CaptAWOL Posted May 24, 2016 Report Share Posted May 24, 2016 Yesterday approaching the narrows to Llangollen, I had a thud in which the engine slowed and the whole boat shook, from then I had a constant rattle/ vibration on the tiller. Today I reluctantly ventured into the weed hatch to find damage to one of the prop blades. Before I go through the process of googling, I thought I'd ask For suggestions as to repair Tomorrow I will advise CRT of this, boat draught is 28 inches Link to comment Share on other sites More sharing options...
RLWP Posted May 24, 2016 Report Share Posted May 24, 2016 A bit bent at the tip? A blade missing? What's happened Richard Link to comment Share on other sites More sharing options...
MoominPapa Posted May 24, 2016 Report Share Posted May 24, 2016 Tomorrow I will advise CRT of this, boat draught is 28 inches According to my Nicholson's the maximum draught for the Llangollen is 27" to Trevor, and 24" for the remainder. I wonder if that will affect CRTs reply. MP, who's at Grindley Brook, heading in the same direction in a 34" deep boat. I'm interested in the replies to the original query as I had a similar experience when (I think) the prop was entirely stopped by a jammed log at I was turning under the junction bridge at Great Haywood. There was a thump, and a loud whirring sound. I instinctively went for reverse, and said log shot out the back. No apparent damage, but I can feel a few nicks in the leading edge of the prop that should probably be dressed next time it's out of the water. Do Blackstone boxes whir when slipping with a jammed output? Link to comment Share on other sites More sharing options...
nbfiresprite Posted May 24, 2016 Report Share Posted May 24, 2016 These people will do a good job repairing your prop. Darglow Engineering Ltd Unit 6 Justin Business Park Sandford Lane Wareham Dorset BH20 4DY Email: mail@darglow.co.uk Tel: +44 (0)1929 556512 www.darglow.co.uk Link to comment Share on other sites More sharing options...
MtB Posted May 24, 2016 Report Share Posted May 24, 2016 (edited) Today I reluctantly ventured into the weed hatch to find damage to one of the prop blades. What damage, exactly? Had to imagine minor damage causing the effect you describe. That would take half a blade missing or something really major as the propshaft just doesn't rotate all that fast. What engine, box and reduction do you have? Is that a JP2 in your avatar? Edited May 24, 2016 by Mike the Boilerman Link to comment Share on other sites More sharing options...
Slim Posted May 24, 2016 Report Share Posted May 24, 2016 (edited) Can't help with suggestions as to removal but Crowthers in Oldham are the people for repairs. Really helpful. Recently had them clean up, re pitch and balance my 17 x 12 prop. Took about 4 hours to do and a fair amount of that time was for it tocooldown. Cost about £150 Don't have contact details but google Crothers Propellers and it will come up Frank Edited May 24, 2016 by Slim Link to comment Share on other sites More sharing options...
MtB Posted May 24, 2016 Report Share Posted May 24, 2016 Tomorrow I will advise CRT of this, boat draught is 28 inches Why? You've just had a lump of debris in your blade. It happens all the time and will be of no concern to CRT. Link to comment Share on other sites More sharing options...
CaptAWOL Posted May 24, 2016 Author Report Share Posted May 24, 2016 Quite a dent in end of blade, can't remember how to put pics up but will when I figure it out The section in which it happened is very deep, this can be seen as water normally quite clear Link to comment Share on other sites More sharing options...
Cheshire cat Posted May 24, 2016 Report Share Posted May 24, 2016 Another vote for Crowthers. The challenge is going to be getting the prop off without visiting a dry dock. Link to comment Share on other sites More sharing options...
CaptAWOL Posted May 24, 2016 Author Report Share Posted May 24, 2016 Link to comment Share on other sites More sharing options...
MtB Posted May 24, 2016 Report Share Posted May 24, 2016 Hmmmm good photo, but I'd class that as so trivial as to be ignorable. I think the vibration you describe is caused by some other damage. (Subject to you telling us what engine and reduction you have.) Link to comment Share on other sites More sharing options...
dor Posted May 24, 2016 Report Share Posted May 24, 2016 In my experience that is a little more than trivial. I've known less damage than that to set up quite a vibration, particularly at certain revs. There is a good chance that the prop can be taken off in the water - a good boatyard should manage it. If not, marinas with slipways often offer a slip out on their trailer, stand for an hour or so and back in for a modest sum. Cost me about £80 I think for a few hours on the slipway at Swanley Bridge. If it was a big bang, it could have taken out a previuosly weakened engine mount, or damaged one that had been previously good. Also could have caused some damage to the couplings depending on how it is set up. Looks fairly typical of a prop picking up a large log and jamming it between the blade and the skeg. Link to comment Share on other sites More sharing options...
MtB Posted May 24, 2016 Report Share Posted May 24, 2016 In my experience that is a little more than trivial. I've known less damage than that to set up quite a vibration, particularly at certain revs. Yes but you have a modern fast revving engine. The OP appears to have a JP2. Link to comment Share on other sites More sharing options...
CaptAWOL Posted May 24, 2016 Author Report Share Posted May 24, 2016 Lister JP2 with 2:1 on paragon manual reverse gearbox Prop is 22" Link to comment Share on other sites More sharing options...
CaptAWOL Posted May 24, 2016 Author Report Share Posted May 24, 2016 Engine is about 15ft from propeller and I have checked prop shafts and joints which appear intact, though I appreciate visual doesn't go a long way with prop shaft joints Link to comment Share on other sites More sharing options...
MtB Posted May 24, 2016 Report Share Posted May 24, 2016 I suspect you have a prop shaft joint designed to slip in the case of a log jam.... Link to comment Share on other sites More sharing options...
Tony Dunkley Posted May 24, 2016 Report Share Posted May 24, 2016 That tailshaft looks a bit small on diameter in the photo, and there's too much of it unsupported between the outer bush and the propeller boss. The kink at the tip of one blade isn't very serious and will be a relatively easy fix, but the tailshaft may well be bent, and certainly should be checked. Link to comment Share on other sites More sharing options...
CaptAWOL Posted May 25, 2016 Author Report Share Posted May 25, 2016 Well its gone from bad to worse, this morning my engine is a none starter, starter motor struggling to turn fly wheel Link to comment Share on other sites More sharing options...
RLWP Posted May 25, 2016 Report Share Posted May 25, 2016 Well its gone from bad to worse, this morning my engine is a none starter, starter motor struggling to turn fly wheel Most likely a flat battery Link to comment Share on other sites More sharing options...
CaptAWOL Posted May 25, 2016 Author Report Share Posted May 25, 2016 Most likely a flat battery Fully charged battery, getting a resistance turning flywheel seems to be on the injection of 1 cylinder inlet & exhaust valves operating as they should, checked inside and nothing obvious Link to comment Share on other sites More sharing options...
MtB Posted May 25, 2016 Report Share Posted May 25, 2016 Fully charged battery, getting a resistance turning flywheel seems to be on the injection of 1 cylinder inlet & exhaust valves operating as they should, checked inside and nothing obvious That is to be expected, the compression stroke provides substantial resistance! Are you saying the resistance is missing on cylinder 2? Link to comment Share on other sites More sharing options...
Claude Posted May 25, 2016 Report Share Posted May 25, 2016 I don't think the dent in that prop blade is trivial at all. It could be ignored if you wish, but will certainly make a difference in terms of vibration and long term wear of stem gland etc. I had a similar dent repaired at Noris in Isleworth and it made a big difference. Link to comment Share on other sites More sharing options...
Kieron G Posted May 26, 2016 Report Share Posted May 26, 2016 A&E Woodward's at Hull would do a good job on your prop for a very reasonable price ( Posted by a satisfied customer ). Link to comment Share on other sites More sharing options...
CaptAWOL Posted May 26, 2016 Author Report Share Posted May 26, 2016 That is to be expected, the compression stroke provides substantial resistance! Are you saying the resistance is missing on cylinder 2? Numpty moment must of occurred, couldn't of had one decompression valve in properly when testing rotation of engine. Solved starting problem, clutches gone in starter motor and replaced today Link to comment Share on other sites More sharing options...
MtB Posted May 26, 2016 Report Share Posted May 26, 2016 Numpty moment must of occurred, couldn't of had one decompression valve in properly when testing rotation of engine. Solved starting problem, clutches gone in starter motor and replaced today What excellent news. A numpty moment if INFINITELY preferable to a broken crankshaft moment, which is what I was wondering! Link to comment Share on other sites More sharing options...
