Grace and Favour Posted August 4, 2013 Report Share Posted August 4, 2013 May I draw upon the wisdom of CWDF's electrical wizards, please? Come the day when we replace our battery banks, (with some Trojan 105's rather than the Numax we have currently) I shall follow one of Chris Gibson's wiring plans - with equal length tails going to bus bars. The configuration will be 12v. I shall also use the bars to receive the cables from the solar controller (fused at 400A) I've sourced some good, chunky copper bar, and will kit them with stainless steel studs for the cables. Does anyone know what level of insulation I require/(or where I may research it) - and what material may be best for the job, - please? Many thanks Dave Link to comment Share on other sites More sharing options...
Charlotte Burnett Posted August 4, 2013 Report Share Posted August 4, 2013 Or just buy Blue Sea bus bars with clip on covers. Link to comment Share on other sites More sharing options...
nicknorman Posted August 4, 2013 Report Share Posted August 4, 2013 I'm inclined to agree with Charlotte - that is by far the easiest and best way! However if you want to mount the bus bars on something, dry wood would be adequate. It will have a very tiny leakage current but that will be insignificant at 12v. But at least for the +ve bus bar, it will need to be covered to prevent accidental shorting and once again a proprietory covered bus bar is the best way to go. Link to comment Share on other sites More sharing options...
Grace and Favour Posted August 4, 2013 Author Report Share Posted August 4, 2013 Ah yes, purchasing a couple was my first thought But they tend to be rather expensive (I think) (Blue Sea bus bar) Link to comment Share on other sites More sharing options...
FadeToScarlet Posted August 4, 2013 Report Share Posted August 4, 2013 I put them in 240v plastic surface mount two gang plug boxes, with a cover over. Spaces easily pushed out for the 70mm^2 cables to enter, and an easily unscrewed and removed blank cover plate for access. Link to comment Share on other sites More sharing options...
Ex- Member Posted August 4, 2013 Report Share Posted August 4, 2013 I've used Heat Shrink in the past, the glued stuff is brilliant. All out battery connections go to single posts made from 10mm Brass studding & Brass nuts set into hardwood. They are then put inside ABS boxes. Really easy to make using off cut hardwood, You can make really nice ones using hardwood hole cutout waste sanded down and threaded, brass studding is pricey though but a lot cheaper than buying bus bars & posts. Link to comment Share on other sites More sharing options...
Charlotte Burnett Posted August 4, 2013 Report Share Posted August 4, 2013 WTF install do you have that you need 600A bus bars? Normally something like this is more than adequate http://compare.ebay.co.uk/like/221239685976?var=lv<yp=AllFixedPriceItemTypes&var=sbar&_lwgsi=y&cbt=y&device=c&adtype=pla&crdt=0&ff3=1&ff11=ICEP3.0.0&ff12=67&ff13=80&ff14=63&ff19=0 What output of solar do you have and with what controller? The biggest ones I know of are 80A Outback's. If you really do need to be fused that high then I would suggest you also need to run straight back to the batteries on the shortest possible length of 150mm2 or bigger cable. How many batteries are you charging? Is propulsion electric? I want to see this! Link to comment Share on other sites More sharing options...
GUMPY Posted August 5, 2013 Report Share Posted August 5, 2013 Personally I wouldn't use those bus bars for connecting batteries there are only two usable terminals. I use these http://pages.ebay.com/link/?nav=item.view&id=230400356291 Enclosed in abs boxes. Link to comment Share on other sites More sharing options...
by'eck Posted August 5, 2013 Report Share Posted August 5, 2013 (edited) I'm inclined to agree with Charlotte - that is by far the easiest and best way! However if you want to mount the bus bars on something, dry wood would be adequate. It will have a very tiny leakage current but that will be insignificant at 12v. But at least for the +ve bus bar, it will need to be covered to prevent accidental shorting and once again a proprietory covered bus bar is the best way to go. Although marine ply was used on my last boat to support high current battery studs well away from any damp, I would recommend something like thick nylon/plastic strip for a narrowboat plus a cover of course for postive bus. I do however agree that a propriety busbar is the best. I used these although I admit not cheap - there are 500 amp versions as well. Edited August 5, 2013 by by'eck Link to comment Share on other sites More sharing options...
luctor et emergo Posted August 5, 2013 Report Share Posted August 5, 2013 Am I the only one who read the topic title, and wondered why one would want to insult a bus bar? Yeah, thought so.. Link to comment Share on other sites More sharing options...
nicknorman Posted August 5, 2013 Report Share Posted August 5, 2013 Insulting a bus - definitely, they pull out just as you approach, lumber along at 20mph chucking out black smoke, stop at bus stops without bothering to pull into the side of the road, have squealing brakes etc etc and all whilst only carrying one person - an OAP who likes to spend their day travelling round and round on their free bus pass. What's not to insult? Bars on the other hand, are surely a good thing? Link to comment Share on other sites More sharing options...
dmr Posted August 5, 2013 Report Share Posted August 5, 2013 I am not at all convinced that bus bars are really necessary unless you want the personal satisfaction of creating the ultimate electrical system (and there is really nothing wrong with getting satisfaction from engineering projects!). A conventional arrangement with linking cables should be fine as long as you follow the basic rules such as taking positive and negative feeds from opposite ends of the bank. This is particularly true for Trojans where you will probably only have two "batteries" (each battery having two Trojans in series). I have checked the current balance on my installation (which has 35mm2 cables) using a good clamp on probe and it was spot on. .............Dave Link to comment Share on other sites More sharing options...
blackrose Posted August 5, 2013 Report Share Posted August 5, 2013 (edited) Ok, I'm going to admit my electrical ignorance here by asking what the difference is between using an expensive busbar, or just connecting all the 8mm ring terminals together on a 25mm x 8mm dia stainless nut & bolt with a stainless washer at each end and perhaps a couple of stainless spring washers? Of course, with the nut & bolt you can't disconnect any single terminal without dismantling the whole lot, but so what? How often do you disconnect these connections around batteries anyway? Do busbars have any other advantages? Edited August 5, 2013 by blackrose Link to comment Share on other sites More sharing options...
nicknorman Posted August 5, 2013 Report Share Posted August 5, 2013 (edited) Ok, I'm going to admit my electrical ignorance here by asking what the difference is between using an expensive busbar, or just connecting all the 8mm ring terminals together on a 25mm x 8mm dia stainless nut & bolt with a stainless washer at each end and perhaps a couple of stainless spring washers? Of course, with the nut & bolt you can't disconnect any single terminal without dismantling the whole lot, but so what? How often do you disconnect these connections around batteries anyway? Do busbars have any other advantages? Advantages: mainly because if you try to connect multiple ring terminals to one bolt, after the first few the crimped bit gets in the way and it won't all lie flat and at the very least you have to have the cables exiting in all directions,probably not the direction you want - definitely an issue with large section cable. You also may get lower resistance connectors since the current doesn't have to flow through all the intermediate ring terminals to get to the middle one (bearing in mind the connection to the threaded part of the bolt is not good). Looks neater? Well not an issue if you are not fastidious, until someone comes along and tries to work out what goes where. Edited August 5, 2013 by nicknorman Link to comment Share on other sites More sharing options...
RLWP Posted August 5, 2013 Report Share Posted August 5, 2013 I'm inclined to agree with Charlotte - that is by far the easiest and best way! However if you want to mount the bus bars on something, dry wood would be adequate. Slate is so much more attractive though Richard Link to comment Share on other sites More sharing options...
David Mack Posted August 5, 2013 Report Share Posted August 5, 2013 I'd like to see that in a trad engine 'ole! Link to comment Share on other sites More sharing options...
RLWP Posted August 5, 2013 Report Share Posted August 5, 2013 So would I! I bought some cheap bakelite meters, a couple of large wooden boxes and some ancient switched fuseboxes ages ago with the intention of doing that. The right boat hasn't turned up yet Richard Link to comment Share on other sites More sharing options...
Grace and Favour Posted August 5, 2013 Author Report Share Posted August 5, 2013 Thanks for the input, everyone . . . it has helped . I have seen Julynian's pics of his new battery set-up before - but the reminder was most useful, and I find myself drawn to making a similar cabinet to Richard's slate mount (though I think I'd need to frame it in Japanese Walnut picked out in Ebony - if I'm going OTT - then I'll go the whole hog!). Thanks also for the links to various bus-bars - and, Charlotte, the reason why I employed a 400A fuse on my Outback, was because that's what the wiring plan specified.... and the reasons why I am after heavy bus bars is that I like nice, tight electrical connections, particularly on batteries, and with studs that will handle the 'squeeze'. (and, moreover, I take pride in doing a tidy job) Thanks everyone Dave Link to comment Share on other sites More sharing options...
blackrose Posted August 5, 2013 Report Share Posted August 5, 2013 (edited) Advantages: mainly because if you try to connect multiple ring terminals to one bolt, after the first few the crimped bit gets in the way and it won't all lie flat and at the very least you have to have the cables exiting in all directions,probably not the direction you want - definitely an issue with large section cable. You also may get lower resistance connectors since the current doesn't have to flow through all the intermediate ring terminals to get to the middle one (bearing in mind the connection to the threaded part of the bolt is not good). Looks neater? Well not an issue if you are not fastidious, until someone comes along and tries to work out what goes where. I can see the advantages of all your points there, but not your premise which I've highlighted in bold. The threadd bolt itself does not really form part of the electrical conection - its function is simply to clamp the terminals together. If threads caused a connection problem then why are your battery posts threaded? Ring terminals that you put over the battery posts don't connect to the threads, they connect to the base of the terminal under pressure from the nut. Edited August 5, 2013 by blackrose Link to comment Share on other sites More sharing options...
nicknorman Posted August 5, 2013 Report Share Posted August 5, 2013 I can see the advantages of all your points there, but not your premise which I've highlighted in bold. The threadd bolt itself does not really form part of the electrical conection - its function is simply to clamp the terminals together. If threads caused a connection problem then why are your battery posts threaded? Ring terminals that you put over the battery posts don't connect to the threads, they connect to the base of the terminal under pressure from the nut. Yes absolutely right. My point was that there is not a good connection to the threaded bit since its not under pressure. As you say, the connection is via the faces of the ring terminals. But if a large current has to pass from one ring terminal to another, via several intermediate ring terminals, each connection represents a small but non-zero resistance, and a resistance that can increase if any corrosion develops. Link to comment Share on other sites More sharing options...
smileypete Posted August 5, 2013 Report Share Posted August 5, 2013 Tufnol is quite good for bus bar supports, google 'tufnol bus bar' And as Julynian says, ABS project boxes make good covers, some sizes are available in red: http://www.ebay.co.uk/sch/i.html?_nkw=red+abs+box&_sacat=12576 cheers, Pete. ~smpt~ Link to comment Share on other sites More sharing options...
Grace and Favour Posted August 5, 2013 Author Report Share Posted August 5, 2013 Thank you Pete Link to comment Share on other sites More sharing options...
Arthur Brown Posted August 6, 2013 Report Share Posted August 6, 2013 Some of Maplin's boxes may suit, some of their heatshrink sleeve may help too. RS and CPC do more and bigger sizes, including some glue lined heatshrink. Link to comment Share on other sites More sharing options...
smileypete Posted August 10, 2013 Report Share Posted August 10, 2013 Also worth tinning the bus bar if not already done. Blowlamp, rosin flux off Ebay, plumbers solder, pure cotton rag for wiping the excess off, practice on some scrap copper maybe. Might have to retap any threaded holes though. cheers, Pete. ~smpt~ Link to comment Share on other sites More sharing options...
