Titan Posted August 3, 2012 Report Share Posted August 3, 2012 Hi Folks Last week we decided to take the boat out for a few hours to recharge our souls, 9 moths now and this was to be our second trip, after having previously sank she is now warm clean and dry, but far from finished. we went from Saul to Glos Docks all went great, i didnt colide with anything, even when mooring up between 2 rather shiny exspesive boats Back to topic, the engine is purring along amazingly well after its ordeal (if a Perkins D3 ) can be decribed as to purr ? But when at the bow the whole craft seems to judder/vibrate? not excessivly but none the less. I havent experienced this on any of my friends boats? and nothing can be felt at the stern ? my thoughts are could it be put down to the bow being high in the water ? as no gas bottles and a empty water tank? making the bow possibly 6/8 inches higher than norm? Also although fully ballasted i have much more weight in the stern to sit low to elleviate cavitation @the prop as not fitted out and weigthted down correctly. Your thoughts and advice appreciated regards Martin Link to comment Share on other sites More sharing options...
The Bagdad Boatman (waits) Posted August 3, 2012 Report Share Posted August 3, 2012 At a guess waves slapping in the bottom. Either that or the bow coming of. Link to comment Share on other sites More sharing options...
IanM Posted August 3, 2012 Report Share Posted August 3, 2012 As you say your boat is far from finished so I imagine it's because there's less in there to dampen the vibration from the engine through the boat. Also I think all boats do it to a more/less extent. Link to comment Share on other sites More sharing options...
twbm Posted August 3, 2012 Report Share Posted August 3, 2012 (edited) Is it doing it at all engine speeds? Might just be yer harmonic vibrations being picked up from the engine at certain revs. Hopefully when the refit is complete and there's more weight/ballast/panelling/bulkheads/foam etc etc it will go away. If not then back to the engine to explore the mountings, propshaft etc. - there's folk on here who know more of this than I do but put simply you may need to get some rubber between the engine and the boat. Edited to add: i.e. what IanM just said but in more words .... Edited August 3, 2012 by twbm Link to comment Share on other sites More sharing options...
Naughty Cal Posted August 3, 2012 Report Share Posted August 3, 2012 As the bow is very light are you sure it wasnt just running along a few ripples/waves in the water? Link to comment Share on other sites More sharing options...
Titan Posted August 3, 2012 Author Report Share Posted August 3, 2012 Thank you all very much for your replys, i will carry on with the fit out and examine more so at a later date, once again many thanks regards Martin Link to comment Share on other sites More sharing options...
