jimfin Posted February 28, 2016 Report Share Posted February 28, 2016 I am marinising a 1.9 XUD Pugeot engine. I'm not in a hurry so hope to get most of the parts secondhand. I am looking at adaptor plates to fit a PRM to the bell housing. What's confusing is the SAE!!! What is this refairing to??? Link to comment Share on other sites More sharing options...
RLWP Posted February 28, 2016 Report Share Posted February 28, 2016 (edited) SAE is an international standards organisation For a gearbox it refers to the input spline size and the mounting bolts. There are many gearboxes with the same bolting pattern and input shaft e.g. PRM120/Hurth (something)/Tecnodrive TMC40 so you can fit any of them to the same adapter plate Richard MORE: the PRM120 installation drawing is here: http://www.prm-newage.com/media/uploads/51b1a096b04f4.pdfIf you check this against other similar boxes, you'll find the same six mounting holes and same size spline Edited February 28, 2016 by RLWP Link to comment Share on other sites More sharing options...
andyb116 Posted February 28, 2016 Report Share Posted February 28, 2016 We have just taken an XUD engine out of a boat, it had a PRM 150 box on it with a proper manufactured adapter plate on it (not home made) and the engine was marinised properly, so the bits must be available. A word of warning though, the engine was a 2.1 90hp on a 2 to 1 box in a 60ft boat so never went above tick over as it was to powerful and revved to high. Link to comment Share on other sites More sharing options...
Paul C Posted February 28, 2016 Report Share Posted February 28, 2016 I am wondering if the engine could be "de-turbo'd" for the boat application? They did many variations of this engine, some without turbo, for example the 1.8 XUD7TE has 90bhp but the XUD7/K has no turbo, and produces 60bhp. If there's non-turbo versions then the relevant inlet and exhaust manifolds, and possibly other parts, will be out there. Link to comment Share on other sites More sharing options...
jimfin Posted February 28, 2016 Author Report Share Posted February 28, 2016 The engine I have is out of a Citron Xantia, an 1.9 XUDTE. This is a turbo engine, but no electronics. I was told that I could leave the turbo off as it would only kick in on high revs and the engine would run ok under 2000. Link to comment Share on other sites More sharing options...
RLWP Posted February 28, 2016 Report Share Posted February 28, 2016 The engine I have is out of a Citron Xantia, an 1.9 XUDTE. This is a turbo engine, but no electronics. I was told that I could leave the turbo off as it would only kick in on high revs and the engine would run ok under 2000. That seems unlikely. The turbo seems to kick in around 1500 RPM Richard Link to comment Share on other sites More sharing options...
zenataomm Posted February 28, 2016 Report Share Posted February 28, 2016 Each to their own, I won't own a car with a rubber belt controlling the essentials .... I certainly wouldn't want to stand on my head and try to maintain one in a boat. Cam Belts? ...... Sham Belts! Link to comment Share on other sites More sharing options...
Bee Posted February 28, 2016 Report Share Posted February 28, 2016 Peugeot diesels are quite common in smaller boats abroad, for marinisation parts I would start by looking at Lancing marine on google. Link to comment Share on other sites More sharing options...
bargemast Posted February 28, 2016 Report Share Posted February 28, 2016 The engine I have is out of a Citron Xantia, an 1.9 XUDTE. This is a turbo engine, but no electronics. I was told that I could leave the turbo off as it would only kick in on high revs and the engine would run ok under 2000. Here is some more technical information about the Peugeot/Citroën (PSA) engines supplied by a french company named "Seenergie" http://www.moteur-seenergie.fr/photos_clients/58/121227122423.pdf suralimentée = turbocharged. Peter. Link to comment Share on other sites More sharing options...
DHutch Posted February 29, 2016 Report Share Posted February 29, 2016 We have just taken an XUD engine out of a boat, it had a PRM 150 box on it with a proper manufactured adapter plate on it (not home made) and the engine was marinised properly, so the bits must be available....Do you have them to sell....? Peugeot diesels are quite common in smaller boats abroad, for marinisation parts I would start by looking at Lancing marine on google.I was going to say, its a project I have known been done before, and Lancing marine are I think the national knowlage pool for such automotive conversions, including the XUD and other common engines. The similar vintage 1.9 VW nat-asp engine is another common one I think. Daniel Link to comment Share on other sites More sharing options...
jimfin Posted February 29, 2016 Author Report Share Posted February 29, 2016 Think this is what I hope to get to at the end of project. Link to comment Share on other sites More sharing options...
BEngo Posted February 29, 2016 Report Share Posted February 29, 2016 Good Luck. Ensure that the turbo is well shielded from anything flammable- it will be bright red hot when it's going anything more than gently. N Link to comment Share on other sites More sharing options...
peterboat Posted February 29, 2016 Report Share Posted February 29, 2016 I wouldnt worry to much about the turbo most of the time you will be running at low rpm. I have thought of adding one to my engine to improve power at higher rpm Link to comment Share on other sites More sharing options...
W+T Posted February 29, 2016 Report Share Posted February 29, 2016 Good Luck. Ensure that the turbo is well shielded from anything flammable- it will be bright red hot when it's going anything more than gently. N I have used these engines a few times, even fitted one in a Suzuki SJ for off roading, so got some stick and never have i seen it, or had the turbo glow red hot, even been wading in 4 foot of water and engine covered in water Towed a caravan over 120 miles and still not glowed. These engine are great IMO, But i would get a NA engine and fit that, no need for the Turbo, I ran the XUD in mine with just 3 wires, glow plug, fuel solenoid and starter motor. 1 Link to comment Share on other sites More sharing options...
Neil Smith Posted March 2, 2016 Report Share Posted March 2, 2016 (edited) How did you charge the battery to work the winch? Neil Edited March 2, 2016 by Neil Smith Link to comment Share on other sites More sharing options...
Alan de Enfield Posted March 2, 2016 Report Share Posted March 2, 2016 I am wondering if the engine could be "de-turbo'd" for the boat application? They did many variations of this engine, some without turbo, for example the 1.8 XUD7TE has 90bhp but the XUD7/K has no turbo, and produces 60bhp. If there's non-turbo versions then the relevant inlet and exhaust manifolds, and possibly other parts, will be out there. Many boats have turbo engines, and / or larger HP engines, the OP is not on the English canal system so may just be looking to power a boat that needs the extra 'oompf'. I have seen a few marinised Pug engines in 'River' cruisers, one recently that was marinised by a car mechanic but 'not quite finished' due to a problem with parts. For Pug marinisation parts look at pages 13 & 15 of the attached Marinisation Parts & Price List.pdf Link to comment Share on other sites More sharing options...
W+T Posted March 2, 2016 Report Share Posted March 2, 2016 How did you charge the battery to work the winch? Neil Alternator charges the battery. Link to comment Share on other sites More sharing options...
jimfin Posted March 3, 2016 Author Report Share Posted March 3, 2016 This all started about 3 years ago, when I was having problems with our BMC 1.8. I got the XUD out of a Citroën Xantia a friend had. I helped him take it out of the car after we had fired it up after it had been sitting for 6 months, and it sounded sweet. I have been in touch with Lancing Marine and found them were helpful. But new parts are expensive. I got the heat exchanger, water pump and new belts etc. on eBay, and then lost interest as my BMC got well again. Turned out the BMC was OK but a rope around the prop did not help the performance. I have now hopefully fully sorted the BMC. See http://www.canalworld.net/forums/index.php?showtopic=80288 Last week I was on eBay again, as you do, and spotted an XUD bell housing. I could not resist and now the project has awakened again. Link to comment Share on other sites More sharing options...
Paul C Posted March 3, 2016 Report Share Posted March 3, 2016 This all started about 3 years ago, when I was having problems with our BMC 1.8. I got the XUD out of a Citroën Xantia a friend had. I helped him take it out of the car after we had fired it up after it had been sitting for 6 months, and it sounded sweet. I have been in touch with Lancing Marine and found them were helpful. But new parts are expensive. I got the heat exchanger, water pump and new belts etc. on eBay, and then lost interest as my BMC got well again. Turned out the BMC was OK but a rope around the prop did not help the performance. I have now hopefully fully sorted the BMC. See http://www.canalworld.net/forums/index.php?showtopic=80288 Last week I was on eBay again, as you do, and spotted an XUD bell housing. I could not resist and now the project has awakened again. What kind (and size) of boat is it going into? Link to comment Share on other sites More sharing options...
Alan de Enfield Posted March 3, 2016 Report Share Posted March 3, 2016 What kind (and size) of boat is it going into? Sounds like its not planned to go into anything - just an engine 'project'. Link to comment Share on other sites More sharing options...
jimfin Posted March 3, 2016 Author Report Share Posted March 3, 2016 Sounds like its not planned to go into anything - just an engine 'project'. I can't help it. I'm a project man!!! Did not want to not finish it. Link to comment Share on other sites More sharing options...
Paul C Posted March 3, 2016 Report Share Posted March 3, 2016 I am wondering if the Peugeot would offer a worthwhile increase in refinement over the BMC? Link to comment Share on other sites More sharing options...
jimfin Posted March 3, 2016 Author Report Share Posted March 3, 2016 I was thinking along the lines of less noise and reliability. The power was not the main consideration when I started this project. Link to comment Share on other sites More sharing options...
