Glennbrown Posted February 6, 2005 Report Share Posted February 6, 2005 Finished the 240v ring main and ready to install a RCD unit Does any one know what fuse rating I need to buy with this unit?. Landline shall only feed ring main and Charger. What type of wire should I run from the the pluggy bit from the land line to this unit? What about the earths ? Thanks All Glenn Link to comment Share on other sites More sharing options...
stuart Posted February 6, 2005 Report Share Posted February 6, 2005 (edited) You need to work out how much current (Amps) will be carried through the ring to each appliance. Keep in mind that most land-lines at marinas already have fuses in them to stop you drawing too much current. The cable to the RCD unit must be suitable for carrying the whole expected current and greater than the fuse proctecting the ring main. Normally 2.5mm 3 core arctic mains cable will do the job. Link to Screwfix I purchased a small RCD unit similar to this one... Link here For the earths I've used a solid connector block with lots of screw down terminals where all the earths join together. This is linked by a heavy earth gauge wire to the bus-bar in the RCD unit. Edited February 6, 2005 by stuart Link to comment Share on other sites More sharing options...
Guest Posted February 7, 2005 Report Share Posted February 7, 2005 We did similar with same unit rom Screwfix. 16amp breaker for sockets and 6amp for charger. 2.5mm should be OK for land line, we also used arctic flex. Link to comment Share on other sites More sharing options...
Glennbrown Posted February 7, 2005 Author Report Share Posted February 7, 2005 (edited) Thanks Guys Stuart, you said all the earths presume you mean in my case the ring main earths and the earth to the charger and any 240v other circuits I may install? Do these earths bond to the steel shell as well ?. If How and where? Thanks for your help. Glenn Edited February 7, 2005 by Glennbrown Link to comment Share on other sites More sharing options...
stuart Posted February 7, 2005 Report Share Posted February 7, 2005 Thanks Guys Stuart, you said all the earths presume you mean in my case the ring main earths and the earth to the charger and any 240v other circuits I may install? Do these earths bond to the steel shell as well ?. If How and where? Thanks for your help. Glenn <{POST_SNAPBACK}> Yes. Just wire a heavy gauge earth cable from the earth "ring" to the hull. Use the crimp connectors with a hole in them and use a self tapper screw to the inside of the hull. Pick a point that you can drill through without going through the hull eg. a strengthing beam etc. Rub the area down with wet&dry paper first so that you have clean shiny metal to make a good contact. No paint etc. Link to comment Share on other sites More sharing options...
Glennbrown Posted February 7, 2005 Author Report Share Posted February 7, 2005 Thanks Stuart Glenn Link to comment Share on other sites More sharing options...
Richard Bustens Posted February 7, 2005 Report Share Posted February 7, 2005 I dont think you connect the earth to the hull. But you need to check the regs to be sure. Link to comment Share on other sites More sharing options...
Gary Peacock Posted February 8, 2005 Report Share Posted February 8, 2005 Hi You do need to connect the Earth to the hull to meet the regs in europe. "BUT" there are often arguments over if this should be done and in certain other parts of the world it is considered dangerous! Gary Link to comment Share on other sites More sharing options...
Guest Posted February 8, 2005 Report Share Posted February 8, 2005 To earth the hull or not-that one again! I have earthed the hull on ours purely out of instinct. I can see both sides of the argument. Link to comment Share on other sites More sharing options...
DHutch Posted February 8, 2005 Report Share Posted February 8, 2005 There a big long thread about earths to the hull or not, but imo you should conect all the earths, and the -ve of you low voltage ring to the hull, thats whay we've dont, and never had a problem. (and were not using an galvantic isolator) daniel Link to comment Share on other sites More sharing options...
