Accumulator Fittings?
NorthwichTrader
 Share
I reckon that would do the job.
Another way would be with a 'flexible':
http://www.screwfix.com/p/wras-speedfit-hose-x-13mm/32762
http://www.screwfix.com/p/wras-hose-15mm-x-3-4in-x-500mm-x-10mm/65966
http://www.screwfix.com/p/wras-hose-15mm-x-3-4in-x-1000mm-x-10mm/31385 (tooo long?)
15mm compression end is a little cheaper and should go OK onto 15mm PEX pipe with a pipe insert and copper olive.
cheers, Pete.
~smpt
Edited by smileypete
Possibly. Otherwise something like http://www.plumbingplace.co.uk/hep2o-hx24-15-brass-adaptor-15x3-4-white.html sealed with ptfe or plumbajoint.
No, don't try anything with parallel threads that you attempt to seal with either PTFE tape or a jointing compound.
Best to leave that to sealing taper threads only - just don't ask me how I know this, though!
When I raised this before, I was assured that a tap connector was the way to go, (the seal then being to the flat end of the accumulator, with a washer, not by attempting to seal the threads.
Using a flexible tap connector as per smileypete's seems the way to go - and one day I will go back and change my own bodge, but probably not until it starts leaking!
That is pretty much the approach I had to take to the calorifier connections, which were parallel and too big for tap connector-type fittings. I agree it's not the best option though.
Yes but the spec of the accumulator says 3/4" BSP, so tap connector should fit it.
 Share
