swift1894 Posted May 7, 2015 Report Share Posted May 7, 2015 (edited) In dry dock at the moment and noticed about 5 degrees of circular "play" in the propeller when in neutral. Is that acceptable/normal in a Gardner 2UC? Edited May 7, 2015 by swift1894 Link to comment Share on other sites More sharing options...
John Williamson 1955 Posted May 7, 2015 Report Share Posted May 7, 2015 (edited) If it's in neutral, normally, the prop should be free to turn continuously, as there's no connection between it and the engine. I'm not familiar with that box, does it have a propshaft brake? Edited May 7, 2015 by John Williamson 1955 Link to comment Share on other sites More sharing options...
swift1894 Posted May 7, 2015 Author Report Share Posted May 7, 2015 If it's in neutral, normally, the prop should be free to turn continuously, as there's no connection between it and the engine. What gearbox is fitted? Some of them have a propshaft brake, which could give the symptom you describe. I can turn it freely but there's just 5 degrees of free loose movement before I can feel any resistance. It's a Gardner 2UC box. Link to comment Share on other sites More sharing options...
John Williamson 1955 Posted May 7, 2015 Report Share Posted May 7, 2015 Ah. You may have some play in the outlet shaft splines, or the box may just need adjusting. I'd have to be there and feel it ,myself to tell for sure. :-( Link to comment Share on other sites More sharing options...
Timleech Posted May 7, 2015 Report Share Posted May 7, 2015 Ah. You may have some play in the outlet shaft splines, or the box may just need adjusting. I'd have to be there and feel it ,myself to tell for sure. :-( I don't think you can have ever seen a 2UC box As with a similar question about a Blackstone box a little while ago, it's very hard to give any constructive judgment at a distance. 5 degrees could be at the top end of what's acceptable, but are there any symptoms which give rise for concern? Tim Link to comment Share on other sites More sharing options...
John Williamson 1955 Posted May 7, 2015 Report Share Posted May 7, 2015 For a fiver, the OP can download or buy a reprint of the manual. Link to comment Share on other sites More sharing options...
swift1894 Posted May 7, 2015 Author Report Share Posted May 7, 2015 (edited) For a fiver, the OP can download or buy a reprint of the manual. No need cos I've got an original manual Hmm. Section 23 Checking Backlash of Bevel Gears.......maybe the answer's in there somewhere. I'll have a read. I don't think you can have ever seen a 2UC box As with a similar question about a Blackstone box a little while ago, it's very hard to give any constructive judgment at a distance. 5 degrees could be at the top end of what's acceptable, but are there any symptoms which give rise for concern? Tim 5 degrees could be at the top end of what's acceptable, but are there any symptoms which give rise for concern? Tim No everything is fine. Just wondered if there should be any free movement in the prop shaft. Edited May 7, 2015 by swift1894 Link to comment Share on other sites More sharing options...
John Williamson 1955 Posted May 7, 2015 Report Share Posted May 7, 2015 Fore and aft, no, even if there is a plummer block. Laterally, no. There will be a tolerance for rotational slackness, and that will be in the manual. Link to comment Share on other sites More sharing options...
RLWP Posted May 7, 2015 Report Share Posted May 7, 2015 Just wondered if there should be any free movement in the prop shaft. Yes, it's inevitable. The various gears always run with some clearance, the diameter of the propeller and the ratio of the reduction box magnifies this Richard Link to comment Share on other sites More sharing options...
swift1894 Posted May 8, 2015 Author Report Share Posted May 8, 2015 Fore and aft, no, even if there is a plummer block. Laterally, no. There will be a tolerance for rotational slackness, and that will be in the manual. The play is only rotational. The section on this in the manual is far too complicated for me to even think about trying to measure, not having the instrumentation required. Link to comment Share on other sites More sharing options...
swift1894 Posted May 8, 2015 Author Report Share Posted May 8, 2015 Yes, it's inevitable. The various gears always run with some clearance, the diameter of the propeller and the ratio of the reduction box magnifies this Richard Thanks, that's reassuring to know. I wasn't particularly worried but I just like to check things like this to increase my knowledge so I can "nip things in the bud" in case things are going wrong. Link to comment Share on other sites More sharing options...
