Sign in to follow this
jockwalt
onan generator
Is this a real product?
Available from onanists everywhere, no doubt, and especially suitable for single-handers.
Share this post
iam thinking of fitting a 7kw mod any one have one fitted on there boat thanks jockwalt
Yes, I have an (Cummins) Onan 7.0MDKBL (with acoustic housing) fitted to my barge. Superbly quiet and nice bit of kit. Not cheap though, but quieter and smoother than the equivalent Beta model. The only issue that I have with it is that it seems to be destroying the impeller of its raw water pump very quickly and Onan Technical are trying to get to the bottom of this mystery. They have sent me a new pump to try which will be fitted next season when we get back to France. I presume that you intend to fit it to a barge rather than a narrow boat as it is quite large (physical size) to fit in a narrow boat.
Roger
Edited by Albion
Share this post
We have a 6,5 kW Onan generator (Kubota) installed under the aft cabin floor. With the acoustic foam insulation and a large exhaust silencer it is remarkably silent.
Helen
Share this post
No we used 240 v I was in the royal signals and used to service the previous version of this genny
Peter
Another Scaley. Greetings and Certa Cito.
Twin Onans and a D11 radio - true heaven. Plus a techy to fix the radio.
Share this post
Roger
See if you can get a "Globe" impeller. They are much tougher.
Share this post
We have an Onan MDKBK 7kva without the factory sound shield as it is much smaller. It is fitted on the swim on the lhs with sound proofing on the underside of the flooring. Remote start in the kitchen.
Share this post
Cheers Kevin, I'll have a look for one of those. I've been using genuine Onan impellers for the Sherwood (?) raw pump (and the latest version which Onan claims is more pliable). However, I have had two impellers (including the one delivered from new with the genny take a small chunk out of the centre of a blade and, on another blade, take a small chunk out of the end in less than 40 hours running each. Onan have sent a ruined impeller back to Sherwood for investigation but I haven't heard any results yet.
Roger
Edited to add that I have found the correct Globe impeller for my Onan with Sherwood G702-01 pump but they don't seem to have a UK dealer or distributor listed on their site. Have you ever sourced one here?
Edited by Albion
Share this post
I know its only 5Kva but if you dont really need 7Kw its worth considering, neat, tidy 'all in one' and a fair price.
http://www.anchorsupplies.com/tools-hardware/generatos.html
It's not a marine generator - could be noisy.
For me a noisy generator is a useless bit of kit because it's a pain in the arse for everyone concerned - and their neighbours.
If money was no object I'd have one of these: http://www.northern-lights.com/marine/M673LD3.html
They do bigger models too, but the 5kw should be more than enough for anyone on a canal forum!
Brochure: http://www.northern-lights.com/PDFs/brochure_pdfs/spec_sheets/Marine/M673LD3.pdf
Edited by blackrose
Share this post
unless one gets tired, then the other can be used.
no grunting noises?
public school - eh?
yes
great -it was sucessful then!
no no no, that's caused by something entirely different!
Edited by billS
Share this post
no grunting noises?
public school - eh?
yes
13yrs in R. Sigs HF radio actually.
Share this post
