really have had done is the starter refurbished.
And a new belt on the alternator which is good and tight.
So after fitting a new belt the alternator didn't charge without help
Share this post
Yes problem started after new belt fitting
Where could I purchase a 5/6watt warning light.
Cant see any on eBay.
It would be fitted with a much lager bulb holder than the usual tiny one which you probably have , which will mean enlarging the hole for it. Car spares shops and motor factors would have them. But do you have the large diameter drive pulley on the camshaft or the small 5'' or so one?
Share this post
Another bulb or resistor in parallel with the original lamp can be used if a higher wattage bulb of the same style can't be found to fit the existing lamp holder.
Share this post
As an initial check, I'd see if the batteries are being charged up with the engine running. Check the voltage is at least above 13 volts (higher than when engine is not running). Just wondering if alternator is playing up or a connection was disturbed when the belt was changed
Share this post
So why did it work before the belt was changed but now it doesn't? something has changed, maybe a poor contact on the field connection?
Edit
Like Rowland al said. My post didn't go straightway.
Edited by ditchcrawler
Share this post
Here is a couple of pictures
You do have the small diameter pulley. It would excite and charge so much better with the large one. That W/Light wire from the alternator looks stretched and a bit thin, strands maybe broken in it..
Share this post
Or the feed cable left off when the starter was fitted.
Which feed cable do you mean? The emgine starts so presumably you don't mean the starter.
Share this post
The main B+ connection should probably have one from battery, one to control panel and one to the alternator. Your problem has not been caused by sudden shrinkage of the pulley and you shouldn't rely on a bodge carried out by a bloke who doesn't know what he's doing.
Share this post
Your problem has not been caused by sudden shrinkage of the pulley..............................
It has been very cold lately!
Share this post
Funny this should come up now, I have just refitted my 24 volt domestic alternator following repair. started the engine all fine ant then noticed the "Ignition" light glowing. I had caught the field connection on the 12 volt alternator mounted a little way above the 24 volt one. quick wiggle and all fine again.
Share this post
The battery shows 13 volts before starting
Engine running not even half throttle it's showing 13-50 13-60
I would like to see above 14 volts a short time after starting.
Most alternators don't charge below 2,000 rpm, do the volts increase at higher rpm?
If you switch the exciter switch off does the lamp come back on?
Share this post
Once I start the engine I switch the exciter off.
And yes it stays off.
With the boat sitting out the water just now on blocks
I am not going to be giving it full throttle
Share this post
What I think you have is a work around for a problem which is still there and could get worse. So in answer to your original question, no, I don't think it is ideal.
I suggest you get all of the wiring checked out by a good engineer and have the alternator tested. As mentioned, it should give you over 14 volts if it's working properly and testing will show whether the DC output is smooth and correctly rectified.
Also as mentioned, a bigger pulley on the crankcase end would help but I assume everything was fine up until the fault.
Once the fault has been rectified (so to speak) it might be best to remove the work around to simplify the circuit and prevent that causing a future problem. I hope you get it sorted.
Share this post
