mark99 Posted October 11, 2014 Report Posted October 11, 2014 Perhaps we can now have a 3-day argument over what it's called......... Or a whole week if you ask what knot should a Cmer use?
FadeToScarlet Posted October 11, 2014 Report Posted October 11, 2014 Or a whole week if you ask what knot should a Cmer use? A Gordian knot.
keble Posted October 11, 2014 Report Posted October 11, 2014 (edited) A bow, like tying a shoe lace looks very nice but difficult to tie with only one ropes end. It can be done though by dividing it into two loops. Seriously, did you know there's a right way and a wrong way to tie shoe laces? I spent a large part of my life doing them wrong! Then I found http://www.fieggen.com/shoelace/tying.htm and buried in there (ignore fancy stuff) is a very simple change. My life has changed .... Edited to show proper URL Edited October 11, 2014 by keble
Barry Posted October 11, 2014 Report Posted October 11, 2014 Seriously, did you know there's a right way and a wrong way to tie shoe laces? I spent a large part of my life doing them wrong! Then I found http://www.fieggen.com/shoelace/tying.htm and buried in there (ignore fancy stuff) is a very simple change. My life has changed .... Edited to show proper URL Me too! My laces stay done up now that I have learned to tie them reef knot fashion rather than as a granny knot. No more double knots needed so I can untie them quickly too Pity it took me fifty years or more to find it out
bizzard Posted October 11, 2014 Report Posted October 11, 2014 Trainers, cheap ones at any rate often come with laces twice as long as they need to be and need multiple doubled up bows just to get rid of it.
Scholar Gypsy Posted October 12, 2014 Report Posted October 12, 2014 Can I add a vote for the bowline, which I don't think has been mentioned thus far? Useful for dropping over large bollards, or tieing on to mooring rings, or to mooring pins with a ring on, and then tightening the rope using a tugboat/lightermans hitch at the other end.
mark99 Posted October 12, 2014 Report Posted October 12, 2014 (edited) I use the hangmans noose on the centre stud. And a version of the lightermans for the bollard which I cant describe (only demonstrate) as it involves twisting of the hands. Edited October 12, 2014 by mark99
Tam & Di Posted October 12, 2014 Report Posted October 12, 2014 I use the hangmans noose on the centre stud. And a version of the lightermans for the bollard which I cant describe (only demonstrate) as it involves twisting of the hands. I'd be surprised if you use a proper hangman's noose - it is quite a complex knot to make. I assume you mean you do use some sort of slipknot rather than perhaps a bowline, but what is the point of that? Tam
bizzard Posted October 12, 2014 Report Posted October 12, 2014 (edited) A hangmans noose is ok if your thinking of heading west. Edited October 12, 2014 by bizzard
mark99 Posted October 12, 2014 Report Posted October 12, 2014 (edited) I'd be surprised if you use a proper hangman's noose - it is quite a complex knot to make. I assume you mean you do use some sort of slipknot rather than perhaps a bowline, but what is the point of that? Tam It's a hangmans noose and it is not that complicated. Picture below. If you want complicated, try a bimini twist knot. ETA I change knots all the time - I'm not suggesting this is the best one or even a logical choice. Last week I had a bowline on the stud. I just like knots! Edited October 12, 2014 by mark99
ditchcrawler Posted October 12, 2014 Report Posted October 12, 2014 It's a hangmans noose and it is not that complicated. If you want complicated, try a bimini twist knot.
Dharl Posted October 13, 2014 Report Posted October 13, 2014 I once sent a young apprentice to Woolworths for some "sky hooks". The trouble was he came back about 45 minutes later.....with some. They were something to do with holding curtains up. I just said "Thanks very much". Rob.... Got him out of your hair for 45 mins though....
ditchcrawler Posted October 13, 2014 Report Posted October 13, 2014 I don't think I would want to try it on a center line
John V Posted October 13, 2014 Report Posted October 13, 2014 Thanks for showing that one...I've never seen it before !
Dharl Posted October 14, 2014 Report Posted October 14, 2014 Can I add a vote for the bowline, which I don't think has been mentioned thus far? Useful for dropping over large bollards, or tieing on to mooring rings, or to mooring pins with a ring on, and then tightening the rope using a tugboat/lightermans hitch at the other end. cant believe I left bowline off my list!! must be getting old! I did hear a tale that it is illegal to use a hangman's noose if it had 13 turns in it. 12 OK, and 14 but 13 a big no no! Never to sure if that was true or not, but was taught to tie it in the Sea Scouts using only 10 turns!!
Mike Tee Posted October 14, 2014 Report Posted October 14, 2014 cant believe I left bowline off my list!! must be getting old! I did hear a tale that it is illegal to use a hangman's noose if it had 13 turns in it. 12 OK, and 14 but 13 a big no no! Never to sure if that was true or not, but was taught to tie it in the Sea Scouts using only 10 turns!! If properly tied in real hemp, (which I've never done, only for fun in modern rope) I understand it will pull tight but will not slip back undone, so needs to be cut off. I'd ask Albert P. but I don't think he's a member on here!
furnessvale Posted October 14, 2014 Report Posted October 14, 2014 If properly tied in real hemp, (which I've never done, only for fun in modern rope) I understand it will pull tight but will not slip back undone, so needs to be cut off. I'd ask Albert P. but I don't think he's a member on here! Not that he ever used that knot mind. George ex nb Alton retired
mark99 Posted October 14, 2014 Report Posted October 14, 2014 (edited) Not that he ever used that knot mind. George ex nb Alton retired The gallows noose cause strangulation. Hangmans noose helped break the neck. Not sure what Albert P used. Edited October 14, 2014 by mark99
Mike Tee Posted October 14, 2014 Report Posted October 14, 2014 Not that he ever used that knot mind. George ex nb Alton retired I guessed that - just a throwaway line. I believe a hard splice was made at the end of the rope (brass I think).
furnessvale Posted October 14, 2014 Report Posted October 14, 2014 I guessed that - just a throwaway line. I believe a hard splice was made at the end of the rope (brass I think). Yes I have seen photos of it. It looked like the sort of hard spliced eye, complete with thimble, that you see in a wire rope. George ex nb Alton retired
