Can these electric outboards power a narrowboat?
Doodlebug
I first posed this question in the midst of another topic but now I am planning out my next project properly so looking for points of discussion.
What are the pitfalls of using a 86lb trolling electric outboard motor to power a narrowboat.
Two of them.
I am trying to work out if the idea is feasible. I know they will push the boat but the sticking point is will they push it fast enough.
I found this video made by rob bolwell and although I tried contacting him I have had no reply. Anyone know of him?
https://m.youtube.com/watch?v=wjA17Fb-WXM
It seems to be going at a reasonable speed and our boat appears to be pretty nimble so I suspect it may work better on ours. But this is all speculation and am looking for last minute issues before I bite the bullet and buy some.
I don't plan on going on any rivers by the way.
Thanks!
Doodlebug
Saw a boat below Atherstone last week being powered by two electric outboards strapped on the back, he was making very slow progress when I saw him.
Edit
Just got the video to load and the set up was identical the boat was blue as well
Edited by ditchcrawler
Edit
Interesting. Wish I could get in contact with him! When you say slow progress. Do you mean slower than walking pace. I have noticed that our top speed at the moment of 3mph is easily dwarfed by a lot of boats so your idea of slow may be different to mine!
With a total of 172lb of thrust you are going to need some serious battery capacity.
Phil
Power source is sorted out. I feel I shouldn't go into detail yet to avoid complicating the topic! My topics usually go off course within a couple of comments!
I would expect the props to be cavitating all the time, and even if you did get up to any speed, stopping would be too slow to be safe.
You can power a narrowboat with electricity but you need at least 10hp available and a decent size prop.
See you say that yet we currently have a 10hp engine and I have never maxed it out and usually have it running just over tickover. That suggests 10 is more than enough.
What size of boat is it?
You don't don't want to be holding people up, so you need to get to the speed which is just bellow the bank washing speed, and you need to be able to stop rapidly when going into locks and when coming out in a high cross winds etc. For a 25ton 70' boat I would not have less than 40hp (modern engine), 20hp (60s/70s Lister ST for e.g.) or 10hp (classic old engine) - note that torque is a key factor here.
Edited by Tiggs
The propellers on those electric outboards are incredibly efficient, well the Minkota ones we used for litter picking on the upper Stort for 7 years in our pick boat Bin Laden were. A 110 amp fully charged battery would last around 3hours but this was with very intensive use, whacking back and forth on full throttle all the time. We also towed a large heavy steel pontoon occasionally which it did pretty well with. We got through 3 motors, 'two were S/H' in that 7 years, they did well considering the bashing they got.
We weigh 6 ton and are 33ft long. I can easily get the boat going at canal speed just by pulling the ropes.
Obviously if someone is catching up with us we let them overtake. And going into locks should be done slow anyway. Never had to put it into reverse and rev hard. I enter locks at tickover then flick it into reverse as we get to the gates - maybe due to being an outboard we have good steering in reverse. I then hop off and tie up.
Any idea what power rating?
Stupid question but what does S/H mean. Been a long day.m
Edit- it means second hand!
Edited by Doodlebug
What if its really windy (crosswind) or a strong weir? Do you just bump along the armco or potentially get stuck on the weir (ie if going downhill and the wind is blowing that direction?)
Also what about winding? I know its a small boat on a big canal but if you want to turn in more places, you'll likely have opportunities with a more powerful engine. Again, what if you want to turn decisively because there's a bit of a crosswind etc? You don't want to be tootling around taking 10 mins, getting blown onto the offside bank, etc etc
Small one 3/4 hp I think.
Have a look at this one
http://solarpowerednarrowboat.blogspot.co.uk
Similar size and weight.
Cruses using about 1 1/3 hp. (1Kw)
But has a sensible prop size and speed I would have thought. Looks like a much more sensible way of doing a solar powered boat.
Having looked up similar, I think the motor is rated at 10Kw but not sure.
Edited by Tiggs
10 is fine with a ok big prop
10p is fine with a ok small prop
The prob you get is if or when you get stuck or into trouble. This is when you find out if your engine and prop are upto it.
Some working boats only had around 10 but most of these had a torque and prop far bigger than most still have.
Im far to over proped on tickover i make no wash but catch people up as it still shifts prob about 2mph i often find my self not in gear. But i also have plenty for when i do get stuck.
Electric or a by product e.g. genarator type thing with electric drive is the future but the electric motors are still not there yet. 1900 they experimented with electric cars they did about 100 miles, guess what we have pure electric cars they still only do 100 miles.
The best way is a small diesel engine running a generator. This gives the best long running fuel economy with high torque and good power.
Edited by billybobbooth
the simple answer is NO, it is unsafe.
I have a 32lb motor pushing a 16ft 600kg launch, it manages canal speeds, and can stop the boat in about 3 boat lengths.
for a heavy steel narrowboat, you may get 2 or 3 mph but you will not be able to stop or manouevre the boat safely in a sidewind, a current or an emergency.
I have a conventional outboard that comes into use when the batteries and the solar cannot keep up.
Its not 'starting' that's the problem - yes they would get you going, initially slowly then building up speed.
In the 'strong man' competitions a human bean can pull a 35 ton truck - but can he stop it ? (I'm sure you know the answer)
Your proposal would be dangerous to you and other waterway users
A good point but bear in mind we would have 6 times more power than you have.
Again I didn't want to over complicate but since emergency stops are an issue - I plan to have the current 10hp petrol (or maybe converted to lpg) engine mounted in position linked with the morso control. When needed the outboard would kick in. Again I won't explain exactly how in this thread but have worked out a way to get it on and in gear within 1 second automatically.
Two of them.
Thanks!
Doodlebug
Those 86 pound thrust Outboards draw 58 AMPS at 24 volt IIRC,that is a massive drain on a Battery bank.
CT
True true. But my topics usually go off on tangents.
If I explained the complex version people would say it's too complicated to work. Thing is that it's a very simple system but with a back up component for every aspect of the design.
If I explain the simple version people say "what if"
It's like me questioning whether direct drive is a danger to canal users - what if you break down and can't stop? What if you run out of diesel. Or the rudder breaks?
CT
Desperately trying to stay on topic but Power comes from an engine in the front.
How did a horse stop a boat? or manoeuvre in a side wind?
Hi Doodlebug,
good to read you've got a new project planned.
If you want a decent electric outboard, you'll find out that they don't give them away, but it may be a good and green solution for the future.
These electric outboards are known worldwide and seem to be very reliable.
I've only seen one in action on a 25ft yacht that an American guy was traveling with in France, he was very happy with his and said that he didn't regret not having his petrol-outboard anymore at all.
http://www.torqeedo.com/en/products/outboards/travel
Peter.
I bought a Minn Kota Genesis from the USA. 24v 74lb thrust. Just the motor unit. I.made a stainless shaft and a mount for it and wire it to a 60a PWM controller (generic Chinese £13)
I found a second hand motor but available new from USA for £300 incl shipping.
http://pages.ebay.com/motors/link/?nav=item.view&id=252370793047
Minn kota did make a 12v "3HP" model but the letters stand for HiPower not HorsePower.
My 24v unit pulls up to 45a so that's around 1hp equivalent I think.
I use it on a heavy 14ft GRP launch. I think two of these would push a small Nb but you are looking at about 60+ amps draw continuously I reckon. You will need good batteries.
Torqeedos are a bit dodgy - more of an expensive toy with a high speed remote control aircraft motor driving through a planetary gearbox. Burnout issues. Minn Kota are direct drive heavy slow running motors.
The idea of the Torqeedo was to get a small inflatable to plane with an electric motor. Minn kota are built down to a price but they are specifically designed to push heavy boats slowly.
I put a Kipawa prop on mine. Good thrust and good in weed.
The 24v 74lb and above are the large 4 inch motor unit which is a different beast from the usual minn kota motors one sees ')
Edited by magnetman
A good point but bear in mind we would have 6 times more power than you have. and probably 20 times the boat weight = 20 times the momentum.
Again I didn't want to over complicate but since emergency stops are an issue - I plan to have the current 10hp petrol (or maybe converted to lpg) engine mounted in position linked with the morso control. When needed the outboard would kick in. Again I won't explain exactly how in this thread but have worked out a way to get it on and in gear within 1 second automatically. if you have a seriously sized narrowboat a petrol outboard won't be adequate for stopping either, unless it is a heavyweight turning an 18" prop (is there such an animal?). you'd better explain further to convince the doubting Thomases that your proposal is practical and reliable.
I don't know - you tell me.
but then they weren't operating at the same speed or in the same circumstances as found on canals today.
