Sign in to follow this
swift1894
Battery/alternator/solar wiring schematic
When you sort it please come back so those who know can explain how to set up the MICC to minimise the "stet of charge" error
Sorry Tony I forgot to get back to you (got side tracked by at least 5 other jobs that need doing!).
Anyway, wiring done, so is there something I need to do re MICC to minimize "state of charge".
Share this post
No, that was rather tongue in cheek. The point you need to grasp is that such instruments are exceptionally good at persuading the unknowing to wreck their batteries by consistent undercharging. This is because it can accurately measure how many amp hours have been taken form the battery but can not accurately measure how many of the amp hours being fed to the battery are actually converted into chemical energy in the plates.
IF the MICC has the facility you need to set it for the battery type you have got, probably tell it the present battery capacity which you will not know because of sulphation, and set the tail current to a sensible figure so it recalibrates itself. Then very regularly charge to that reset point so it recalibrates and stays as accurate as it can be - which some will say is not very.
The reason I said Those who know is because I have no experience of the MICC and all the amp hour counters are slightly different in their setup.
You need to grasp that there is a good chance that yours will tell lies re state of charge and institute other procedures for checking it. I would suggest voltage readings just before you go to bed when all the loads are switched off.
Share this post
Tee-hee!?
The batteries are 6 brand new Trojan 105s, so 675Ah at 12 volts.
Currently the MICC is saying 13.17v, 0.4A (nothing running at mo and I switched genny off 30 mins ago) and SoC 40%!!!!!! So I think I need to reset the MICC
Edited by swift1894
Share this post
Tee-hee!
What did the current read just before you switched the charger off? Taking a range of views it should be down to around 10% of battery capacity, so say about 6 or 7 amps. That's the tail current and we can argue about whether 5, 10, 0r 16% of capacity is the so called fully charged tail current reading all day but 10% is near enough for most people.
Unless you have solar the 13.7V must still be surface charge that will dissipate over the next few hours. If it stabilises at around 12.7 to 12.8 V without a load then you can consider the batteries about fully charged and reset the meter. However I think it should reset itself by the tail current if you can program it.
Share this post
Reading at mo 13.44v 7.6A (that will be coming from solar panels)
I'll let things settle down tonight (when solar goes to sleep) and if things stabilise around 12.7 I'll reset the meter.
Edited by swift1894
Share this post
I'll let things settle down tonight (when solar goes to sleep) and if things stabalise around 12.7 I'll reset the meter.
That sounds like a good plan.
Share this post
ISTR the defaults are pretty poorly chosen, especially if there's solar.
Been a few topics on them, should be able to dredge one up if needed.
Yes please. All advice gratefully received.? Edited by swift1894
Share this post
Thanks, that is what I was hoping for.
Share this post
Nope. 6 brand new T105s will give around 470 Ah at 12V. Once they've been through a few hard discharge and full recharge cycles then they'll start to approach 670 Ah capacity. (At 20 hour rate.)
Tony
Share this post
Tony
Good point. I've heard about Trojans taking a while to get up to max.
Should I "tell" my MICC the capacity is 470Ah to start with?
Is this peculiar only to Trojans?
Share this post
Better still do a few good long charges and go by the tail current for when to stop and ignore the MICC for now. Then put the 670Ah in the MICC.
Share this post
Looks like it was for a BMV, should apply for the MICC if it uses similar settings:
http://www.canalworld.net/forums/index.php?showtopic=69564&page=2#entry1385646
Can you find out and post all the existing settings from the MICC?
For example say you charge by genny, and the max charge voltage is 14.4V and minimum 'tail current' is 3 amps when it levels off to a steady low level.
Then set the 'charge voltage' just below this at 14.3V and set the 'tail current' just above this at say 4 amps.
Edited by smileypete
Share this post
Apparently not although whether it's to the same degree on all batteries I couldn't say.
Tony
For example say you charge by genny, and the max charge voltage is 14.4V...
It's worth pointing out that he'll never get the best out of his Trojans if he can't get the charge voltage closer to 14.8.
Tony
Share this post
Pedant input - 1%, not 10%!
Tony
Very true. They get better in their first 6-12 months.
Share this post
Tony
Yes I realise that (after it was pointed out to me on this forum), so I'm getting a Sterling regulator.? Edited by swift1894
Share this post
Agreed - another brain fart, must be getting too old it seems.
PS - that's not being pedantic, its getting the fact right. Everyone makes mistakes sometime.
Edited by Tony Brooks
Share this post
Swift, it would seem we are both in the middle of quite similar electrical refits of Sheffield size keels - might be interesting to compare notes. :-)
If you look at the "Remote battery isolators" thread you will see the wiring diagram I drew up for ours, although there are some subsequent corrections discussed in the thread.
Share this post
I have just done a 285 watt solar install on my boat and even though I had solar on my last boat I did not it seems balance the battery bank correctly, so from information I found on line I wired my bank up so all the battery's share a more balanced load.
Here is a diagram I made for a 4 battery bank.
http://s20.postimg.org/foic92au5/image.jpg
Share this post
