Sign in to follow this
ditchy
Pulley
I'm after a BMC 1.8 cranlshafy pulley as I've taken mine off and it has a chip out of the keyway. It is approx 28 inner & 185mm outer diameter. Thanks in advanve.
Share this post
Hi ditchy
Have you tried Calcutt Boats, they have loads of BMC bits :)
Address:
Tomlow Rd, Stockton, Southam CV47 8HX
Phone: 01926 813757
Share this post
Worth calling Chertsey Meads Marine (Google for phone number) they have recently helped a friend of mine out with parts for a BMC 2.5 :)
Share this post
Plenty on Ebay.
Share this post
This is a pulley from a BMC 1.5/1.8. The key feature is that it is in two parts, separated by a thick rubber section. This allows the outer ring to damp out oscillations in the crankshaft by being connected through a flexible element. Opinions differ on if this is necessary, I'm inclined towards thinking that it is
This is the problem with these pulleys:
They develop a crack along the keyway. Ditchy's is worse than this with a piece falling out. As this is the surface that the oil seal runs on, it makes a terrible mess
Now, if pulleys were easy to find, I would scrap this one. But they are nigh on unobtainable. I have just stripped the pulleys from three engines, and only one is OK
So, we need a pragmatic solution, which is a Speed Sleeve:
It's a precision made, thin walled sleeve intended to renew sealing surfaces. In this case, it will seal the crack and stop oil seeping out. It will also put a strengthening hoop around the spigot which will help hold it together.
The sleeves come as a kit with a fitting tool:
Which you put over the sleeve and fit it with a hammer:
This is the fitted sleeve:
And it's too long, and hardened, so it needs to be ground off:
And there we are:
Richard
Share this post
This is a pulley from a BMC 1.5/1.8. The key feature is... etc, etc.
Richard
If that isn't the most helpful post I've ever seen, I don't remember what the better ones were! I don't have a BMC engine, but I might go and buy one just to ask questions about it now! Nice one, Richard, have a greenie. :)
Share this post
Plenty on Ebay.
There are a few MGB B series pulleys there, but are these the same as the BMC diesel?
I was also told the 1.5 is different from the 1.8?
Share this post
I have had 1.5 and 1.8 pulleys side by side and I cannot see any difference
Richard
Share this post
Richard
Thanks for that bit of info.
I'm sure at the time I had phoned Calcutt some years ago or similar establishment and they advised against mixing the two. I might have misunderstood the details I was told.
I found your repair of the pulley interesting to follow. How much was the Speed Sleeve?
Share this post
The Americans on the MGexp forum swear by them as a way of helping keep oil in B series engines.
There's a lot of discussion on MG forums about the harmonic damper/ pulley. General view of the expert engine builders is that without them engine life can be affected - racers having problems with broken cranks. They're available second hand from MG breakers.
Share this post
And are they the same as the diesel pulley? Calcutt say they are unobtainable, so I would be surprised if the MGB one, which is very common, was the same
Richard
Share this post
Without intending to appear anal, the SKF variety you have is Speedi Sleeve. I spent a while googling speed sleeve and got few hits. Just in case the photos disappear from this site, for reference, your part no. is SKF 99156.
The idea of hammering this on, even with the tool, frightens me a little! I have a flypress and much prefer to apply pressure uniformly over the tool and perhaps slide the sleeve in one go.
Share this post
The sleeves come as a kit with a fitting tool: Which you put over the sleeve and fit it with a hammer:
I am not sure about hitting it with a hammer. Maybe as a last resort. But without a proper bench press it would be easy enough to make your own simple fitting tool.
Take two large metal plates with a hole in the middle and a large diameter nut and matching (long enough) bolt.
Pass the bolt through the plates and pulley and sleeve and tighten the nut.until the sleeve is squeezed onto the pulley.
Share this post
Yew, you can do all of that if you want. Or follow the Speedi Sleeve instructions and use a hammer: http://www.skf.com/uk/products/seals/industrial-seals/power-transmission-seals/wear-sleeves/skf-speedi-sleeve/installing-skf-speedi-sleeve/index.html
The sleeves are designed to repair shafts without removing them from machines, i.e. when you cannot use bench presses, hydraulic kit, vices or any other equipment
Richard
Share this post
Richard
Do you have a part no. for the 'Diesel' pulley ?
Share this post
Sorry, no. There is a number cast into the pulley, it doesn't match the parts lists. We checked with an MG specialists
Richard
Share this post
Richard
On my 18V engine the pulley has 12H963 cast into it. This is a 1979 petrol b series.
On the Moss website they list 3 pulleys. 1 without a damper (1962 - 3) 12H773, 12963 (64 - 70) and 12H3515 (1970 - 4). Main difference is where the timing marks are, apparently all are interchangeable ( on petrol at least).
Edited by Chalky
Share this post
Do you have any dimensions of that pulley?
Richard
Share this post
Richard
Richard
Great! - if there is room to swing a hammer - boat engines are likely to be too close to the bulkhead to use a hammer.
Share this post
And there we are:
Richard
Excellent repair, however I would be concerned that with a cracked keyway of that magnitude how long it will go before it fails.
Share this post
Seconded! You may just have saved me some head scratching when I finally get my pulley off to renew the oil seal. Thanks!
Share this post
