jenevers Posted May 23, 2015 Report Share Posted May 23, 2015 When I stop my engine, I always leave it ready to start next time. That's to say I push the cold start button up, decompresser lever on, and accelerator with a few revs on etc. Is this bad practice? Link to comment Share on other sites More sharing options...
steamraiser2 Posted May 23, 2015 Report Share Posted May 23, 2015 Nope! Link to comment Share on other sites More sharing options...
jenevers Posted May 23, 2015 Author Report Share Posted May 23, 2015 (edited) Nope! Phew! Thanks? Edited May 23, 2015 by jenevers Link to comment Share on other sites More sharing options...
jonesthenuke Posted May 25, 2015 Report Share Posted May 25, 2015 Alternative question then. I never use the cold start button. Should I? Engine always starts immediately. Link to comment Share on other sites More sharing options...
Timleech Posted May 25, 2015 Report Share Posted May 25, 2015 Alternative question then. I never use the cold start button. Should I? Engine always starts immediately. If you don't need it, don't use it. Tim Link to comment Share on other sites More sharing options...
Cloudinspector Posted May 25, 2015 Report Share Posted May 25, 2015 I never use the cold start button either. Our 2LW starts easy every time. I guess it helps having a radiator in the engine room so it never gets too cold. Link to comment Share on other sites More sharing options...
jenevers Posted May 26, 2015 Author Report Share Posted May 26, 2015 Alternative question then. I never use the cold start button. Should I? Engine always starts immediately. Good question. By force of habit, I always use cold start and decompression just because I think it's easier on the battery, offering less resistance etc. I'll try not using either and see what happens. Btw the Bosch 220 ah starter battery is at least 12 years old. Link to comment Share on other sites More sharing options...
by'eck Posted May 26, 2015 Report Share Posted May 26, 2015 Good question. By force of habit, I always use cold start and decompression just because I think it's easier on the battery, offering less resistance etc. I'll try not using either and see what happens. Btw the Bosch 220 ah starter battery is at least 12 years old. Using decompressors is probably not easier on the battery as you have to turn engine over longer. A means to an end with near flat battery though. Link to comment Share on other sites More sharing options...
LEO Posted May 26, 2015 Report Share Posted May 26, 2015 Look lads - it's a Gardner, stop the engine, when it stops push the 'stop lever' back into start position, Before starting, check the oil open the throttle a bit and 'hit the button', it starts first time. Ledgendary Engineering excellence! L. Link to comment Share on other sites More sharing options...
Timleech Posted May 26, 2015 Report Share Posted May 26, 2015 Look lads - it's a Gardner, stop the engine, when it stops push the 'stop lever' back into start position, Before starting, check the oil open the throttle a bit and 'hit the button', it starts first time. Ledgendary Engineering excellence! L. I need to use the cold start button (for a cold start) on my 4LW because there is a heavy alternator load almost immediately, without the excess fuel the engine will fire but not pick up. Tim Link to comment Share on other sites More sharing options...
