jenevers Posted March 20, 2015 Report Share Posted March 20, 2015 my manual issue (44.1) says" use an extreme pressure heavy gear oil of MINERAL base. But mine has SYNTHETIC 75W-90 (API GL-5). Will that be OK? Link to comment Share on other sites More sharing options...
Flyboy Posted March 20, 2015 Report Share Posted March 20, 2015 I think you may have answered your own question. Stick to the oil recommended by the gearbox maker. There are corrosion issues with some gear oils where gearboxes contain yellow metal parts. Link to comment Share on other sites More sharing options...
jenevers Posted March 23, 2015 Author Report Share Posted March 23, 2015 (edited) I think you may have answered your own question. Stick to the oil recommended by the gearbox maker. There are corrosion issues with some gear oils where gearboxes contain yellow metal parts.Hmm. Well I wonder if synthetic oils were around in 1945 when my gearbox was built. Reading this http://www.machinerylubrication.com/Read/167/synthetic-gear-oil tends to make me feel that synthetics are probably better than mineral oils. I know what the manual recommends...... But it also recommends changing the oil every 4 months!!!!! And, is there any yellow metal in a 2UC reducing gear? Edited March 23, 2015 by jenevers Link to comment Share on other sites More sharing options...
PeterG Posted March 25, 2015 Report Share Posted March 25, 2015 So I would say the two things I think could cause you problem with a synthetic oil is if water gets into the oil which can then cause corrosion or a bad reaction with some of the component parts which make them degrade. On the balance I would say if you can use the recommended oil why do you need to change and take the risk of the potential side effects causing you a problem. The changing the oil every 4 months would only be for a very heavy set of operating conditions which you would not have a chance of seeing so can be forgotten. Link to comment Share on other sites More sharing options...
swift1894 Posted March 25, 2015 Report Share Posted March 25, 2015 (edited) So I would say the two things I think could cause you problem with a synthetic oil is if water gets into the oil which can then cause corrosion or a bad reaction with some of the component parts which make them degrade. On the balance I would say if you can use the recommended oil why do you need to change and take the risk of the potential side effects causing you a problem. The changing the oil every 4 months would only be for a very heavy set of operating conditions which you would not have a chance of seeing so can be forgotten. But wouldn't water getting into a mineral oil be just as bad? The manual states " if there is any indication that water may have entered the gear case, immediately drain and flush out repeatedly with oil until all traces of water have been removed". Edited March 25, 2015 by swift1894 Link to comment Share on other sites More sharing options...
PeterG Posted March 27, 2015 Report Share Posted March 27, 2015 No in synthetic oils the water gets chemically bonded which reduces the lubricating ability of these oils under loads seen in gearboxes such as this, unlike the traditional (old fashioned) petroleum based oils which do not chemically bond with the water. This is not seen in engines as the loading is of a different type and hence why you do not run an engine on an EP oil. 1 Link to comment Share on other sites More sharing options...
swift1894 Posted March 29, 2015 Report Share Posted March 29, 2015 (edited) No in synthetic oils the water gets chemically bonded which reduces the lubricating ability of these oils under loads seen in gearboxes such as this, unlike the traditional (old fashioned) petroleum based oils which do not chemically bond with the water. This is not seen in engines as the loading is of a different type and hence why you do not run an engine on an EP oil. Thanks for the info. All interesting stuff. Synthetic drained and replaced with mineral based oil! Edited March 31, 2015 by swift1894 1 Link to comment Share on other sites More sharing options...
