hilaryb Posted October 18, 2016 Report Share Posted October 18, 2016 recommendations for a not too heavy sander.. And not too expensive please. Link to comment Share on other sites More sharing options...
carlt Posted October 18, 2016 Report Share Posted October 18, 2016 (edited) It depends what you are sanding but nearly all my sanders are from the Makita range, the palm sander for detail work being by far the number one choice for professional woodsmiths. I steer clear of "not too expensive" orbitals because the cheap stuff tend to be just sanding blocks that rattle and are no better switched on than switched off. Randon orbitals are more consistent though. For wet work (ie. standing on the bank where the sander can go into the water) I use a Wickes own brand random orbital which is just as efficient as my Makita (but not nearly as comfortable) but more disposable should it take a swim. Edited October 18, 2016 by carlt Link to comment Share on other sites More sharing options...
dave moore Posted October 18, 2016 Report Share Posted October 18, 2016 All of the coach painters I work with use random orbit or dual action sanders, usually with a 150mm pad to hold the disc. I've had my Bosch professional for years, a cracking bit of kit, paid about £150 for it. Worth checking Screwfix or Tool Station to see what's around. Very cheap models may not last long! Link to comment Share on other sites More sharing options...
Psycloud Posted October 18, 2016 Report Share Posted October 18, 2016 My random orbital sander from Screwfix has just completed my boat, and I put 7 coats on so it had to rub down the entire 64" top and sides 7 times. It is quite heavy as 150mm so you might be better with a 125mm model. http://www.screwfix.com/p/erbauer-erb382sdr-150mm-random-orbit-sander-230-240v/96759 Link to comment Share on other sites More sharing options...
Jrtm Posted October 20, 2016 Report Share Posted October 20, 2016 Ifbits a belt sander the jcb one id good but will happly strip the joint on the belts. Link to comment Share on other sites More sharing options...
