Ark Right Posted January 21, 2013 Report Share Posted January 21, 2013 Curiously, there is railway history before 1961 There were two classes of 0-8-0 compound, three cylinder 'A' class and four cylinder 'B' class. There were built after the experimental simple, two cylinder 0-8-0 at a time when the LNWR had given up building 0-6-0s for goods use (compare with MR practice) Webb's 4-4-0 compounds (Jubilees and Alfred the Greats) were pretty successful passenger locomotives What you are repeating (incorrectly) are the apocryphal stories, probably spread by Ahron,s about the 1880s 2-2-2-0 three cylinder passenger locomotives. For example: http://www.steaminde...people/webb.htm There are two very good reasons why the early compounds didn't last long. Firstly, in the early stages of learning about compounds, Webb picked the wrong arrangement for a three cylinder compound, meaning the two putside cylinders were only just big enough to lift a train. The Smith arrangement used by the Midland was the right choice as it could be used as a three cylinder simple for starting. Secondly, the massive growth in traffic around the turn of the last century meant that they were all too small for the work. Crewe were pretty pragmatic, so into the pot they went Richard Facinating NOT!!!! Not much help to the OP either A Link to comment Share on other sites More sharing options...
Athy Posted January 21, 2013 Report Share Posted January 21, 2013 Curiously, there is railway history before 1961 The Smith arrangement used by the Midland was the right choice Did I suggest that there wasn't railway history before 1961? That's about the time that I was old enough to begin taking a serious interest in it, though. I have owned that Ahrons book for many years so that is probably where I got the information about the poor performance of some earlier LNWER compounds. Pleased to see that you admit the superiority of the Midland design. Link to comment Share on other sites More sharing options...
ditchcrawler Posted January 21, 2013 Report Share Posted January 21, 2013 Do you think you could make an insurance claim Link to comment Share on other sites More sharing options...
Dave_P Posted January 21, 2013 Author Report Share Posted January 21, 2013 Do you think you could make an insurance claim I tried but computer said no. I'm thinking I might upgrade to a 75 litre calorifier and rip out the bathroom, have a re-jig and fit a better bathroom. Link to comment Share on other sites More sharing options...
Bobbybass Posted January 22, 2013 Report Share Posted January 22, 2013 Well clearly it does! Sounds sensible. how do you know it's the right pressure though? It has a pressure gauge on the foot pump... Link to comment Share on other sites More sharing options...
Dave_P Posted January 22, 2013 Author Report Share Posted January 22, 2013 It has a pressure gauge on the foot pump... Doh! With the benefit of hindsight, I feel ashamed of my stupid question! Link to comment Share on other sites More sharing options...
ditchcrawler Posted January 22, 2013 Report Share Posted January 22, 2013 It has a pressure gauge on the foot pump... And if you leave it connected while you run the pump and taps through a couple of cycles you will not only the accumulator pressure but also the pump cutoff pressure. Link to comment Share on other sites More sharing options...
Bobbybass Posted January 22, 2013 Report Share Posted January 22, 2013 And if you leave it connected while you run the pump and taps through a couple of cycles you will not only the accumulator pressure but also the pump cutoff pressure. Exactamento what I do..!! Great to see there are other great minds out there..that think alike... Link to comment Share on other sites More sharing options...
Paul C Posted January 22, 2013 Report Share Posted January 22, 2013 Recently our PRV failed. I took the opportunity to fit one with a built-in pressure gauge. Link to comment Share on other sites More sharing options...
DHutch Posted January 22, 2013 Report Share Posted January 22, 2013 We have a calorifier with expansion tank and it vents a little out of the 3 bar prv everytime its heated from cold. Alternatively, I understand some dont have non return valve in the feed pipe, so slightly naughty make use of the main accumulator by the pump, if you have one of those. Also, if you dont already, fit a isolation valve into the cold feed so you can at least turn the cold water back on! Daniel Link to comment Share on other sites More sharing options...
Dave_P Posted January 23, 2013 Author Report Share Posted January 23, 2013 We have a calorifier with expansion tank and it vents a little out of the 3 bar prv everytime its heated from cold. Alternatively, I understand some dont have non return valve in the feed pipe, so slightly naughty make use of the main accumulator by the pump, if you have one of those. Also, if you dont already, fit a isolation valve into the cold feed so you can at least turn the cold water back on! Daniel I can confirm that cold is back on. Link to comment Share on other sites More sharing options...
