MagicSat tracking mechanism
RLWP
I usually have an 'interesting' job on as well as engines and gearboxes. This time it's part of a MagicSat salletite dish mechanism:
The dish and the cover are missing, I didn't need them for this
This is the elevation motor:
The problem the owner was getting was, when the system began to lift the dish, it would stop and show an error code.
The dish is attached to the upper shaft in this mechanism. The bronze wheel is driven by the worm at the bottom, which is pegged to the shaft of the motor on the far side
The owner had worked out that, if they turned the worm by hand, it would be free for half a revolution, then went very tight stalling the motor
This is the worm:
Quite a nice installation, needle roller and thrust bearings each end.
The shaft and bearings:
I was pretty sure what the problem was, putting the shaft in the lathe confirmed it:
http://www.primrose-engineering.co.uk/wp-content/uploads/Bent-shaft.mp4
The shaft is bent. The puzzle then is how a nearly half inch shaft could get bent!
The solution is that the end of the shaft is drilled for the spindle for the motor. Now, the motor shaft is around 10mm long, the hole in the worm shaft?:
over 28mm. In fact, long enough to drill into the worm part itself:
That's an 8mm hole in a 12mm shaft. To make it more interesting, there's an undercut at the end of the bearing surface:
Instead of a solid 12mm shaft, at this point the worm is supported by a tube, 11.6mm OD with an 8MM bore. Not enough
I'm going to bore out the worm and mount it on a new solid shaft - with a shallow hole drilled in the end
Richard
Edited by RLWP
Interesting, and a well engineered piece of kit. But how on earth did the shaft get bent?
A worm and wheel mechanism can create quite a separating force between the two parts. Apart from the too deep hole, all the components are very nicely proportioned - including the 12mm shaft and bearings
Richard
Didn't Richard just explain that? At one section the shaft is 11.6mm diameter with an 8mm hole leaving only 1.8mm of "meat". The nature of the worm drive is that a force on the dish elevation cog translates partly into a bending force on the worm, clearly enough to bend the shaft. I wouldn't be surprised if a close inspection didn't reveal a circumferential crack at the weak point.
Maybe the dish whacked a bridge etc when it was elevated.
Richard
One wonders if they are all like that, or whether the machinist looked away at the wrong moment on that one
So, fixing it. First off was to cut off the ends:
This gives some idea of the tube supporting the worm, rather than a solid shaft:
Parting the shaft off threw up a burr on the inside of the hole, it's actually thinner than it looks here
Next up, put the worm in the lathe:
I'm using an aluminium split collet here to hold the worm. It holds it true without damaging the 'thread'
Then drill and ream the worm:
ready for a new 12mm shaft:
And the finished component:
I decided to bore out the worm completely rather than fitting a stub into one end as this way I can guarantee the ends are concentric
This is the altitude mechanism installed back on the mechanism, next to the azimuth wheel
Richard
Richard, could you have made the shaft a thou or two bigger, heated up the worm and had an interference fit?
I could have made the hole a little smaller and used a push fit, and it isn't worth it. Modern adhesives are very effective for this kind of job
Richard
Interesting and very good work, but to me it seems like a lot of effort to fix what's actually a rather expensive and over-engineered solution for setting up a satellite dish. Considering it usually takes about 5 minutes to set them up manually.
Just my opinion for what it's worth.
Edited by blackrose
Ah, "proper" engineering. These days it can be hard to find someone to do this kind of work. I'm sure it leads to our "throw away" culture.
Well done to Richard, and also the owner, who got it repaired rather than simply replacing it.
I wonder is this is all down to quality control, and a sloppy supplier over drilling the hole?
Also surprises me slightly that that the solution was not to contact the manufacturer and have them sorted it, although if nothing else I guess if you have the kit the time to spin the the new parts is actually fairly reasonable.
Personally I solve the 'issue' by not having a TV on the boat, but each to the own, and certainly I have no issue with these such devices existing and having seen one in the flesh running with a clear dome, can vouch for the overall high quality of the item.
Daniel
The suppliers solution was to sell a new base for around £1000
Richard
They where not up for 'sod off, this is clearly as design/wulity issue of yours, I'll give you £50 for a new worm wheel' then? The gits.
How old is the unit, approx usage?
Daniel
Since Rolls Royce nearly downed an Airbus 380 with an oil pipe that was drilled visibly off-centre, nothing surprises me anymore.
MP.
  • 3 weeks later...
Excellent thread Richard, have enjoyed following it.
It's always good to observe an engineer at work.
In a different hobby I restore antique amusement machines and regularly use modern adhesives and epoxy putties.
Have you a favourite type/brand?
Cheers
