Skip to content
Who is the best supplier of wood burning stoves?
Featured Replies
#1
We need a woodburner for our house out here in France, but french prices are ludicrous, so wonder who is the best supplier in the UK for a stove of up to 20 Kw, log burner only, with backboiler?
#2
Brocante ?
actually surprise me about 5 years ago I was looking at French stoves as I thought the quality and prices excellent Godin etc
Edited by John V
  • Author
#4
Thanks, somehow Prity had escaped my searches, they look interesting. Brocantes in the area haven't turned up any good models yet. Backboiler stoves seem to be quite rare in France.
#5
no worries, i hope you find something!!
#6
Try Robeys of Belper - ask for Malcolm
#7
We've got a portway inset stove at home (installed 3 years ago) and have been very pleased with it. Its used daily in the winter- good control and heat output, effective airwash, easy to clean and no issues so far
  • Author
#8
Thanks, just had a chat with him, he is very helpful.
#9
If I was buying a woodburner with back boiler it would have to be Woodwarm and the wildwood 20kw.
http://www.woodwarmstoves.co.uk/products/wildwood-range/20kwwoodburner.ashx
http://www.connexionfrance.com/Heat-any-home-with-a-Woodwarm-stove-10483-advertorial-view.html
Not cheap but quality as the boilers are replaceable when years to come they start to leak! On 99.9% of stoves the boiler is part of the stove body, ie integral boiler so once it leaks it's new stove time. Woodwarm just buy a replaceable boiler only.
I have the baby 4.5kw fireview on my narrow boat and love it.
In my opinion superbly made in Devon, double glazed door and superbly controllable.
Here is a 20kw fireview burning but without the back boilers. The wildwood has different lower styling but same body as the fireview.
https://www.youtube.com/watch?v=kXxBNo855xs
Make sure to size the boiler load required and the room heat required too as if you install the stove with a room heat output greater than the room it's in needs, you will roast or turn down the stoves air supply to make it throw out less heat but in doing so reduce the boiler output in doing so. It has to be a balancing act. If the stove produces less room heat than the room requires you can always install a radiator in the same room as the stove.
We heated a 3 bed stone house in Normandy with a villager A range ALI. It was rated 13kw to the boiler and approximately 5kw to the room. It was in a big 35 sqm room with a 3.4m heigh ceiling and got it very warm and heated 11 rads. It was a budget UK made stove. Did the job but the glass got dirty, have to clean every day and got through 20 cubic metres of mixed wood over 7 months of winter. Would stay in with the optional flue damper on 3 large logs but if I was buying again, no doubt a Woodwarm!
Edited by canals are us?
Recently Browsing 0
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
