mark99 Posted May 24, 2013 Report Share Posted May 24, 2013 Hi, I got to get some grease for various bits and pieces. What brand grease is good for general duties including for the water pump gland greaser on the 2LW. Link to comment Share on other sites More sharing options...
Split Pin Posted May 24, 2013 Report Share Posted May 24, 2013 Hi Mark The grease point on the water pump is not for the gland it is for the bearing that the impelleor shaft runs on. This should be lubricated with a a small quantity of LM grade grease occasionaly, make sure that any excess grease has not blocked the drain slot on the bottom of the pump . Steve Link to comment Share on other sites More sharing options...
mark99 Posted May 24, 2013 Author Report Share Posted May 24, 2013 ok Steve thanks - the manual calls it the "water pump gland greaser" perhaps a mis-nomer but I take your point with thanks. Link to comment Share on other sites More sharing options...
jenevers Posted May 29, 2013 Report Share Posted May 29, 2013 Hi Mark The grease point on the water pump is not for the gland it is for the bearing that the impelleor shaft runs on. This should be lubricated with a a small quantity of LM grade grease occasionaly, make sure that any excess grease has not blocked the drain slot on the bottom of the pump . Steve Did I read in the Gardner manual once that the water pump greaser should be turned very seldom, as the grease is actually detrimental to the gland. Seemed a very strange state of affairs Link to comment Share on other sites More sharing options...
Timleech Posted May 29, 2013 Report Share Posted May 29, 2013 Did I read in the Gardner manual once that the water pump greaser should be turned very seldom, as the grease is actually detrimental to the gland. Seemed a very strange state of affairs As Steve said, the grease is for the (ball) bearing rather than the gland. The early pumps had a spherical graphite seal, not really a gland, and any grease on that would certainly render it less effective. The newer pumps have better seals, but even so best to keep grease off them. Tim Link to comment Share on other sites More sharing options...
jenevers Posted May 29, 2013 Report Share Posted May 29, 2013 The newer pumps have better seals, but even so best to keep grease off them. Tim How? Link to comment Share on other sites More sharing options...
Timleech Posted May 29, 2013 Report Share Posted May 29, 2013 How? By following the directions and only very occasionally giving the greaser a turn? Tim Link to comment Share on other sites More sharing options...
jenevers Posted May 29, 2013 Report Share Posted May 29, 2013 By following the directions and only very occasionally giving the greaser a turn? Tim Once a year? Link to comment Share on other sites More sharing options...
