Red Diesel
Big COL
Hi
With all the problems with Eberspacher heaters i rung up Shell last week, eventually i was put through to there marine oil devision and was told by a man there categorically that there is no such thing as diesel what we buy from the petrol station and marina's is gas oil and there is only one grade of this and has been for donkeys years, red die is added to donate the tax status but it is the same stuff.
There is a marine fuel that has a higher flash point, but he said it is very unlikely that we would be getting that from marinas as it was sold bulk by tanker to the boats in docks, and the difference would not be noticeable.
Someone is telling porkies, either the fuel Co or Eberspacher.
I give up, the only logical thing can be is the way the boat yard and or the boat owner stores the fuel
Hi Richard,
I get the distinct feeling the chap who wrote the article works for the company who manufacture "Fuel Set" the additive recommended by Eberspacher. They actually supply it "free" with the units now.
So your suspicions may be correct.
However we fit split tanks on our boats and the heaters running on kerosene or DERV fuel do seem to be more reliable.
The Victron Whispergen definitely doesn't like red diesel either and becomes very labour intensive when run on it.
I used to work with bulk fuel supply and the grades of fuel did vary depending on requirement, but I think we could do with some more facts from the fuel suppliers on this.
Gary
Hi
Just to add to the confusion, long time ago I fitted quite a few boat engines and got to know and hate the red stuff. I then worked on the cross Channel ferry steamers, Weymouth to Channel Islands, one of me jobs was to strip and clean the burners from the main boilers. Did this in a bucket of diesel fuel from the generators, this was hands in stuff and that fuel felt and smelt different to the red I knew. It felt “silky”, quite different to red and almost pleasant to use. There was no dye in it. It was also, I think, different to the DERV I use in me white van.
<_< Hi Col
I was always of the opinion that it was something to do with the driving test, if you passed they gave you a car and if you failed miserably you got a white van to play with, as a consolation prize  :D  :D
Jest if you must but things could be worse. Imagine living in a city with 1/2M people behind the wheels of cars, who couldnt pass water with out praying for guidance.
Don't knock the WVM compared to a Saudi driver he's a friggin' expert.
Don't know what the other site discussed but here's my bit on fuel quality.
If it's red its gas-oil, if it's white/yellow its derv (diesel for road vehicles). That’s the case now, it may not have been years ago.
Derv duty is paid when it's made and it is not then economic to colour it red because the extra duty paid over gas-oil would have to be reclaimed.
If you compare the two with petrol, then derv is 4* and gas oil is 2*
Eberspacher heaters are made to run on derv and they are not happy on gas-oil (because of the lower cetane rating or equivalent petrol * rating).
Fuel Set is an additive which they say alters the cetane number of gas-oil to make it more like derv. Fuel Set also allows water in the fuel to be "burnt" and no doubt does other things as well (so they say). I use it, but may be wasting my money, I don't know.
Rod Fox
Edited by enigma
I don't want to argue with Shell!
I will however stick to my statements above. Auto diesel (DERV) is made to BS EN590 and Gas Oil is made to BS 2869.
The web page below has the full product specification of the two:
http://www.cplpetroleum.co.uk/products.htm
Click on the links for DERV and Gas Oil
Rod Fox
I’m no x-spurt on this subject, but, <_< the way I read this over the years is, once upon a time DERV and RED were the same stuff, then things started to be done to DERV to alter the impact on the environment, so that today we have two distinct products, red, much like it used to be, and DERV with the low sulphur, etc. and stuff added to replace the sulphur, which the injection gubbins needs as a lubricant.
